Galant VR-4 Forums » Galant VR-4 » Technical Discussions » ABS issues... after installing new coilovers
E39Alfa
Newbie
Galant VR-4 org Post #: 1247387 posted 10/02/19 12:12 PM     Remind Me!  Send Private Message   Edit Post
Hey guys,
I have a JDM RHD 88í GVR4...
Having issues with ABS being activated after installing new BC Racing coilovers.
Never had any issues before the install. No just driving around the neighborhood at no more than 25mph and using normal braking I can feel the ABS engaging on normal braking conditions.
I swapped out the front ABS sensor today hoping that would fix this issue but no resolve. I am also hear a weird sound from inside the cab like a pump being activated or something of that sort.
What should my next step be? ABS control module?
Where is the ABS control module located?
Any input about this issue will be appreciated.
Thanks in advance
Edited by toybreaker (10/03/19 07:43 AM)
Posts: 14 | From: frederick | Member Since: 09/11/19 | IP: (2601:147:4005:57) | Report this post to a Moderator
Galant VR-4 org Post #: 1247389 posted 10/02/19 01:54 PM     Remind Me!  Send Private Message   Edit Post
Is that all you changed? Everything else remained the same? No change to the sensor rings?
I would check the wiring and make sure the sensors are clean and adjusted properly. they need to be inserted to the proper depth and adjusted close enough to the sensor rings. Debris or misadjustment can affect them. Maybe you knocked or moves something during installation.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10774 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1247401 posted 10/03/19 06:34 AM     Remind Me!  Send Private Message   Edit Post
Personally I'd remove the abs. I never like them in these or the DSMs. It just always left something to desire I. The pedal. Lack of feeling the brakes maybe, but I do know an abs delete makes that pedal real nice. I also usually do a 3g eclipse master cylinder and brake booster upgrade at the same time.
138/2000
152/1000
Posts: 3658 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1247403 posted 10/03/19 06:39 AM     Remind Me!  Send Private Message   Edit Post
^^ I also usually do a 3g eclipse master cylinder and brake booster upgrade at the same time.
Is that a direct fit? I have brand new brakes on my car, and they still feel soft compared to a modern car. As in the amount of force I have to use. They will stop, but it just requires more foot work.
1992 Nile black w/sunroof
Posts: 5954 | From: central Indiana | Member Since: 08/06/02 | IP: (142.79.57.1) | Report this post to a Moderator
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 1247406 posted 10/03/19 07:19 AM     Remind Me!  Send Private Message   Edit Post
(sorry - short threadjack)
Not quite drop in. You'll have to modify the line routing and preferably, re-flare the ends with the correct bubble flare. There's been people that just cram the inverted flares in there and hope for the best. I'm good with hack jobs on some things but brakes aren't one of them
Easier way to do it is combine it with an ABS delete kit like JNZ has. Comes with correct flare adapters and braided lines cut to length.
Edited by Dan D (10/03/19 07:20 AM)
Posts: 1160 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (2601:805:c700:5b) | Report this post to a Moderator
E39Alfa
Newbie
Galant VR-4 org Post #: 1247407 posted 10/03/19 07:59 AM     Remind Me!  Send Private Message   Edit Post
I didnít change anything else during the coilover install.
I bought a used set of ABS sensor that came with the rings already installed and did the swap but not too sure about the correct depth they need to be at. I basically just bolted them back in place on the hub without any real depth specific measurement.
What are the install specs for these ABS sensors?
88í JDM RHD GVR4 = Current
93í JDM RHD Mr2 Turbo = Current
TL-SH, G35s, IS300, Mx5 Turbo, TSX, TL-S, EVO8 = SOLD
E39Alfa
Newbie
Galant VR-4 org Post #: 1247408 posted 10/03/19 08:01 AM     Remind Me!  Send Private Message   Edit Post
Iíve unplugged the ABS unit from the truck for the time being...
I might do that delete soon if I canít figure this thing out.
138/2000
152/1000
Galant VR-4 org Post #: 1247409 posted 10/03/19 08:02 AM     Remind Me!  Send Private Message   Edit Post
so what dan was saying, the flairs that go into the master are bubble, the inverted flairs need to be swapped with the flairs that come stock on the 3g. not hard to do, but i will say this, the first time i did this swap i did it as a drop in affair, not realizing i needed to change the flairs until someone pointed it out to me and the pedal worked, but not as well as i thought it should. after i made the correction to the flairs, braking was much tighter and kept the pedal high and firm. im not sure if it was the flairs or the re-bleeding of the brakes that made this happen, but once i did it things got better.
138/2000
152/1000
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1247413 posted 10/03/19 12:15 PM     Remind Me!  Send Private Message   Edit Post
you're definitely better off deleting it. With some fairly unscientific testing, i was getting ~15-20' longer stopping distances WITH ABS than without. It's ancient mid 80's two channel diagonal ABS, and unlike the new stuff that's basically magic, it really kind of sucks.Deleting it makes the car better, cleans up the engine bay, and sheds a bunch of weight. win/win/win.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3713 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (75.172.87.4) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1247417 posted 10/03/19 01:06 PM     Remind Me!  Send Private Message   Edit Post
it's actually a different system to the ABS fitted to the USDM and facelift JDM models - but I have no idea if it is better or worse. I feel it is worse. Having said that - the ABS in my '91 JDM functions well and I feel it improves braking distances had it not had ABS.
Posts: 2153 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (199.243.178.67) | Report this post to a Moderator
Galant VR-4 org Post #: 1247420 posted 10/03/19 03:11 PM     Remind Me!  Send Private Message   Edit Post
Quoting E39Alfa:
The "depth" of the sensor is important, but maybe didn't change if by rings you mean the mounting loops they fit in (they always rust in so I understand getting them with those brackets already attached). More important is the distance the sensor tip is from the hub ring. Those mounts are adjustable as you will see they can rotate around one of the mounting bolts until the other adjusting bolt is tightened. I can't recall the gap spec off the top of my head. It's in the service manual. That gap being too great will throw off the count all the time.
E39Alfa
Newbie
Galant VR-4 org Post #: 1247507 posted 10/14/19 08:41 AM     Remind Me!  Send Private Message   Edit Post
Update...
I seemed to have solve this issue by:
1. Realigning the sensor (to no specific spec) I just eye balled it to where itís close enough to where it wonít touch the hub
2. Disconnect and reconnect the ABS ECU in the trunk.
3. Disconnect and reconnect middle plug (of the three) under the hood next to PS pump.
Iíve been driving the car around for more than a week now and these steps seemed to have fix my issue with no more premature ABS being activated for normal braking and driving conditions.
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1247520 posted 10/15/19 09:56 PM     Remind Me!  Send Private Message   Edit Post
That is great news. I was following this post to hopefully here an update. Spot on Dave for catching this.
Posts: 1524 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (174.99.237.35) | Report this post to a Moderator
E39Alfa
Newbie
Galant VR-4 org Post #: 1247523 posted 10/17/19 06:30 AM     Remind Me!  Send Private Message   Edit Post
Thanks to everyone who chimed in on this issue, especially iceman!
E39Alfa
Newbie
Galant VR-4 org Post #: 1247524 posted 10/17/19 06:33 AM     Remind Me!  Send Private Message   Edit Post
Shout out to pot for for supplying me those ABS sensors, I probably didnít need them, but Iíll have extras for the future. Haha.
E39Alfa
Newbie
Galant VR-4 org Post #: 1247525 posted 10/17/19 06:42 AM     Remind Me!  Send Private Message   Edit Post
Thanks Pot and Iceman, between you guys recommendation to readjust the ABS sensors and to reset the ABS ECU, It seemed to have fixed my issue. So all the praise to you guys!
Generated in 0.084 seconds in which 0.053 seconds were spent on a total of 14 queries. Turbo powered.
