Clutch pedal assembaly.
gvr4ever
central Indiana
Are new parts still available?
Getting my car back up to par. Getting close, but the clutch grab is low. I think a ACT 2600 did the wear and tear. Currently running a centerforce. A lot lighter, but I still don't have enough play.
Sachse, Texas
The lever at the end of the clutch pedal assembly that wears out is no longer available, unless somebody on here has an unused one lying around. Other than that I think your only option is to have your lever welded. The good news is that it won't wear out again.
Cherry Hill, NJ
If your gonna weld it you need to get the brass bushings from JNZ, the stock bushings will melt if you try to woed with them in place.
