Galant VR-4 Forums » Galant VR-4 » Technical Discussions » QM twin disc questions
bob92vr4
Member +
????/1000
Galant VR-4 org Post #: 864352 posted 01/11/10 05:18 PM     Remind Me!  Send Private Message   Edit Post
Ok so I bought a used QM twin disc and Im getting ready to install this thing and just curious if anyone with experience with these can tell me if i should install the isuzu slave and a pedal stop. I have search this subject and cant find any info on it also if anyone know's where to find dsm/gvr4 specific install info I.E how much material and where it needs to be removed from the stock clutch fork that would be great too thanks.
Posts: 258 | From: littleton colorado | Member Since: 12/24/03 | IP: (71.212.171.136) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 864380 posted 01/11/10 07:26 PM     Remind Me!  Send Private Message   Edit Post
If I recall correctly, the Isuzu lave and clutch stop are needed for the PTT twin, not the QM.
The 2g accumulator and slave can be used to help out the driveability, and help a ton. As far as trimming the fork, Im not sure how much needs to be trimmed, you may just need to test it out and see.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (71.214.95.177) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 864446 posted 01/11/10 10:20 PM     Remind Me!  Send Private Message   Edit Post
I used the stock slave and no pedal stop with mine.
I set the clutch up on a bench and assembled the fork and throwout bearing then laid the fork on the clutch housing to see where the bolts would hit and ground away that area only.
Took a decent amount of time till I could rotate the fork all the way round the clutch housing without it hitting any of the bolts.
That seemed to be the easiest way to do it without having the motor out so you could test fit everything easily.
I was a bit paranoid about it hitting though!
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 953 | From: brisbane australia | Member Since: 02/13/04 | IP: (58.165.110.24) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 864449 posted 01/11/10 10:36 PM     Remind Me!  Send Private Message   Edit Post
Here are some pics of the fork.
| | | IP: (75.142.219.92) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 864452 posted 01/11/10 10:56 PM     Remind Me!  Send Private Message   Edit Post
Ok since this is used you need to check it first. It may be fine but you don't want to install it and a month later smoke two disks that are about 220 to replace plus the time and effort to pull it again.
first you need a slab of marble or something known to be dead flat. Thick mirror etc. Set the flywheel face down and measure the inside of the friction area and do the outside with a feller gauge do the same to the pressure plate disk friction surface. I can't remember the specs on it but I'm sure a quick call to QM or PTT will get the specs they cup from heat. Its steel under tremendous load and heat and will cup do all the way around it. Now for the disks measure the thickness all around and get an average thickness also get the specs for it. The disks are only allowed like .008 total loss or something like that so It might look perfect and plenty of material left but may be junk. When my thrust went out I was about 70 miles from home and kept trying to adjust the clutch and nothing help so I limped it home. I had worn off like .070 total on both disks and Steve (I think that's his name) at PTT couldn't believe I got home.
As for the isuzu slave. I used it on mine and didn't build a stop because I never slab it to the floor and never over extend it anyway so just a waste for me but a stop would be easy enough to build. I found my slave out in the shop other day and some how one of the new bolt holes I drilled broke off so I'll have to get another or just have a stock one bored out and the piston from the izuzu installed in it. Alot has to be cut off the ears for the mitsubishi bolt holes to line up but a hack saw and a drill will only take a few minutes. Measure and mark 4 times cut once.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.95.177.176) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 864480 posted 01/12/10 12:48 AM     Remind Me!  Send Private Message   Edit Post
I bought my setup used from a buddy that put maybe 700 miles on it and installed it using the stock slave cylinder and put a bolt in the lower clutch switch location to create a pedal stop. Mine came with a clutch fork that was already clearanced. Works fine, but the clutch is very on/off. I recently purchased a 2gDSM AWD slave and accumulator that I will be installing with a new transmission this spring. I will also be removing the pedal stop. BrianAWD has had good luck using this combo on his setup.
-Mark
1051
Posts: 11957 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 864485 posted 01/12/10 01:16 AM     Remind Me!  Send Private Message   Edit Post
I drove Brians car when he had just the accumulator installed. It was very, very manageable, not much more aggressive than my 2600/6 puck setup.
When my QM goes in, Im going to strictly swap the clutches, then later add the accumulator and 2g slave just to see how each piece affects the clutch on my setup.
cobrajetguy
Doppleganger
1886/2000
Galant VR-4 org Post #: 864782 posted 01/12/10 10:26 PM     Remind Me!  Send Private Message   Edit Post
I have a PTT in my GVR4, I used a bolt in the stock clutch switch location to make a pedal stop and I couldn't ever get the isuzu slave to bleed perfect so I put a stock slave back on it and it was fine. I didn't clearance the clutch fork but it will definitely hit if the stop is not set perfect which makes it pretty close to the floor on engagement. I already chewed through a set of metallic discs street driving the car and am trying a set of organics next and will clearance the fork while it's apart.
Peter
'91 Belize Green Galant VR-4 Sold
'92 Nile Black Galant VR-4 Sold
'91 Summit White Galant VR-4 Rally Project
'94 Red TSi AWD Rally-X + DD
'01 Red EVO VII RS-II
Posts: 407 | From: Fort Collins, CO | Member Since: 08/02/04 | IP: (24.9.94.185) | Report this post to a Moderator
bob92vr4
Member +
????/1000
Galant VR-4 org Post #: 864795 posted 01/12/10 11:00 PM     Remind Me!  Send Private Message   Edit Post
good info thanks guys. Any advice on where to pick up the 2g parts jnz or dealer?
Posts: 258 | From: littleton colorado | Member Since: 12/24/03 | IP: (71.212.182.61) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 864799 posted 01/12/10 11:11 PM     Remind Me!  Send Private Message   Edit Post
So whats the bore dia. on the 2nd gen slave and also whats the dia of the master on a second gen. I have one of there masters in the shop somewhere to go on mine because it comes with a remote mount fluid tank. If no one knows right off hand I'll dig it out and measure.
92 GVR4 0475/1000
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 864800 posted 01/12/10 11:13 PM     Remind Me!  Send Private Message   Edit Post
Id just go through JNZ. They wont jerk you around like a dealer may.
1941Galant
Will fight mice for food
1941/2000
Galant VR-4 org Post #: 864856 posted 01/13/10 09:27 AM     Remind Me!  Send Private Message   Edit Post
Quoting cobrajetguy:
Peter
You don't have to clearance the fork when using the PTT twin disk. I don't use the clutch stop with my twin disk, I make sure the clutch disengages just before the clutch pedal hits the floor, and I test it every time I fire the car up. I also use the 2g fwd slave w/ the clutch line accumulator.
Posts: 1904 | From: Charles Town, WV | Member Since: 08/21/04 | IP: (24.115.13.29) | Report this post to a Moderator
bob92vr4
Member +
????/1000
Galant VR-4 org Post #: 864977 posted 01/13/10 06:57 PM     Remind Me!  Send Private Message   Edit Post
ok so i went to jnz they dont have a accumulator listed does anybody have the part #'s? and are both the slave and accumulator from the fwd and not awd?
Posts: 258 | From: littleton colorado | Member Since: 12/24/03 | IP: (71.218.125.41) | Report this post to a Moderator
1941Galant
1941/2000
Galant VR-4 org Post #: 864991 posted 01/13/10 07:44 PM     Remind Me!  Send Private Message   Edit Post
Here are the part #'s that were posted in another thread, they were apparently taken off of the link forums. I believe the accumulators came on both FWD and AWD 2g DSMs.
Accumulator - 2ga - MD746400
Accumulator - 2gb - MD749915
Long hard line - MD746084
Short hard line - MD745644
Edited by 1941Galant (01/13/10 10:00 PM)
1qkfwd
1868/2000
Galant VR-4 org Post #: 867365 posted 01/21/10 07:40 PM     Remind Me!  Send Private Message   Edit Post
I run the QM on my talon. I love it. I have the 2G slave and accumalator, I can slowly the pedal out and inch the car forward as needed. I probably couldnt do that without the accumalator. No stop yet I run the pedal a little low. I talk to shep about the stop he said over time it can over extend the fingers on the pressure plate, and cause some stuff to warp. I like the idea of installing a stop where the switch is. I looked right over that.
92 eclipse FWD [email protected]
92 Talon AWD Best et [email protected] 1.39 60'
2011 GTX series here we come!
#1868/2000 Looking for 10s on pump
Posts: 209 | From: Sun Valley, NV | Member Since: 09/29/09 | IP: (75.14.219.205) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248299 posted 02/06/20 11:19 PM     Remind Me!  Send Private Message   Edit Post
Bringing this back thanks to Andrew's suggestion. Ordered the accumulator to try and further tame my QM clutch, so I'll report back in 2 years when I actually feel like wrenching on the car.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3432 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:8801:da00:5) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1248301 posted 02/07/20 01:16 AM     Remind Me!  Send Private Message   Edit Post
by then maybe mine will be back together too!
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3713 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (75.172.29.63) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248305 posted 02/07/20 07:28 PM     Remind Me!  Send Private Message   Edit Post
Scratch that. Dealer just emailed me:
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(2600:1012:b10d:2) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1248306 posted 02/09/20 03:11 AM     Remind Me!  Send Private Message   Edit Post
I had to find mine at a junkyard. Of course I never got around to installing it and went back to a single disk because I don't give a shit about racing anymore. Sold it to somebody. Don't remember who.
-Mark
1051
Posts: 11957 | From: Yakima, WA | Member Since: 04/29/01 | IP: (47.42.152.133) | Report this post to a Moderator
thecman02
too lazy to look
580/1000
Galant VR-4 org Post #: 1248325 posted 02/12/20 05:52 PM     Remind Me!  Send Private Message   Edit Post
You sold the QM to me. I ended up putting "street" friction disks with Tim Zimmer's Gear Drive setup. It worked great. You also sent me the accumulator and I didn't want/need it. I ended up selling it for a case of top shelf beer haha.
580/1000
2013 Max Effort Winner
-Chris
Posts: 913 | From: Kalamazoo,MI | Member Since: 11/03/07 | IP: (64.136.244.130) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248844 posted 04/26/20 11:47 PM     Remind Me!  Send Private Message   Edit Post
Added the 2G accumulator. The clutch feels a little better, but still sucks ass overall.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Generated in 0.087 seconds in which 0.046 seconds were spent on a total of 14 queries. Turbo powered.
