Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Air conditioning
Air conditioning
cevic
Galant VR-4 org Post #: 15147 posted 06/16/03 04:19 PM     Remind Me!  Send Private Message   Edit Post
Does anyone know how to recharge the air conditioning system. Autoparts stores sell the recharge kits that cost about $15. Do they work?
| | | IP: (24.124.95.48) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 15148 posted 06/16/03 04:34 PM     Remind Me!  Send Private Message   Edit Post
it will work
but you really should vaccume out the system.
just dump 2-3 cans in for a cheap fix though.
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (138.89.76.150) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 15149 posted 06/16/03 04:56 PM     Remind Me!  Send Private Message   Edit Post
Use a can of stop leak too so you can try and seal whatever leak caused the original coolant to leak out.
Ya you "should" have someone vacume out the system. However, if you don't get ANY cool air what so ever, then all the coolant is probably gone anyway.
So, who all has a original working AC? I do, I do [Smile]
Posts: 5947 | From: central Indiana | Member Since: 08/06/02 | IP: (12.221.228.124) | Report this post to a Moderator
slvrblt
Galant VR-4 org Post #: 15150 posted 06/16/03 06:21 PM     Remind Me!  Send Private Message   Edit Post
I have the working system, but I think its out of R12. I will be converting it to R134a in a week or two.
| | | IP: (68.35.27.99) | Report this post to a Moderator
Minjin
Galant VR-4 org Post #: 15151 posted 06/16/03 11:18 PM     Remind Me!  Send Private Message   Edit Post
This is an area I'd really recommend taking it to a pro for. You don't want to end up buying a compressor too because you messed it up by not putting enough oil in or whatever.
And don't use stop leak!!
Mark
| | | IP: (24.54.214.19) | Report this post to a Moderator
BlackHole
Galant VR-4 org Post #: 15152 posted 06/17/03 06:13 AM     Remind Me!  Send Private Message   Edit Post
I used to agree with Mark, but now I'm not so sure. I've done one R134a job the right way [change all the seals, drier, expansion valve, evacuate the system, lube & recharge], one the sloppy lazy way [replace the drier, lube and recharge]. I can't tell the difference between the two cars A/C operation.
Since I have two or three spare A/C compressors, if one goes out I'll just swap another one in. If you don't have the spares and equipment and have to buy an expensive rebuilt compressor then I'd lean more heavily towards having a pro do it.
just my $.02
| | | IP: (130.36.27.130) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 15153 posted 06/17/03 07:04 AM     Remind Me!  Send Private Message   Edit Post
Mark
Not the product "stop leak". They do have stuff made for your AC system.
turboflanagan
I would give myself something respectable.
478/1000
Galant VR-4 org Post #: 15154 posted 06/17/03 10:55 AM     Remind Me!  Send Private Message   Edit Post
Work for what? For your car? Maybe, maybe not. Most are for r134a systems. IF yours hasn't been converted it is r12. Not the same by any means.
The evap is really the only real difficult part to change out. Everything else is relatively simple. If you have a leak, fix the leak! Don't put some crap in there that will clog whatever in addition to the leak.
If you have moisture in the system it needs to be boiled out. That is the reason to vacuum the system down. Water boils at a lower temp under a vacuum. Vacuum the system, leave it for a while, the water boils out of the system. Then you can recharge it with new refrigerant. I use Freeze12 to replace the r12. It works great for me and I don't have to change any components or worry about getting all the oil out that isn't compatible with the r134a. Just my lazy preference.
Posts: 2551 | From: Peachtree Corners, Georgia, US... | Member Since: 03/05/01 | IP: (65.114.37.193) | Report this post to a Moderator
LastOne
Galant VR-4 org Post #: 15155 posted 06/17/03 08:52 PM     Remind Me!  Send Private Message   Edit Post
My original AC system (at 205,000 miles) was accidentially drained by the previous owner as we were removing the engine.
I had it recharged with R-12 once the engine was back in, and it works great.
Up to 230,000 miles now [Smile]
| | | IP: (64.252.159.64) | Report this post to a Moderator
1 registered and 27 anonymous users are browsing this forum.
Generated in 0.075 seconds in which 0.056 seconds were spent on a total of 14 queries. Turbo powered.
