Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Cad file for camber plates?
Galant VR-4 org Post #: 1245712 posted 04/01/19 01:05 PM     Remind Me!  Send Private Message   Edit Post
Anyone have a file for cad to make camber caster plates? I found a company takes files and laser cuts part for a reasonable price.
Edited by tektic (04/01/19 01:06 PM)
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:6437:9) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1245714 posted 04/01/19 08:38 PM     Remind Me!  Send Private Message   Edit Post
I have ground control camber/caster plates on my 92 talon. They fit fine, might have to drill 1 hole to fit them. I get 5* of caster out of them
Posts: 57 | From: pagosa springs colorado | Member Since: 11/26/10 | IP: (71.211.8.161) | Report this post to a Moderator
Galant VR-4 org Post #: 1245756 posted 04/05/19 11:59 AM     Remind Me!  Send Private Message   Edit Post
So... CAD file anyone?
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.69.137) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1245921 posted 04/23/19 07:55 AM     Remind Me!  Send Private Message   Edit Post
I have some "domed" Tien plates I would donate for someone to use as a template, I only ask that I get a set in return. These could be flattened out and templated, I just don't trust using them as they are starting to crack.
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1245924 posted 04/23/19 07:00 PM     Remind Me!  Send Private Message   Edit Post
Yeesh. I take it you bottomed out the front a few times with those plates?
-Mark
1051
Posts: 11953 | From: Yakima, WA | Member Since: 04/29/01 | IP: (47.42.152.133) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1245925 posted 04/24/19 04:47 AM     Remind Me!  Send Private Message   Edit Post
I didn't, the PO of 148/1000 did. The AGXs these were used on were set to the lowest setting for the GC coil-overs. Needless to say, the struts were blown also.
Thom
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1245934 posted 04/24/19 01:37 PM     Remind Me!  Send Private Message   Edit Post
Ouch.
I am guessing that Tektic will take this on, but if not, I'd be interested in using them as a template to have some made.
Posts: 1219 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.242) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1245938 posted 04/24/19 04:04 PM     Remind Me!  Send Private Message   Edit Post
Either way works for me.
Thom
Whoodoo
buff guys = good time but my dream is to fondle 1051
62/2000
Galant VR-4 org Post #: 1245954 posted 04/27/19 11:19 AM     Remind Me!  Send Private Message   Edit Post
How quick do you want it? I've been thinking about putting together a set of custom coilovers using the K-sport camber plates I bought years ago. The problem is, they are currently installed and I'm not super motivated to get the project done right now. If nothing turns up, I'll model them up when I get them off.
62/2k
Posts: 924 | From: Binghamton, NY | Member Since: 07/11/09 | IP: (2600:1017:b01f:1) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1245960 posted 04/27/19 09:18 PM     Remind Me!  Send Private Message   Edit Post
How ever fast you can do it. I am not using them currently, since they have a crack and are domed. They could be flattened, but I dont want to send my struts through the hood.
Thom
AllanL
Heal and Toe
Galant VR-4 org Post #: 1245996 posted 05/04/19 09:22 AM     Remind Me!  Send Private Message   Edit Post
Lost the drawing so getting it redrawn...
Needs some time though...
Edited by AllanL (05/05/19 12:40 AM)
Posts: 268 | From: NV | Member Since: 08/05/08 | IP: (120.29.104.196) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1246002 posted 05/05/19 09:29 AM     Remind Me!  Send Private Message   Edit Post
I have dsm camber plates (the camber slots would need to be rotated 90 degrees for galants unless you want them to be caster plates) that I could donate to the cause.
Posts: 409 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1246016 posted 05/06/19 09:39 PM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
do you still need the CAD drawing?
Posts: 268 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1246018 posted 05/06/19 09:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
here's a draft...i'll send .pdf if you still need...
Galant VR-4 org Post #: 1246335 posted 06/09/19 11:26 AM     Remind Me!  Send Private Message   Edit Post
Quoting mooserage:
Ouch.
I have so many things going on right now... I'm out of service last 3 weeks with a concussion.
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
Galant VR-4 org Post #: 1246336 posted 06/09/19 11:28 AM     Remind Me!  Send Private Message   Edit Post
Thank you Allan. There's a link in the first post if you could could you send them the file and ask for a quote?
Edited by tektic (06/09/19 11:31 AM)
Galant VR-4 org Post #: 1247112 posted 09/03/19 04:58 PM     Remind Me!  Send Private Message   Edit Post
Working in solid works now, anyone have measurements for the hole spacing? I have a few designs I'm thinking up.
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:5456:f) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1247136 posted 09/06/19 02:18 AM     Remind Me!  Send Private Message   Edit Post
which holes?
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1247137 posted 09/06/19 06:35 AM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
Same. If someone gets me a drawing with dimensions I can model it and could 3D print you a prototype to test fit.
I love my crazy mother!!!
Posts: 1599 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1247140 posted 09/06/19 07:50 PM     Remind Me!  Send Private Message   Edit Post
you need the rear as well?
Edited by AllanL (09/06/19 07:52 PM)
Posts: 268 | From: NV | Member Since: 08/05/08 | IP: (120.29.104.68) | Report this post to a Moderator
Galant VR-4 org Post #: 1247150 posted 09/08/19 11:16 PM     Remind Me!  Send Private Message   Edit Post
Thank you again. I drew up a pretty decent camber/ caster plate. Does anyone know a good source for spherical bearing plates? The bottom plate with the cup a bearing gets pressed in to it.
I drew up a 5 piece system with off the shelf radial and spherical bearings. It would be easier to get made if I just needed to make the one plate though.
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1247151 posted 09/09/19 09:01 AM     Remind Me!  Send Private Message   Edit Post
The plate with the cup/bearing in it is going to be a custom made part. Either that or source one from a manufacturer that will sell just that and design your camber plate to be compatible with it.
866/1000
Galant VR-4 org Post #: 1247152 posted 09/09/19 10:53 AM     Remind Me!  Send Private Message   Edit Post
If TEIN still has them, they would be a good source. My plates were TEIN, they just got domes from the PO running at full drop and definitely bottoming the suspension out. We found evidence of it from the undercarriage,
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (99.41.236.89) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1247155 posted 09/09/19 08:15 PM     Remind Me!  Send Private Message   Edit Post
if anybody has tein or cusco bearing housings for any car, these are universal, I believe.
and will fit.
the drawing i provided for a 6g galant-specific cusco plate.
Galant VR-4 org Post #: 1247180 posted 09/11/19 01:23 PM     Remind Me!  Send Private Message   Edit Post
I've reached out to a few places for parts an most have just said no. Pretty lame. I guess I'll be looking to make some? I'll try Cusco first. Thanks.
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:2460:f) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 18 anonymous users are browsing this forum.
Rating: *
Generated in 0.159 seconds in which 0.104 seconds were spent on a total of 14 queries. Turbo powered.
