Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Auto harness swap - fuse box confusion
boostme
Galant VR-4 org Post #: 1242025 posted 03/21/18 01:26 AM     Remind Me!  Send Private Message   Edit Post
The GVR4 engine harness is out. But I am confused on the part where the GVR4 has a 2nd harness where the fuse box goes. The 1G auto harness does not have a connector
I tried searching but some lead to dead links and don't mention that part.
I'm keeping A/C so I want that functional as stock as possible ( reason I'm not hardwiring)
I can't attach a picture but what do I do from here?
Posts: 28 | From: Crete, IL | Member Since: 10/04/13 | IP: (2601:244:4401:13) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1242026 posted 03/21/18 06:09 AM     Remind Me!  Send Private Message   Edit Post
That harness is separate. You may need to make the necessary power connections for the auto harness
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 798 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
boostme
Galant VR-4 org Post #: 1242028 posted 03/21/18 04:37 PM     Remind Me!  Send Private Message   Edit Post
Rereading the threads now I understand... so now it's just a matter of soldering them together?
I e never removed a harness so I had no idea what to expect.
Posts: 28 | From: Crete, IL | Member Since: 10/04/13 | IP: (2607:fb90:a2b5:8) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1242029 posted 03/21/18 06:08 PM     Remind Me!  Send Private Message   Edit Post
If you are planning on using a TCU. When we auto-swapped a DMS, we just went with a Forced-4 box. Much more reliable.
Thom
Posts: 798 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c402:59) | Report this post to a Moderator
boostme
Galant VR-4 org Post #: 1242044 posted 03/22/18 10:47 AM     Remind Me!  Send Private Message   Edit Post
Well for now I wanted to use a TCU but if it is easier to just wire in a shift box, then I'll go that route.
So then I can reinstall the GVR4 harness or proceed to solder in the 1G harness?
Posts: 28 | From: Crete, IL | Member Since: 10/04/13 | IP: (2607:fb90:a30b:1) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1242045 posted 03/22/18 11:12 AM     Remind Me!  Send Private Message   Edit Post
You will probably still want the 1g harness. It will make it easier wiring up the solenoids and such. I have a write-up I did for installing the box in a swapped auto Summit/Colt Vista/Expo Wagon (aka Mitsubishi Chariot), but it still might be some help to you.
Thom
boostme
Galant VR-4 org Post #: 1242050 posted 03/22/18 03:17 PM     Remind Me!  Send Private Message   Edit Post
Do you have a link to your work?
Do you suggest cutting off the plugs from the auto harness and wiring it that way?
Maybe I'm over complicating things but its obvious wiring isn't my strong point.
Thank you
866/1000
Galant VR-4 org Post #: 1242057 posted 03/22/18 06:18 PM     Remind Me!  Send Private Message   Edit Post
I can email the PDF to you, just give me an email address
Thom
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.204 seconds in which 0.19 seconds were spent on a total of 14 queries. Turbo powered.
