Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Is a JDM VR4 2.0 engine any better than a US one?
scottinalaska
676/1000
Galant VR-4 org Post #: 1242255 posted 04/10/18 05:11 PM     Remind Me!  Send Private Message   Edit Post
Since I blew mine up, , I was thinking about dropping in a 50K mile JDM one. It has this "Cool" "Cyclone" intake on it and all too! It comes with the ECM and transmission. So I was wondering if there was any advantage from the Jap market.
I realize the Jap ECU will request better octane, so I'll like be changing over to my sensors and basically just be using the long block anyway.
Thoughts?
Scott
Posts: 47 | From: Alaska, USA | Member Since: 11/15/16 | IP: (24.237.158.22) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1242256 posted 04/10/18 07:27 PM     Remind Me!  Send Private Message   Edit Post
If you have emissions requirements, the Cyclone intake does not have EGR provision, fwiw.
Posts: 9746 | From: ca | Member Since: 04/23/04 | IP: (2600:1012:b016:c) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1242259 posted 04/10/18 09:29 PM     Remind Me!  Send Private Message   Edit Post
Quoting scottinalaska:
Thoughts?
Scott
Do you know what year the JDM engine is? It could be an early model which has the same 450cc blue top injectors and TD05H-14B turbo that makes barely 10hp more than the USDM engine. Or it could be the later Evolution model with 510cc yellow top injectors and TD05H-big16G turbo that makes 240hp. Things like knock sensor, coolant temp sensor, oil pressure sensor etc are all going to be the same. Main difference is the JDM engine uses an air-to-oil oil cooler like the '90 DSM, and the inlet manifold needs the JDM ECU to control the Cyclone butterflies. You could of course just swap over your USDM inlet manifold and not have to worry about that. Pistons/compression ratios, cams, head castings etc are all the same between JDM and USDM.
Posts: 2098 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:fea8:4e0:b1) | Report this post to a Moderator
scottinalaska
676/1000
Galant VR-4 org Post #: 1242280 posted 04/12/18 01:45 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the insight there. Is there a visual way to tell the difference easily? Would yellow top injectors be a giveaway? or something on the turbo? These are just situated on pallets usually. When you say a "later Evolution" model, would this be post 1992? Meaning maybe I should be looking for an Evolution motor? Thanks!
Posts: 47 | From: Alaska, USA | Member Since: 11/15/16 | IP: (66.58.150.186) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1242282 posted 04/12/18 08:02 AM     Remind Me!  Send Private Message   Edit Post
Would be 91 and 92. Yes look at the injectors as well as the text on the intake manifold.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8869 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
scottinalaska
676/1000
Galant VR-4 org Post #: 1242292 posted 04/12/18 01:48 PM     Remind Me!  Send Private Message   Edit Post
So it sounds like really, if I found that rare Evo one or two engine, I am really only getting 4 bigger injectors and a better turbo. Everything else is the same. Am I correct?
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1242293 posted 04/12/18 01:52 PM     Remind Me!  Send Private Message   Edit Post
Not an EVO motor (those were 7-bolt and had different mounts (I believe). He is talking about the GVR4 Evolution, a model that Japan got with bigger injectors and a bigger turbo
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 798 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1242297 posted 04/12/18 04:34 PM     Remind Me!  Send Private Message   Edit Post
Quoting G:
Evolution VR-4 was released mid way through 1990 on the 5M/T models, the auto models still had the regular engine. Just to clarify - early engines have 'CYCLONE' while the Evolution engines have 'ECI-MULTI' (despite still using a cyclone type manifold). I believe the auto models post the mid '90 facelift also have 'ECI-MULTI' despite not having an Evolution spec motor.
Posts: 2098 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1242299 posted 04/12/18 06:28 PM     Remind Me!  Send Private Message   Edit Post
Yes, basically. If you ever plan to use larger injectors or a more modern turbo get whatever engine is cleanest and has the lowest mileage. IMO
-Mark
1051
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.4.116) | Report this post to a Moderator
0 registered and 24 anonymous users are browsing this forum.
Generated in 0.224 seconds in which 0.196 seconds were spent on a total of 14 queries. Turbo powered.
