Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Gas needle not reading full on full tank after replacing fuel pump.
4dr_vr4
Galant VR-4 org Post #: 1242176 posted 04/04/18 12:00 PM     Remind Me!  Send Private Message   Edit Post
It reads somewhere like 5/8 full on a full tank. I searched around here and noticed that I am not alone. It has been like this since I replaced the stock fuel pump with a Wally 190 about 3 years ago. I finally have a little bit more time on my hands and replaced the pump with a Wally 255 I had laying around in the hopes that the sender arm was bent and could be readjusted. Unfortunately that is not the case.
I have read posts where people just filled up the tank and then just pulled the dash needle and set it back down at the full mark.
The question is whether or not the tank will remain accurate throughout it's range by doing this. I certainly don't want to buy another used sender for something like this especially since going in there is a pain in the ass at many levels.
Thanks.
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (2601:5cb:c080:57) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1242189 posted 04/05/18 03:10 PM     Remind Me!  Send Private Message   Edit Post
You bent the shit out of the float rod getting the sending unit out. Pull it again and fix it.
I love my crazy mother!!!
Posts: 1542 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1242191 posted 04/05/18 09:12 PM     Remind Me!  Send Private Message   Edit Post
The float arm isn't bent at all though.
"Just to be pedantic!"
Galant VR-4 org Post #: 1242196 posted 04/06/18 07:56 AM     Remind Me!  Send Private Message   Edit Post
Is there something stopping the full movement of travel of the arm? Pull the sender and move the arm to the top as if the tank were full - is it hitting on the pump assembly or does it have a stiff spot on the potentiometer? I would just try fit in another sender and see what the result is.
Posts: 2098 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:fea8:4e0:b1) | Report this post to a Moderator
Galant VR-4 org Post #: 1242197 posted 04/06/18 08:31 AM     Remind Me!  Send Private Message   Edit Post
Quoting 4dr_vr4:
Are you possibly not clocking it correctly with the reinstallation? If it hits the fuel cup in the tank it may not move enough.
I would check it for full stroke out like Fuel mentions.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10601 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1242206 posted 04/06/18 06:38 PM     Remind Me!  Send Private Message   Edit Post
Every galant I've had so far has never read full when full. Even 100% stock. Well, not 5/8's but maybe 7/8-9/10
Ryan W.
Edited by turbofonz (04/06/18 06:39 PM)
Posts: 438 | From: Granby, MA | Member Since: 09/27/06 | IP: (73.238.136.246) | Report this post to a Moderator
Galant VR-4 org Post #: 1242209 posted 04/06/18 09:25 PM     Remind Me!  Send Private Message   Edit Post
Mine reads just a smidgen over full when it is full, but it lasts for about 5-10 miles before it starts going under full. Top half goes quickly and then hovers around the half way point for a while, then drains the last 1/3 quickly.
4dr_vr4
Galant VR-4 org Post #: 1242548 posted 05/12/18 12:20 PM     Remind Me!  Send Private Message   Edit Post
Thanks everyone. I am clocking it correctly. I just replaced the wally 190lph with a 255lph and no change unfortunately after reinstallation. I guess I'll just live with it.
Edited by 4dr_vr4 (05/12/18 12:31 PM)
Eager Beaver
Galant VR-4 org Post #: 1242680 posted 05/23/18 09:19 PM     Remind Me!  Send Private Message   Edit Post
What the guys posted above can all be spot on, so take this as a secondary consideration.
In the FSM there should be resistance values listed for the sensor and it's range of travel. Remove the level sensor and measure it at full = mid = empty travel and see how they compare to spec. You may have a bent arm or something silly keeping it from operating properly.
In the Colts, this sensor is the only fuel related component that can come through the floor beneath the rear seat, as the pump is below the floor panel unless you make a removable top section and seal it from the environment.
Anywho, try what I mentioned. They are not expensive, even new from Mitsubishi IIRC.
C53A 1 of the ~1500
Edited by FlyingEagle (05/23/18 09:21 PM)
Posts: 1586 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.132) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1243214 posted 07/04/18 01:33 PM     Remind Me!  Send Private Message   Edit Post
Thanks, will check the resistance values. I think that is all that is left. Arm sits exactly where it should.
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.65) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.214 seconds in which 0.19 seconds were spent on a total of 14 queries. Turbo powered.
