Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Thoughts on windage tray
Galant VR-4 org Post #: 1241921 posted 03/10/18 09:22 PM     Remind Me!  Send Private Message   Edit Post
I'm building a rwd 4g63 and am already adding baffles to the rwd oil pan.
I was considering the addition of a windage tray or crank scrapper. In the case if the windage screen it would most likely be a slightly convexed 20 gauge screen attached by bolts welded to the inside of the pan so I could adjust the distance from the crank and also remove it if need be.
Have others here made either screens or scrapers for their 4g63?
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (98.7.27.255) | Report this post to a Moderator
dime2nr
Member ++
905/2000
Galant VR-4 org Post #: 1241932 posted 03/11/18 08:50 PM     Remind Me!  Send Private Message   Edit Post
Posts: 639 | From: Portland OR | Member Since: 09/01/04 | IP: (2600:1:971a:cee3) | Report this post to a Moderator
Galant VR-4 org Post #: 1241983 posted 03/15/18 07:37 PM     Remind Me!  Send Private Message   Edit Post
Seen this but don't like the idea of using the main bolts. I'm probably going to make one out of aluminum that bolts to the oil pan ring. Then weld an arched mesh windage tray over the top. I'll post when done.
Edited by tektic (03/17/18 10:58 AM)
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.86.154) | Report this post to a Moderator
bazeng
work in progress
Galant VR-4 org Post #: 1242014 posted 03/19/18 08:10 AM     Remind Me!  Send Private Message   Edit Post
Make a girdle and attach it on that. Or use a kiggly one and attach accordingly?
This is my work in progress.
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (220.237.97.252) | Report this post to a Moderator
Galant VR-4 org Post #: 1242019 posted 03/20/18 12:02 PM     Remind Me!  Send Private Message   Edit Post
wow. thats impressive.
I Ordered a crank scraper from click last night. Talked with him for over an hour. Real nice guy and very knowledgeable.
Going to do something like an evo9 windage tray attached to the pan I think
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
Generated in 0.228 seconds in which 0.216 seconds were spent on a total of 14 queries. Turbo powered.
