Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 936/1000 progress report
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1219546 posted 10/31/15 12:48 PM     Remind Me!  Send Private Message   Edit Post
Hello everyone. haven't had the time to write one of these up until now. I have owned 936 for about 2 years now. When I bought here she was basically bone stock with a rebuilt bottom end from DSMGraveyard. she has some rust issues that I plan on fixing this spring, (no room in the garage thanks to my brothers TA).
Driveway Queen lol.
Anyway here is how she currently sits.
I would like to see close to 500 horse. I will be switching over to a borg warner s300 turbo soon.
if you see any weak links or have any advice let me know. thanks for looking
Engine- bottom end.
-evo 9 pistons
-dsm graveyard blueprint rods
-evo 9 oil squirters
-stock crank
-cometic mls headgasket
Engine- Head
-mild port on the exhaust side.
-crower 272 cams
-crower single springs w/chromoly retainers
-gsc zero-tick lifters. (they do tick btw)
-BC stainless steal valves
-ferea valve guides and seals
-fidanza cam gears
-hks fine tune belt
Intake
-jmf street intake manifold
-s90 70mm Tb
-ebay intercooler w/short route piping
Exhaust/turbo
-ebay tubular manifold. (its leaving soon)
-stock 16g turbo
-3" DP & exhaust
Fuel/spark
-E85
-FIC 1120 low z injectors
-Fic high flow rail
-255 inline fuel pump
-fuel lab filter
-16g fuel cell
-braided ss lines
-spark tech cop
-ngk br8es
Cooling
-griffin sirocco radiator
-1g upper thermo housing
-si slim fan
Electronics
-odessey pc680
-innovate mtl-x wideband
-glowshift gauges
-boost
-water temp
-oil press
-oil temp
-fuel press
-DSMlink v3
Drivetrain
-act 2900 pressure plate
-act 2900 4puck sprung clutch
-fidanza aluminum flywheel
-trans and difs stock, for now
936/1000-almost going places
95 Honda civic notec DD
Edited by Mn92gvr4 (12/20/15 05:23 PM)
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (96.2.134.194) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1219620 posted 11/02/15 10:17 AM     Remind Me!  Send Private Message   Edit Post
I like the placement of your radiator. Seems thick and like it fit well right behind the intercooler
92 GVR4 #802 link
06 EvoIX SSL-417HP/418TQ-OEM Turbo E85 / Ohlins DFV
94 MX5 M-Edition - On Xidas
SOLD: 92 GVR4 #611
Posts: 790 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1219625 posted 11/02/15 12:19 PM     Remind Me!  Send Private Message   Edit Post
Thanks. It took some finess but it works well.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:2a6:d1) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1219789 posted 11/05/15 05:35 PM     Remind Me!  Send Private Message   Edit Post
Anybody know if the drivers seat back and the passenger seat back are interchangeable? the only difference I see is the lumbar adjustment.
Galant VR-4 org Post #: 1219798 posted 11/05/15 08:06 PM     Remind Me!  Send Private Message   Edit Post
Quoting Mn92gvr4:
Engine- bottom end.
-evo 9 pistons and rods
100% sure you don't have evo 9 rods on a stock 6 bolt crank.
Engine bay looks great though! I wanted to install my intercooler in the same spot You made it work much better though.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1219802 posted 11/05/15 09:10 PM     Remind Me!  Send Private Message   Edit Post
ok. you caught me. the po said it was a dsm graveyard with 9 rods and pistons. just checked their website and its only the pistons. my bad.
thanks the install turned out to be rather simple just attached the upper bracket to the bumper mounts and welded some tabs to the radiator support.
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1219824 posted 11/06/15 08:59 AM     Remind Me!  Send Private Message   Edit Post
Quoting Mn92gvr4:
The seat backs are shaped differently (Larger bolster on the outside of them), also the gear/teeth for the recliner would be on the wrong side.
Thom
Posts: 712 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (50.58.165.200) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1219828 posted 11/06/15 12:12 PM     Remind Me!  Send Private Message   Edit Post
Ah. Ok, they looked similar. Forgot about the gears
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:17cc:9) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1220927 posted 11/24/15 08:12 PM     Remind Me!  Send Private Message   Edit Post
Couple of new additions. Got the head redone after a couple of bent valves. Added a jm fab intake and fic fuel rail.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (96.2.107.18) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1220958 posted 11/25/15 08:25 PM     Remind Me!  Send Private Message   Edit Post
Custom fuel rail brackets.
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1221948 posted 12/20/15 05:25 PM     Remind Me!  Send Private Message   Edit Post
Got her back together after the valve job. Purred like a demented kitten
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1222435 posted 01/02/16 04:17 PM     Remind Me!  Send Private Message   Edit Post
Just got my floor mats. Big thanks to turboflanagan. They look awesome!
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1222546 posted 01/04/16 08:55 PM     Remind Me!  Send Private Message   Edit Post
ok. I believe I have my winter plans laid out.
1. fix the dsmgraveyard bottom end with new rods. I see a lot of people using pauter x beams or manley turbo tuff rods. also considering carillo I beams. any imput one rods would be a big help.
2. kiggly main girdle.
3. borg warner s300 turbo (still working out what specs I need to fit my needs).
4. top-mount exhaust manifold
5. acr2 spark amp
6. finish shaving the bay and minimizing wires
I am looking for 5-600hp plus. any and all input appreciated
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1222690 posted 01/07/16 08:20 PM     Remind Me!  Send Private Message   Edit Post
So this week ive been picking away at a project ive been wanting to do for a while now. Custom front strut brace. Its a dc sports bar for a 2g eclipse with custom mounting plates. Turned out quite well.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:a052:4) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1222697 posted 01/08/16 07:15 AM     Remind Me!  Send Private Message   Edit Post
looks great!!
138/2000
Posts: 3431 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.22.248) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223138 posted 01/23/16 01:50 PM     Remind Me!  Send Private Message   Edit Post
She is coming out! Time for rods and top-mount turbo.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:1749:4) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223403 posted 01/28/16 08:53 PM     Remind Me!  Send Private Message   Edit Post
So i just pulled the pistons and rods. Was planning on just doing rods buuuuut the pistons are pitted as f#ck. So lets replace them to. I am fairly new to the bottom end of the motor. So stock comp ratio is 8.3:1 correct? Im planning on running quite a few booostes, would there be much benifit of switching to an 8.5 or 9.0?
Somehow the cylinders are still mint
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:1709:b) | Report this post to a Moderator
jeverts
Member +
909/1000
Galant VR-4 org Post #: 1223404 posted 01/28/16 09:03 PM     Remind Me!  Send Private Message   Edit Post
Raising the compression will always get you more power. How much pressure are you planning on running? Even on 9.0 to 1 you will have no problem running 35 psi on E85.
Posts: 305 | From: Hartford, WI | Member Since: 07/14/11 | IP: (73.37.195.185) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223405 posted 01/28/16 09:17 PM     Remind Me!  Send Private Message   Edit Post
35 is right around what im looking for. I will be running a borgwarner s300sx 8375, which is capable of 45psi. And if i can reach that i will. Whats the rule of thumb? Higher boost lower c.r?
diambo4life
476/2000
Galant VR-4 org Post #: 1223409 posted 01/28/16 10:41 PM     Remind Me!  Send Private Message   Edit Post
I like 8.5:1. That is already a touch higher than stock which is 7.8:1. I like the extra margin of error that lower compression gives you. You could throw a bunch of boost and timing to it and still be relatively safe. I would mic your bores for taper and concentricity bro especially with the condition of those slugs. At the bare minimum, a cylinder hone will be required when you fit new slugs in there.
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Edited by diambo4life (01/28/16 10:43 PM)
Posts: 229 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (68.12.102.205) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223416 posted 01/29/16 06:16 AM     Remind Me!  Send Private Message   Edit Post
I was planning on running a hone through it for sure. How would i check the others? Slap the caliper in there at a few different points? Its a little concerning those only have 30k on them
jeverts
Member +
909/1000
Galant VR-4 org Post #: 1223419 posted 01/29/16 08:35 AM     Remind Me!  Send Private Message   Edit Post
The best way would be a dial bore gage. Most people are not going to have that equipment. The other way would be with telescope gages and a micrometer. Calipers are not accurate enough.
On another note. You can go 9:1 pistons with that turbo and the boost that you want to run. You just need to make sure you have good enough rods to handle that. Those 1120 low z injectors will not be able to handle that. Even if you went to stock compression pistons you will probably run out of fuel. Same with the fuel pump. Your going to need to go to a wally 400 and run -8 feed lines.
Edited by jeverts (01/29/16 08:39 AM)
Posts: 305 | From: Hartford, WI | Member Since: 07/14/11 | IP: (23.30.240.177) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223421 posted 01/29/16 09:41 AM     Remind Me!  Send Private Message   Edit Post
I have manley turbo tuffs coming. I think im going to go with the 8:5 comp ratio just to be safe. Atleast until my tuning skillz are up to par. I know i am going to run out of fuel at some point. That stuff is a 30 min job to swap out.(inline pump). I'll cross that bridge when the time comes. Dont suppose map has a dial guage they "rent" out?
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:297:33) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223662 posted 02/03/16 01:46 PM     Remind Me!  Send Private Message   Edit Post
Look what mr.fedex brought me today!
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:28f:a3) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1223836 posted 02/06/16 12:16 PM     Remind Me!  Send Private Message   Edit Post
Today i realized that i hate the monstrosity that is our fuse boxes. Other that relocating to the glovebox or something what options do we have? Is there some sort of aftermarket option/replacement?
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:296:44) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 26 anonymous users are browsing this forum.
Generated in 0.277 seconds in which 0.229 seconds were spent on a total of 14 queries. Turbo powered.
