Galant VR-4 Forums » Galant VR-4 » Technical Discussions » What ECU for EVO8 rom
Galant_martin
Galant VR-4 org Post #: 1240971 posted 12/15/17 06:25 AM     Remind Me!  Send Private Message   Edit Post
Hello
i want to ask if anyone know what ecu i can use for an "evo8 ecu swap". Must it be an Evo 8 ECU like the MN132874 or can it be another one used too?
Like these i found cheap on ebay:
MN156916 04 Lancer Manual
MR988331 03 Lancer LS
MN132618
Thank you all
Martin
Edited by Galant_martin (12/15/17 06:36 AM)
Posts: 31 | From: Austria | Member Since: 10/21/13 | IP: (194.96.157.193) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1240972 posted 12/15/17 07:41 AM     Remind Me!  Send Private Message   Edit Post
Must be an Evo ECU - I believe one from an Evo 5/6/7 will be fine too. You can't use the Evo 9 due to MIVEC.
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:fea8:4e0:b1) | Report this post to a Moderator
Galant VR-4 org Post #: 1240989 posted 12/16/17 08:29 AM     Remind Me!  Send Private Message   Edit Post
There's a list of programmable ecus on the evo scan website. 3g manual eclipse works and some year manual lancers work.
Posts: 1410 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.127.157) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1240991 posted 12/16/17 11:53 AM     Remind Me!  Send Private Message   Edit Post
i actually just had a recent conversation with someone about this. im very excited to try it myself. i was told a 3G eclipse does work, he has actually done the conversion, and can be had for $30-40, build the harness yourself for a few bucks and EVOScan.. I plan on doing this for the 1G DSM i just recently bought. going to tuck a 3G MAF into the 1G canister for it.
138/2000
Posts: 3527 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Galant_martin
Galant VR-4 org Post #: 1240999 posted 12/17/17 12:58 AM     Remind Me!  Send Private Message   Edit Post
Ok thank you for ur help, i finally got an 1860A118 from an evo. =)
I also built an adapter cable already.
Do i still need the resistorpack in the loom for the injectors?
Greetings
AllanL
Heal and Toe
Galant VR-4 org Post #: 1241047 posted 12/20/17 08:55 PM     Remind Me!  Send Private Message   Edit Post
you will still need it.
Posts: 249 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
Galant_martin
Galant VR-4 org Post #: 1241134 posted 12/27/17 03:52 AM     Remind Me!  Send Private Message   Edit Post
Ok thank you !
Eztoril
1450/2000
Galant VR-4 org Post #: 1241136 posted 12/27/17 03:58 AM     Remind Me!  Send Private Message   Edit Post
I'm in the middle of doing this using a 2005 evo8 ecu. Will report back once it starts and fires up.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (12/27/17 04:00 AM)
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (174.67.213.203) | Report this post to a Moderator
Galant_martin
Galant VR-4 org Post #: 1241157 posted 12/29/17 02:33 AM     Remind Me!  Send Private Message   Edit Post
Okay, im still waiting for the 1.3U cable and the knocksensor...
Galant_martin
Galant VR-4 org Post #: 1241850 posted 03/04/18 04:30 AM     Remind Me!  Send Private Message   Edit Post
So its going on..
But i have a problem. Ecu throws codes:
P0183 Fuel Tank temp
P0340 no camshaft signal at EFI ECU
P0335 no crankshaft reference Signal at EFI ECU
I checked the connector under the hood, 2 wires go to the ecu Pin 88/89, 2 have +12V.
Car starts without problems, it holds idle with my feet (no ISC) ..
Any ideas?
EDIT
if i unplug the cas the car wont start
Edited by Galant_martin (03/04/18 06:43 AM)
Posts: 31 | From: Austria | Member Since: 10/21/13 | IP: (213.225.15.127) | Report this post to a Moderator
1 registered and 20 anonymous users are browsing this forum.
Generated in 0.119 seconds in which 0.103 seconds were spent on a total of 14 queries. Turbo powered.
