Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Headlights stopped working/Random Issues
Amanthius
Newbie
Galant VR-4 org Post #: 1247829 posted 12/02/19 06:58 PM     Remind Me!  Send Private Message   Edit Post
Hey guys, I tried searching online but could not find any answers.. I have a couple of issues on my newly acquired car:
1) Car sputters sometimes, and the CEL is on. I ran the LED Diagnostic and it seems to be my fuel injectors not working properly and the o2 sensor being faulty. Would you guys recommend replacing the fuel injectors or cleaning out the current ones? I ordered an AEM Wideband o2 guage that comes with the o2 sensor, do I just replace the o2 sensor in the car now and pop in the new one? Would that fix the o2 diag code?
2) My low beams and high beams randomly stopped working. I replaced all of the fuses within the engine bay and some on the kick panel but no luck. I am thinking about replacing the bulbs to see if that fixes the issue but before I do that, is there any location I should check? Maybe a different fuse panel? I have a 91 GVR4. I appreciate your help.
Thank you.
Posts: 18 | From: San Antonio, Texas | Member Since: 09/05/19 | IP: (198.49.125.32) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1247832 posted 12/03/19 08:06 AM     Remind Me!  Send Private Message   Edit Post
I'd buy a brand new o2 sensor to replace the one in the car, the aem is a wideband and even though it has a 1v output on it I wouldn't recommend using that as your narrowband, unless you have dsmlink. Even then the aem sends it's information out a little slow. An innovate lc-2 would really be a better option for the car.
As for the bulbs, pull them from the car an see if there burnt out. Takes a few seconds to check.
138/2000
152/1000
Posts: 3658 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247834 posted 12/03/19 08:43 AM     Remind Me!  Send Private Message   Edit Post
I've never known bulbs to work and than not work. Especially both high and low beam. It sounds like you might have a electrical connection or ground issue. It's possible that the bulb connections themselves could be corroded.
Was the car always in Texas? Rust free?
1992 Nile black w/sunroof
Posts: 5954 | From: central Indiana | Member Since: 08/06/02 | IP: (142.79.57.1) | Report this post to a Moderator
Amanthius
Newbie
Galant VR-4 org Post #: 1247855 posted 12/06/19 02:13 PM     Remind Me!  Send Private Message   Edit Post
I figured it out. The connector to the headlamp relay in the engine bay was not supplying power to the actual relay. I had to bypass the connector to get power to the relay.
If your factory alarm goes off and your lights stop working.. then it may be your relay or relay connector in my case.
Posts: 18 | From: San Antonio, Texas | Member Since: 09/05/19 | IP: (2605:6000:1715:4) | Report this post to a Moderator
Galant VR-4 org Post #: 1247859 posted 12/06/19 03:27 PM     Remind Me!  Send Private Message   Edit Post
That's how you should troubleshoot electrical issues. Follow from the device backwards until you find voltage, or the other way until it stops.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10774 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Amanthius
Newbie
Galant VR-4 org Post #: 1247865 posted 12/07/19 03:28 AM     Remind Me!  Send Private Message   Edit Post
I am still learning but this is pretty neat. I had no idea there were tools to track down voltage.
Generated in 0.061 seconds in which 0.048 seconds were spent on a total of 14 queries. Turbo powered.
