Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » No start
No start
Sheep300
Newbie
Galant VR-4 org Post #: 1236519 posted 04/11/17 05:04 PM     Remind Me!  Send Private Message   Edit Post
My galant vr4 1992 edition has a no start problem ...... What should my gas pressure be ?
Posts: 2 | From: Jamaica | Member Since: 04/11/17 | IP: (207.204.88.137) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1236520 posted 04/11/17 05:08 PM     Remind Me!  Send Private Message   Edit Post
depends, any mods?? is it an after market regulator? most common answer is 39 psi, but can range. i have a lot of things done to mine and i run 43.5 psi, but i have tuning capabilities.
138/2000
Posts: 3417 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Sheep300
Newbie
Galant VR-4 org Post #: 1236526 posted 04/11/17 11:37 PM     Remind Me!  Send Private Message   Edit Post
im getting 20
138/2000
Galant VR-4 org Post #: 1236528 posted 04/12/17 08:39 AM     Remind Me!  Send Private Message   Edit Post
fuel pump, fuel sock, fuel filter.
138/2000
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236534 posted 04/12/17 12:56 PM     Remind Me!  Send Private Message   Edit Post
Transparent dsm is right you need air fuel and spark plus compression for a motor.
Also check your fuses and relays sometime when hard starting the mpi fuse will blow.
I found the anti-lag.
Posts: 582 | From: Fresno, Califonia | Member Since: 06/11/08 | IP: (107.77.109.64) | Report this post to a Moderator
Sheep300
Newbie
Galant VR-4 org Post #: 1236544 posted 04/13/17 08:44 AM     Remind Me!  Send Private Message   Edit Post
i have those it just wont start by the gas pump but if i pour gas in the intake it will start
Posts: 2 | From: Jamaica | Member Since: 04/11/17 | IP: (72.27.18.192) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1236545 posted 04/13/17 09:12 AM     Remind Me!  Send Private Message   Edit Post
20psi is too low of fuel pressure. Check your fuel pump, fuel filter and fuel pump sock as stated above
Thom
Posts: 680 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.22 seconds in which 0.212 seconds were spent on a total of 14 queries. Turbo powered.
