Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Bilstein HDs
Bilstein HDs
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 1003313 posted 07/05/11 10:31 AM     Remind Me!  Send Private Message   Edit Post
I bought these(clicky) from belize1334. I also got the rear evo springs and hats.
Got everything together over the weekend. Rears were a piece of cake. Initially they sat ~0.75” higher vs my old OEM springs on blown AGX but once I finished the fronts and let it settle overnight there is little over 1” drop. I was actually surprised by how much lower they went. I slapped my old oem springs on the fronts after I painted the housings just to get an idea of how it would sit and ride. The front is sky high now with the rear having dropped.
In regards to ride these are great. The rears handle the evo spring rate just fine. No weird oscillations or bouncing – just flat and smooth. What a big improvement in ride quality over the agx. Smooth and stable with little body roll. Soaks up bumps quite well and is super stable in a corner with only a roughed-in alignment. I just need to get the front springs sorted. I like how it rides so much that I might try some DSM front springs so it levels out some without too much increase in front spring rate. I can’t believe more people hadn’t figured out and tried these Bilsteins.
Posts: 1141 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (75.148.192.233) | Report this post to a Moderator
123abc
1945/2000
Galant VR-4 org Post #: 1003395 posted 07/05/11 04:26 PM     Remind Me!  Send Private Message   Edit Post
I must ask, whats the problem running 3kgt vr4 Bilstein hd's? Why the bmw rears?
Edited by 123abc (07/06/11 10:25 AM)
Posts: 144 | From: Winona, MN | Member Since: 03/02/07 | IP: (174.253.148.214) | Report this post to a Moderator
Galant VR-4 org Post #: 1181506 posted 07/24/14 09:17 PM     Remind Me!  Send Private Message   Edit Post
Any chance there's a part number on the cut struts your using to house you bilstein inserts?
7 1G DSM's now a GGSX build.
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2001:5b0:22ff:cf) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1181569 posted 07/25/14 01:57 PM     Remind Me!  Send Private Message   Edit Post
I have the whole build up on DSM tuners.com, Just search for Bilstein HD. You will see everything I did
Rick
Posts: 53 | From: pagosa springs colorado | Member Since: 11/26/10 | IP: (75.121.84.169) | Report this post to a Moderator
Galant VR-4 org Post #: 1181625 posted 07/25/14 08:04 PM     Remind Me!  Send Private Message   Edit Post
I've read it and commented. My questions weren't answered.
Edit:
I guess you tried cutting open gr2s from a DSM and it didn't fit? Well last question I have would be is it worth 300 for front struts when you can get bc set for ~1k?
Edited by tektic (07/25/14 08:57 PM)
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (208.54.45.252) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1181631 posted 07/25/14 09:31 PM     Remind Me!  Send Private Message   Edit Post
My opinion is that Bilstein HDs are much better than any cheap coilovers on the market. Their is no part # for the strut housing because they were built in my garage. All of my modds are custom made in my garage. I am old school hot rodder, always build your own parts, not bolt ons
Rick
Galant VR-4 org Post #: 1181652 posted 07/26/14 12:12 AM     Remind Me!  Send Private Message   Edit Post
What is the actual outside diameter ?
Edit:
What spring rate and length are you running up front?
Edited by tektic (07/26/14 12:18 AM)
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1181664 posted 07/26/14 07:53 AM     Remind Me!  Send Private Message   Edit Post
I run 375 front springs x 12". You could run 10". All the measurement are on the Bilstein web sight for the strut. I spoke to Was @ Bilstein wast coast.
Galant VR-4 org Post #: 1181712 posted 07/26/14 03:01 PM     Remind Me!  Send Private Message   Edit Post
What's the impression with these springs? It is on a Galant right? Do you have a picture of the ride hight? I have a 7" 280# set, up front that is maxed out tall and has a huge drop. They are just not cutting it. I was considering a set of 9" but will now look into 10". You are using the gc sleeves right?
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.88.15.63) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1181766 posted 07/26/14 09:49 PM     Remind Me!  Send Private Message   Edit Post
Quoting pagosadsm:
Rick
What makes the damper so awesome?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3311 | From: SoCal | Member Since: 01/02/12 | IP:
(174.251.228.191) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1181771 posted 07/26/14 10:19 PM     Remind Me!  Send Private Message   Edit Post
://farnorthracing.com/I think Dennis Grant knows more on Struts and shocks than most people on Mitusbushi sights. This is good reading.
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1181786 posted 07/27/14 12:08 AM     Remind Me!  Send Private Message   Edit Post
That was a good read. Thanks for the link. I'm not sure if I would ever compare NASCAR to F1 though.
My issue is that unless these are valved specifically for the VR4, they probably leave a lot to be desired compared to even some of the "cheaper" coilover setups. Sure, I'm sure they are really nice dampers, but unless they are set up specifically for the car, you aren't going to use them to their full potential, especially since they aren't adjustable. You'd need somebody like Mueller to do the leg work and figure out the optimal valving, and then find someone to actually modify the dampers. My point being, these would need to be properly valved to really be an improvement over even a decent to cheap adjustable damper.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (07/27/14 12:11 AM)
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1181797 posted 07/27/14 02:57 AM     Remind Me!  Send Private Message   Edit Post
Bilstein HDs are nice, on their own though they are just an upgrade over stock dampers. Bilstein can revalve them for you to any specification you chose. They are good for a set it and forget it style setup, but anyone who wants to tune their dampers will be unable.
What does the one lap VR4 run?
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (67.168.143.160) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1181808 posted 07/27/14 08:48 AM     Remind Me!  Send Private Message   Edit Post
Last time I spoke to him he had a blown set of Konis
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 1181837 posted 07/27/14 01:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting coyotes:
This, altho "unable" really should be "not easily" ( send them to Bilstein for revalve ).
Bilstein suspension products are about as good as they come. Run them on my Subaru's and had a set on 86/2000, for an install-and-forget system there's nothing better IMO.
Mike O.
#464/1000 - Sold
05 Legacy GT - 6MT swap
#86/2000 - Sold ( again )
Posts: 3098 | From: Portland, OR | Member Since: 09/10/07 | IP: (12.12.162.124) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1181839 posted 07/27/14 01:43 PM     Remind Me!  Send Private Message   Edit Post
I believe Coyotes ment "unable" as is you aren't going to do it yourself like you can with an adjustable set of dampers.
As I said, drop in Blistens (or any damper) should be valved for a specific application. I don't see how they could possibly perform better than adjustable dampers unless they are properly valved. Who has figured out how these should be valved for a Galant VR4, because a damper set up for a 3kgt wouldn't even be close IMO? It sounds like people typically buy these for another application (like a 3kgt) and just drop them in a strut assembly that fits the Galant. If that's the case, you'd probably be better off with a Blisten damper for an Evo or something, if they are even available for an Evo. At least then the valving would probably be closer to being right for the Galant.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (07/27/14 01:44 PM)
(174.251.228.82) | Report this post to a Moderator
Galant VR-4 org Post #: 1181883 posted 07/27/14 08:42 PM     Remind Me!  Send Private Message   Edit Post
3kgt 3350-3655 lbs weight distribution F/R: 60/40
G-vr4 Curb Weight: 3,270-3527lb weight distribution F/R: 58/42 spring rate front:
Evo-X Curb Weight: 3,131–3,527lb weight distribution F/R: 57/43 spring rate front: 3.5kg(196lb) rear: 2.9-3.8kg(162-212lb) (kg/mm & lbs/in)
The weight isn't that dissimilar so why would the valving be that far off...
This guy loves bilstines click
Edited by tektic (07/27/14 08:43 PM)
pagosadsm
Galant VR-4 org Post #: 1181892 posted 07/27/14 10:01 PM     Remind Me!  Send Private Message   Edit Post
I like my Bilsteins. Yes the valving is correct according with Bilstein USA. I was in close communication with Wes at the Bilstein west coast. He was very interested with what I was doing. Bilstein was in the development with manufacturing housing for their struts. I don't have unlimited funds and my thought the Bilsteins was the best choice. As far as the people that disagree with Bilstein show us what you have done with your car. You can see my profile and photos of my build on DSM tuners. I am Shure you have a great car with all of the supporting up grades, all tubular control arms with all steel and heim joint suspension. Upgraded brakes, frame stiffing and roll center and bump steer adjustment. I built the Bilstein stuts and shocks with Ground Controls coilover springs and camber plats for less than $1000.00.
Tektic
I sent you a PM with my phone#. If you would like to give me a call, I would be happy to help
Rick
Posts: 53 | From: pagosa springs colorado | Member Since: 11/26/10 | IP: (72.161.112.55) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1181896 posted 07/27/14 10:15 PM     Remind Me!  Send Private Message   Edit Post
For the fronts, the part number R36-5021-H0 doesn't exist anywhere that I can find. I also don't see it listed anywhere for a 3KGT. The part number F4-R36-5022-H0 DOES exist however, and that shock is listed for a 3000GT VR-4, which weighs in closer to 3,800-3,900 lbs. Someone feel free to school me up if i'm not Googling good enough.
The rear is listed for multiple BMW applications ranging from the 89' 525i (3,400 lbs) to the 95' 540i (3,700 lbs). Anyone's guess how that one is valved.
Weight distribution doesn't help you that much when comparing 2 vehicles with substantially different weights. You could have 2 cars with 60/40 weight distribution, but if one weighs 100 lbs and the other weighs 1,000lbs, these two cars don't have a bit of common ground when picking the proper suspension setup.
I'm not sure how these would be valved honestly. That was my point. It's anyone's guess until someone does the research on this particular damper (shock dyno, etc). I would go with a cheaper "tuneable" damper before I dropped these in, and did a bunch of custom work just to make them fit. I just don't see the payoff. But, that's just me. I'm sure they are a vast improvement over stock. But, a vast improvement over a cheaper adjustable damper? I just don't see how they would be right out of the box.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (07/27/14 10:19 PM)
(76.88.98.84) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1181897 posted 07/27/14 10:20 PM     Remind Me!  Send Private Message   Edit Post
Quoting pagosadsm:
Tektic
Rick
I'm not a hater or a doubter of bilsteins. I would love to see your setup actually. It is only my opinion that no one on here is serious enough to go with a proper track setup. BCs or JICs do the trick for those who hit the track for fun.
1226/2000
pagosadsm
Galant VR-4 org Post #: 1181901 posted 07/27/14 10:37 PM     Remind Me!  Send Private Message   Edit Post
You can see my profile and photos on DSM tuners. I have the Bilstein build up there also. Just search Bilstein HD
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1181904 posted 07/27/14 10:46 PM     Remind Me!  Send Private Message   Edit Post
The custom work you did on the front dampers was sweet. Did you use the Hyperco springs on the front and back? What were the rates?
And here's his build: click
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (07/27/14 10:51 PM)
Galant VR-4 org Post #: 1181931 posted 07/28/14 07:04 AM     Remind Me!  Send Private Message   Edit Post
I will give you a call today some time. Thank you.
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1181956 posted 07/28/14 10:38 AM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
If you're talking about cheap japanese single adjustable coilovers, you're likely better off with some evo bilsteins, mostly because the adjusters are fucking worthless... "more rebound? Let's add more compression too!" Not going to lie, there are reasons for cheap coilovers, and some of the brands (i.e. BC) seem to hit a price point while delivering decent performance. None of them are going to be on the level of Ohlins/Penske, but they're 25-35% of the cost, so it makes sense.
One interesting thing about NASCAR, is that while the racing may not be my cup of tea, the fact that the platform changes so little, and the fact that they keep getting faster is similar to how a stupid design like the 911 (rear engine is inherently inferior to mid engine) has gotten so good over time. Having to perfect every aspect of the car to get the performance out is a different challenge than dealing with new engine, chassis & aero requirements every few years.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3593 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (209.189.196.1) | Report this post to a Moderator
Galant VR-4 org Post #: 1182047 posted 07/28/14 06:36 PM     Remind Me!  Send Private Message   Edit Post
Check out this spring claculator!
Front and rear motion ratios were listed as .92/.844 on tooners
a=d1 b=d2
This is what I came up with:
weight: 3500
front weight: 58%
unsprung front: 80lb
unsprong rear: 80lb
SF Front: 1.8hz
SF Back: 2.0hz
Spring angle: 5%
Front MR: .98
Rear MR: .844
acf: 1
Front corner sprung: 935lbs
Rear corner weight:: 655lbs
Front WR: 309 lb/in
Rear WR: 267 lb/in
Front SR: 323 lb/in
Rear SR: 377 lb/in
Edited by tektic (07/28/14 07:33 PM)
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (63.118.210.7) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.291 seconds in which 0.201 seconds were spent on a total of 14 queries. Turbo powered.
