Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 25mm offset
25mm offset
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1240301 posted 11/02/17 07:20 AM     Remind Me!  Send Private Message   Edit Post
Is anyone running a 25mm offset? If so what diameter wheel and do you have any pics?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8859 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 1240318 posted 11/02/17 03:40 PM     Remind Me!  Send Private Message   Edit Post
I think 25mm is too much, no? I am running evo8 which is 38mm and with 245 tires, it would sometimes rub the front struts. On my eclipse I ran racing hart with 32mm offset and no rub, but does stick out a little.
3"K&N, B16g, 2.5pipe, Synapse DV, ETS Frntmnt, FP4r, ZFG Long Block, 2g mani, evo3o2/5th, 3"exst,fic1100cc/walbro,
6an, poly mnts, DEL-abs/ps/4ws/egr/evp, Jack's tran, SB-clutch, evo8 whls-245/45/17/springs, 3kvr4 brakes, Koni, 4bolt rear,
ds-map, ntk.
Posts: 810 | From: Denver, CO | Member Since: 03/06/01 | IP: (2601:283:4000:4b) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1240322 posted 11/02/17 07:33 PM     Remind Me!  Send Private Message   Edit Post
That's what I was thinking.
www.nostalgic.co.jp
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1240325 posted 11/03/17 12:27 AM     Remind Me!  Send Private Message   Edit Post
You'll need a bit of stretch and negative camber to tuck it under the fender. Although I'm not a fan of tire stretch, minimal amounts to fit a deeper lipped wheel can look good. I think BobDole's car runs a 25 offset and looks pretty sweet.
-Mark
1051
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.4.116) | Report this post to a Moderator
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 1240402 posted 11/07/17 05:41 PM     Remind Me!  Send Private Message   Edit Post
I'm running 12mm offset. But there is no tucking the tire inside the fender.
816 of 1000
[email protected]
??? of 2000
[email protected] on 93oct
[email protected] on C16
[email protected] on E90
ASE Certified Master Technician
www.Performance-Alignment.com
Posts: 396 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (2605:a000:c64f:9) | Report this post to a Moderator
Generated in 0.213 seconds in which 0.203 seconds were spent on a total of 14 queries. Turbo powered.
