Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Engine Vibration AFTER timing belt / water pump service - HELP!?!
E39Alfa
Newbie
Galant VR-4 org Post #: 1247722 posted 11/16/19 05:34 PM     Remind Me!  Send Private Message   Edit Post
Hello again VR4 community,
Need help figuring out what’s causing my VR4 to start to vibrate at around 4-5k RPM range?
This issue arise after timing belt / water pump service done at a local shop. Car drives fine under 4k rpm BUT starts to vibrate after that. I returned the car back to the shop and explained to him the issue. He took another 2 days with the car and still can’t figure out the source of the issue. He initially thought it might be the motor mounts, not the case.
Any advice or recommendations will greatly be appreciated.
Thanks in advance
88’ JDM RHD GVR4 = Current
93’ JDM RHD Mr2 Turbo = Current
TL-SH, G35s, IS300, Mx5 Turbo, TSX, TL-S, EVO8 = SOLD
Posts: 14 | From: frederick | Member Since: 09/11/19 | IP: (68.33.74.12) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247723 posted 11/16/19 06:46 PM     Remind Me!  Send Private Message   Edit Post
He probably did the balance shaft belt wrong. I've never had it happen, but the balance shafts can rotate with the belt off and be out of phase. I can't remember if the rear or the front likes to rotate with a belt off, but that is likely it.
I'm no longer using the balance shafts, so it's way easier to only line up the timing belt marks.
1992 Nile black w/sunroof
Posts: 5954 | From: central Indiana | Member Since: 08/06/02 | IP: (199.168.78.42) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247724 posted 11/16/19 06:48 PM     Remind Me!  Send Private Message   Edit Post
Step 21. click
E39Alfa
Newbie
Galant VR-4 org Post #: 1247725 posted 11/16/19 09:44 PM     Remind Me!  Send Private Message   Edit Post
Awesome! Thanks man.
I will print off this for the shop so they can fix the issue.
Posts: 14 | From: frederick | Member Since: 09/11/19 | IP: (2607:fb90:6039:f) | Report this post to a Moderator
Galant VR-4 org Post #: 1247728 posted 11/17/19 12:50 PM     Remind Me!  Send Private Message   Edit Post
They didn't know to set the balance shafts in the first place? If they don't take responsibility for this, I would certainly look for someone more qualified to do repairs in the future. Even then I'd probably still think twice about continued business with this mechanic.
Posts: 1490 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
Galant VR-4 org Post #: 1247729 posted 11/17/19 02:39 PM     Remind Me!  Send Private Message   Edit Post
This is how everybody heads blew up back in the mid 90s after their first timing belt jobs, not reading the manual, no one adjusted the timing tension pulley. I just wonder what yours is set at right now.
7 1G DSM's now a GGSX build.
Posts: 1490 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:2456:7) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1247894 posted 12/09/19 01:53 PM     Remind Me!  Send Private Message   Edit Post
the funny thing is, when you have this vibration, it's almost always the rear shaft (oil pump) not the front shaft that's out of phase, since that mark is so obvious.
Since the oil pump can be 360* out of phase, it can look lined up and still be totally wrong. Take the plug off and check it with a screwdriver per the vfaq. You can probably get the car on a stand, and check that with ~15 minutes of work.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3713 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (192.195.4.34) | Report this post to a Moderator
E39Alfa
Newbie
Galant VR-4 org Post #: 1247928 posted 12/14/19 06:43 PM     Remind Me!  Send Private Message   Edit Post
Shop made the necessary adjustments and vibration is now gone.
Only issue now is the car idle low at times after engine is warm...
CAS probably??
Posts: 14 | From: frederick | Member Since: 09/11/19 | IP: (2607:fb90:6420:7) | Report this post to a Moderator
Galant VR-4 org Post #: 1247933 posted 12/15/19 08:58 AM     Remind Me!  Send Private Message   Edit Post
With the car warmed up and the timing ground set you could try adjusting the idle set screw in the throttle body. Look at the manual for further details.
Posts: 1490 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:2451:a) | Report this post to a Moderator
andrew4g63
GVR4 have DSM stickers all over them, they are DSMs
1706/2000
Galant VR-4 org Post #: 1247943 posted 12/16/19 09:42 AM     Remind Me!  Send Private Message   Edit Post
Quoting E39Alfa:
CAS probably??
Low idle at times? or all the time?
Cam timing be off can cause low idle.
Did it have low idle before the timing belt job?
1706/2000 Hangs out in a corner of the garage
1702/2000 Daily Duties
1185/2000 wannabe rally car
46/1000 going back together
41/1000 Parts car
5/1000 Fixed-Sold!
Posts: 179 | From: Lake Geneva, WI | Member Since: 03/09/06 | IP: (2603:6000:a341:f) | Report this post to a Moderator
Generated in 0.077 seconds in which 0.06 seconds were spent on a total of 14 queries. Turbo powered.
