The Mitsubishi Galant VR-4 Forum
Galant VR-4 Forums » Galant VR-4 » Technical Discussions » TSB for Aligning the Rear
Galant VR-4 org Post #: 895940 posted 05/04/10 09:46 PM     Remind Me!  Send Private Message   Edit Post
Cleaning my Garage I found this paper to help those who are having problems with getting their rear alignment done with 4WS.
| | | IP: ( | Report this post to a Moderator
Galant VR-4 org Post #: 895965 posted 05/04/10 10:59 PM     Remind Me!  Send Private Message   Edit Post
I took that with me to the shop a few years ago when having 855 aligned. they looked at me like I was from Mars. Then they proceeded to screw it up and I had rear tire wear issues.
I would suggest undoing the rear tie rod ends before going to get an alignment, then reinstalling them yourself following the shop's adjustment. Just make sure and adjust them properly so you have no preload affecting the just performed alignment.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10480 | From: Michigan | Member Since: 03/05/01 | IP: ( | Report this post to a Moderator
Galant VR-4 org Post #: 895980 posted 05/04/10 11:45 PM     Remind Me!  Send Private Message   Edit Post
^That's exactly how you do it. I've been doing alignments for a while and that is the only way I would do mine. Anything else is just stupid. Disconnect tie rods, do the 4 wheel alignment, screw/unscrew tie rods so they fall right in without pulling or pushing on the control/trailing arms. DONE!!!
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Edited by marvinmadman (05/04/10 11:50 PM)
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: ( | Report this post to a Moderator
Galant VR-4 org Post #: 896243 posted 05/05/10 05:19 PM     Remind Me!  Send Private Message   Edit Post
thanks for posting this, even though I work as a tech I would have not done this when I did my car. Guess that's what happens when you align honda's all day long
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: ( | Report this post to a Moderator
atc250r Galant Moderator
Senior Ricer
Galant VR-4 org Post #: 896286 posted 05/05/10 07:44 PM     Remind Me!  Send Private Message   Edit Post
Some alignment machines will actually warn you to disconnect the 4WS before doing the alignment.
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: ( | Report this post to a Moderator
Member +++
Galant VR-4 org Post #: 931917 posted 09/16/10 06:14 PM     Remind Me!  Send Private Message   Edit Post
Thank you for the good info
92 GVR4 #802 link
06 EvoIX SSL-417HP/418TQ-OEM Turbo E85 / Ohlins DFV
94 MX5 M-Edition - On Xidas
SOLD: 92 GVR4 #611
Posts: 789 | From: Corona, CA | Member Since: 04/08/08 | IP: ( | Report this post to a Moderator
Gas Analyzer
Galant VR-4 org Post #: 931921 posted 09/16/10 06:32 PM     Remind Me!  Send Private Message   Edit Post
Just did mine, Had to replace two tires because the last alignment I paid for was fubar! I gave then a printout of how to do it & I think they just ignored me Set the front toe charged me for a four way & sent me down the road . So glad to work where we have an alignment rack again, never did trust anybody to touch my car but me .
Car just absolutely handles better now. Stand over their shoulder while they do it to make sure the tech won't puss out & screw you over, I'd swear as bad as it was they must have just eyeballed it, Tire Factory in Tacoma WA, FTMFL!!!
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: ( | Report this post to a Moderator
Carbon Fiber Cage
Galant VR-4 org Post #: 931990 posted 09/16/10 09:43 PM     Remind Me!  Send Private Message   Edit Post
^ I do my own as well, but I tell people to make sure you request the print out of your alignment. I don't know of any decent machine that doesn't have printer capabilities, and then you can see before/after.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
01 GMC Sierra C3 AWD
05 CTS-V Stealth Grey
Posts: 1619 | From: Bucks County, PA | Member Since: 06/28/08 | IP: ( | Report this post to a Moderator
Galant VR-4 org Post #: 935596 posted 09/29/10 06:56 PM     Remind Me!  Send Private Message   Edit Post
im a tech and specialize in front end work and the alignment print out really means nothing because you can change the specs in the alignment program so it shows up green/in spec without changing anything. this comes in handy with old chrysler minivans and volkswagens/nazi sh*t boxes.
Galant VR-4 org Post #: 935608 posted 09/29/10 07:26 PM     Remind Me!  Send Private Message   Edit Post
600 is right, the printout is a way to fool the customer into unnecessary alignment parts and so they feel like you've done something to earn their money. The numbers can be manipulated anyway the user wants. I'm not saying that every printout ever printed is bogus, its just not 100% reliable, that's all.
Galant VR-4 org Post #: 1238026 posted 06/15/17 10:39 PM     Remind Me!  Send Private Message   Edit Post
Yet again, 600 is right. I'm a tech and over the many years I've used Hunter racks, I have learned that you can very easily go into the vehicle specifications and modify them to put "EVERYTHING IN THE GREEN". Much easier than adding shims or fighting old bent or settled suspensions or having to reposition subframes.
Though, I have done quite a few of the local gvr4's in my area and on almost every vehicle I have had to torch the rear tie rods or toe adjustment eccentrics/cams. Not because of rust either. It's just old and corroded and sometimes refuse to turn or loosen up in the first place. I've been able to get most of these cars set up absolutely perfect to either factory or user defined specs.
I guess what I am saying is, it's totally doable. Make sure the shop you take it to has an experienced tech who has done atleast a couple aws alignments and understands how to do this without melting bushings or completely ruining the alignment all together. I'd suggest talking with the tech and seeing if you can watch. Call around till you talk to somebody wbo seems confident and knowledgeable. And most importantly knows what a vr4 is when you mention it!
Edit:whoops for some reason I thought I was commenting on "miguextreme's" post -CAN THE REAR WHEELS BE ALIGNED.. Got linked here and forgot by the time I submitted my comment.
VR4 677/1000-rebadged. AKA Charlie the turbo slut DD
Edited by highrpm666 (06/15/17 10:51 PM)
Posts: 118 | From: Morrison, Co | Member Since: 02/19/14 | IP: (2607:fb90:6e26:a) | Report this post to a Moderator
2 registered and 15 anonymous users are browsing this forum.
Galant Moderator:  curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker
Contact Us | Privacy statement
Generated in 0.265 seconds in which 0.222 seconds were spent on a total of 14 queries. Turbo powered.
