Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Random shutdowns
Random shutdowns
kdott96
733/2000
Galant VR-4 org Post #: 1247549 posted 10/21/19 12:08 PM     Remind Me!  Send Private Message   Edit Post
I keep getting random shutdowns with 733. It happens sometimes when in idle, sometimes when driving.. it's very random. When driving, I can feel the car slowing down and no matter how much gas I press, the speed drops on its own until it turns off (or if I put neutral and drop the clutch it goes straight to 0). It starts back up right away, but I want to get to the bottom of this.
This began happening after I switched to an Odyssey battery and was missing my lower intercooler pipe, but ever since then, I replaced that battery with a bigger one I previously had and found the ETS lower intercooler pipe. I would begin to see the battery/brake lights dim on from time to time so I knew my alternator was acting up and got one from Motorcity Reman had it installed Saturday so no more lights on the dash.. but the problem persists. I have also replaced the coolant temp sensor for a new OEM one but still no luck, Is there anything I can check next?
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
Posts: 54 | From: Queens, NYC | Member Since: 03/02/16 | IP: (2604:2000:a0c2:f) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247550 posted 10/21/19 12:13 PM     Remind Me!  Send Private Message   Edit Post
That's a tricky one....
I'd check and make sure the battery ground is clean where it connects. Near the stock air box location. I think the ECU has a ground too. One of the bolts that hold it in.
Check ECU....
It sounds like a connection issue, but with the age of these cars.... They can cause mysteries.
1992 Nile black w/sunroof
Posts: 5954 | From: central Indiana | Member Since: 08/06/02 | IP: (142.79.57.1) | Report this post to a Moderator
Galant VR-4 org Post #: 1247554 posted 10/21/19 05:13 PM     Remind Me!  Send Private Message   Edit Post
I had a TPS issue that would cause stalls, but never while driving. I would check for boost/air leaks in your intake system. Could be an air metering issue.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10774 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1247560 posted 10/22/19 12:58 PM     Remind Me!  Send Private Message   Edit Post
Take the ECU out, open it up and take a peek.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1646 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (2607:fb90:bc76:1) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1247562 posted 10/23/19 07:33 AM     Remind Me!  Send Private Message   Edit Post
im gonna have to third the idea of pull the ecu, sounds to me like you have a dead ISC motor and it burnt out your 102 or 105 diode, i forget what one it is.
138/2000
152/1000
Posts: 3658 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1247563 posted 10/23/19 08:18 AM     Remind Me!  Send Private Message   Edit Post
Make that a 4th. My ISC motor leaked into it's plug and took out the diode and the controller on the ECU. ECM Tuning fixed it right up
Thom
Posts: 897 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (99.41.236.89) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1247578 posted 10/24/19 06:13 PM     Remind Me!  Send Private Message   Edit Post
Pulled the ECU and I donít see anything extraordinary, am I overseeing anything?
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
Posts: 54 | From: Queens, NYC | Member Since: 03/02/16 | IP: (2607:fb90:7b4e:a) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1247579 posted 10/24/19 06:36 PM     Remind Me!  Send Private Message   Edit Post
Actually... Looking very closely at IC105 there is a vague orange part on the back Iíll hit up ecmlink tonight
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247594 posted 10/28/19 08:55 AM     Remind Me!  Send Private Message   Edit Post
Here is an example of a failed one.
Your's doesn't look like that. Did you have a idle surge problem at all?
kdott96
733/2000
Galant VR-4 org Post #: 1247640 posted 11/03/19 10:18 PM     Remind Me!  Send Private Message   Edit Post
No but idle ran high on cold startup no matter what
ECMtuning got back to me, could be just a failing MAP sensor
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
kdott96
733/2000
Galant VR-4 org Post #: 1247702 posted 11/14/19 09:53 PM     Remind Me!  Send Private Message   Edit Post
Dave from ECMLink said that my datalog suggested a failing map sensor reading.... and that was literally what it was. Changed the MAP sensor and car is running back again. Thanks for everybody that chipped in.
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
Posts: 54 | From: Queens, NYC | Member Since: 03/02/16 | IP: (2607:fb90:7ada:3) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1247706 posted 11/15/19 04:42 AM     Remind Me!  Send Private Message   Edit Post
What MAP sensor are you using?
Thom
kdott96
733/2000
Galant VR-4 org Post #: 1247707 posted 11/15/19 08:44 AM     Remind Me!  Send Private Message   Edit Post
Omni4bar
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
866/1000
Galant VR-4 org Post #: 1247708 posted 11/15/19 09:05 AM     Remind Me!  Send Private Message   Edit Post
Yea, they are pretty much crap. There is lots of info out there about them being problematic. Ine dies out of the blue, so I went with AEM
Thom
Posts: 897 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2600:1700:6c83:0) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1247710 posted 11/15/19 10:48 AM     Remind Me!  Send Private Message   Edit Post
Yes Iíve heard it too, just gave it another chance bc I feel like it was my fault that it broke (probably when said pipe was not on the car)
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
Posts: 54 | From: Queens, NYC | Member Since: 03/02/16 | IP: (2607:fb90:7a23:f) | Report this post to a Moderator
Generated in 0.07 seconds in which 0.053 seconds were spent on a total of 14 queries. Turbo powered.
