Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Caster adjustments
Caster adjustments
Galant VR-4 org Post #: 1242848 posted 06/07/18 10:59 AM     Remind Me!  Send Private Message   Edit Post
I'm wondering if anyone is using DSM camber plates for this purpose.
I'd like to get more castor as it seems this reduces the need for static camber while improving tire contact area throughout a turn.
I will be using evo struts and swift springs. Plan is to make shims to correct the positive camber associated with these struts with an upper camber bolt. Wondering what clearance issues I'll be dealing with.
Something like this
Would be awesome.
This is the BMW strut mount I measured.
Edited by tektic (06/14/18 11:17 AM)
Posts: 1410 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:245b:e) | Report this post to a Moderator
Galant VR-4 org Post #: 1243101 posted 06/24/18 02:46 PM     Remind Me!  Send Private Message   Edit Post
Finally got around to do more measuring and turns out these bolts are too close together for our chassis. Will be looking at other options.
Posts: 1410 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1243363 posted 07/16/18 10:05 AM     Remind Me!  Send Private Message   Edit Post
I use DSM camber plates for caster adjustment. I was able to get 4.2 deg of caster using them. I have a cambered upper bolt for the lower strut mounting to get my -2.5 deg of static camber. handles real nice.
Posts: 1278 | From: Beaverton | Member Since: 09/26/12 | IP: (73.96.102.244) | Report this post to a Moderator
Galant VR-4 org Post #: 1243418 posted 07/18/18 06:57 PM     Remind Me!  Send Private Message   Edit Post
Thanks. That's what I was looking for. Also what struts do you use?
Posts: 1410 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:24b7:7) | Report this post to a Moderator
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1243433 posted 07/19/18 02:37 PM     Remind Me!  Send Private Message   Edit Post
I just have D2 coilovers at the moment. much better options available but its what i had to work with at the time.
Generated in 0.162 seconds in which 0.151 seconds were spent on a total of 14 queries. Turbo powered.
