Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Have to turn the key about 50 times to start the car sometimes.
4dr_vr4
Galant VR-4 org Post #: 1241495 posted 02/03/18 03:57 PM     Remind Me!  Send Private Message   Edit Post
About 40% of the time, I have to keep on turning the key to start the vehicle. I don't hear the starter relay clicking. I do hear something that sounds like a wave sloshing around from the front of the car when this is happening.
I have never been stranded due to this and it has been going on for about the last 3 years.
I have not acted sooner since the vehicle is always down for one reason or another. I have used several different batteries, new battery terminals, and have swapped the ECU out....none of this was done to troubleshoot this but rather for other reasons over time.
Thanks for any help!
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.9) | Report this post to a Moderator
Galant VR-4 org Post #: 1241500 posted 02/03/18 09:51 PM     Remind Me!  Send Private Message   Edit Post
Ignition switch? Starter itself (worn contacts)? It eventually always starts?
Could even be a battery cable that is corroded internally and has trouble passing the current. Had this on my Volvo decades ago.
Not sure what the wave sound might be...
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10617 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1241510 posted 02/04/18 06:11 PM     Remind Me!  Send Private Message   Edit Post
Lol! Thanks for the help. Gives me a few ideas to go on. Ignition switch. Will a 1g ignition switch work? I have a few 1g's laying around that I can try but in the end don't I need to use a different key?
...and yep eventually always starts.
Edited by 4dr_vr4 (02/04/18 06:12 PM)
Galant VR-4 org Post #: 1241512 posted 02/04/18 09:48 PM     Remind Me!  Send Private Message   Edit Post
The key cylinder is removable so you can keep the same key. I think 1g parts should be interchangeable as they were made by Tokai Rika. The switch part with the contacts is attached to the back and I think you can change that separately too.
AllanL
Heal and Toe
Galant VR-4 org Post #: 1241514 posted 02/05/18 06:20 AM     Remind Me!  Send Private Message   Edit Post
starter may need to be cleaned or the solenoid replaced.
sloshing may be the solenoid just turning...
Posts: 243 | From: NV | Member Since: 08/05/08 | IP: (111.125.109.47) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1241529 posted 02/07/18 12:54 PM     Remind Me!  Send Private Message   Edit Post
I struggled with this for quite a while. I finally found that if i supplied 12v directly to the solenoid signal wire from under the hood, it would crank every time.
I wound up putting a relay under the hood for this wire. Ignition sends a signal to the relay now, which closes the circuit to a battery post. No more issues.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.86.44) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1241570 posted 02/09/18 07:19 PM     Remind Me!  Send Private Message   Edit Post
Thanks for all of the info and likely fixes!
Generated in 0.289 seconds in which 0.271 seconds were spent on a total of 14 queries. Turbo powered.
