Problem while cruising
RWD4G63
NY
I was driving on the highway the other day and my car started to miss. When I accelerated it went away and the car accelerates clean and strong. When I decellerate I get a slight popping. The tach bounces around when the car misses but aside from the missing during cruising there seems to be no other problem. I have an MSD ignition so I bypassed it and it did the same thing. Plugs are OK and no DTC's. Thought it might be my CAS but with the lack of issues during hard acceleration I'm not sure...any thoughts???
Test & check the spark plug wires. Because when you gas it..give full charge & power. But when you cruising...less charge & power. It happen on me few years back. I changed the wireset...it's all back to normal. Hope it help.
icurunnin
Fort Worth Tx
^x2
I had the same issue on 501 and the boot was arching the coil pack. swapped wires and it went away.
RWD4G63
NY
I should have mentioned its a COP setup. It almost feels like fuel starvation, its a really strange miss.
if your getting full power when accelerating then it's not an ignition problem. popping from the exhaust is from excessive fuel in the exhaust. your probably shooting some flames /ubbthreads/images/graemlins/laugh.gif
do you still have egr? the egr system is active under cruise but not during acceleration. I know in hondas when the egr ports get clogged they miss under cruise but no other time.
check and make sure a hose hasnt come loose too.
