Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » For the AFCO radiator guys...
diambo4life
476/2000
Galant VR-4 org Post #: 1219270 posted 10/27/15 09:50 PM     Remind Me!  Send Private Message   Edit Post
So, I got tired running useless low flow slim line fans and I think I have found a good fan that can handle the VR4's cooling requirements and still fit the AFCO radiator. This fan can only be setup as a puller but should leave room for your typical T3 or T4 bottom mounted turbo. It's the SPAL 30102800 11* HO fan.
If you shop around, you can find it cheaper. This sits perfectly on the AFCO radiator's core. I suggest fabricating mounts for it. It's beefy as hell, makes my old slimline look like a toy. It's heav(ier) and relatively thick. I already had the fan mounted on the radiator (engine was out) and doing quick math and crossing my fingers, the engine dropped right in and I had maybe 1/2 an inch to spare. Closest distance being of the fan motor to the compressor housing of my PTE turbo. I apologize for the low quality photo from the cell...but you get the idea. The setup is also staggered so I don't have to worry about too much about heat from the header.
Edited by diambo4life (10/27/15 09:54 PM)
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (72.198.120.197) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1219509 posted 10/30/15 09:37 PM     Remind Me!  Send Private Message   Edit Post
Looks good. For the price though you might as well run the fans made for the radiator. They have shrouding and work extremely well. They didn't fit with my setup with the JMF T3 TS manifold and HX-35, but they are only 2.5" thick compared to the 4.3" thick one your referencing.
Flex-a-lite Scirocco Radiator
Edited by WaRrIoRs16 (10/30/15 10:13 PM)
Posts: 369 | From: Ferndale, WA | Member Since: 03/23/08 | IP: (204.153.130.50) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1219510 posted 10/30/15 09:50 PM     Remind Me!  Send Private Message   Edit Post
quick question, whats up with your fuel set up, are you running the rail backwards or is the FPR ran between the filter and the rail??
138/2000
Posts: 3451 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.22.189) | Report this post to a Moderator
89Patches
I <3 AMS
Galant VR-4 org Post #: 1219512 posted 10/30/15 10:43 PM     Remind Me!  Send Private Message   Edit Post
Looks like just the opposite of stock. Surprised more guys don't do it. Opens up a little room on the driver side.
Posts: 718 | From: Ontario Canada | Member Since: 01/30/13 | IP: (174.35.243.172) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1219513 posted 10/30/15 10:54 PM     Remind Me!  Send Private Message   Edit Post
Quoting transparentdsm:
It's backwards. The feed is on the driver side. The car was set up like this when I bought it and didn't find a reason to change it. Works just fine.
WaRrIoRs16, I picked up my Spal fan for $125 shipped. Much cheaper than what the major outlets were selling it for. I was just lucky I guess. It works great. I'm yet to see the tempts go over 178*F according to my analog water tempt gauge. Couldn't be happier. Keep in mind, my car was a chronic overheater especially in stop and go traffic. I was actually looking for that shrouded kit when I came across this fan and I got distracted. It seems to flow the same as the kit so all is good.
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Edited by diambo4life (10/30/15 11:00 PM)
138/2000
Galant VR-4 org Post #: 1219524 posted 10/31/15 09:00 AM     Remind Me!  Send Private Message   Edit Post
glad to know this fan setup works. i just upgraded to the scirocco rad and i got the mishimoto 12" high flow fan rated at 1850 CFM so if yours works good then i shouldn't have any issues. i really hate those slim line fans...
138/2000
diambo4life
476/2000
Galant VR-4 org Post #: 1219622 posted 11/02/15 11:34 AM     Remind Me!  Send Private Message   Edit Post
12" may be a little big. This fan fits exactly the dimensions of the AFCO rad "heightwise" and it is an 11" fan. (See my photo below) This fan pulls 14-16A. I had to fix a short over the weekend and in the process, rewired the fan and measured the current draw. I also installed another thermoswitch since the previous one was making the fan run all the time. I can now say that coolant tempts stay right between 170-180* with normal operation according to my analog water tempt gauge. With the fan running all the time, it was running almost 10* cooler especially in the sub 50-60*F weather. Very happy with this mod.
Edited by diambo4life (11/02/15 11:36 AM)
diambo4life
476/2000
Galant VR-4 org Post #: 1227518 posted 05/03/16 07:52 AM     Remind Me!  Send Private Message   Edit Post
Update! FYI, this has been working great! Tempts are right at 190-200*F even after beating on it. Keep in mind this is a car that always had tempts in the 210-230*F area. I can make multiple 40psi+ pulls and the mechanical water tempt gauge needle not move at all! This fan is the ish!
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (64.135.58.130) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1227519 posted 05/03/16 08:41 AM     Remind Me!  Send Private Message   Edit Post
i can concur, i am also using this fan and while driving and beating on it i stay at 190-200, i do still however reach 220 when i let the car sit at idle for a few minutes after some hard pulls.
138/2000
Posts: 3451 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.25.198) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1239576 posted 09/17/17 08:46 AM     Remind Me!  Send Private Message   Edit Post
This has been working great still. A few times I have been stuck on I135 S traffic to Dallas on a Friday evening while driving to the track, in 90deg+ temperatures, stop and go traffic and it works as a champ. No more than 203deg!
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (108.171.131.164) | Report this post to a Moderator
3 registered and 71 anonymous users are browsing this forum.
Generated in 0.23 seconds in which 0.201 seconds were spent on a total of 14 queries. Turbo powered.
