Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Lights Flickering
Lights Flickering
Defiant
Definitely? Defiantly? wat
136/1000
Galant VR-4 org Post #: 1240074 posted 10/23/17 01:18 PM     Remind Me!  Send Private Message   Edit Post
So I've noticed my dash lights flickering when the blinker is on.
When I try to roll the window up/down, they dim until I release the button.
Has anyone had a similar issue, and if so what did you do to resolve it.
136/1000
Posts: 164 | From: Houston, TX | Member Since: 09/07/12 | IP: (204.58.246.49) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1240076 posted 10/23/17 01:28 PM     Remind Me!  Send Private Message   Edit Post
i have had two similar experiences, 1 was fixed by replacing the alternator, it checked good at oreilly, but i wasn't satisfied with there evaluation. i replaced it with an old OEM unit and problem fixed. the second time it was one of the fuses under the hood. i forget what one, but it causes the dash lights and tail lights to not operate. your problem could not be relate at all to what i had happen, but its a start.
138/2000
Posts: 3451 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Galant VR-4 org Post #: 1240077 posted 10/23/17 01:55 PM     Remind Me!  Send Private Message   Edit Post
Could also be a ground issue.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1240078 posted 10/23/17 02:10 PM     Remind Me!  Send Private Message   Edit Post
Would definitely look at all the grounds. Someone on here created a kit, but you can do it yourself. You most likely have the original grounds. 25 years of work and those grounds are way inefficient.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
1992 GVR-4 148/1000. Rescue
Posts: 761 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (68.45.230.24) | Report this post to a Moderator
Defiant
136/1000
Galant VR-4 org Post #: 1240079 posted 10/23/17 02:13 PM     Remind Me!  Send Private Message   Edit Post
Marvinmadman installed multiple ground wires using 8ga wire, so I think the grounding is good.
I can take pics tonight for reference.
136/1000
Galant VR-4 org Post #: 1240082 posted 10/23/17 02:39 PM     Remind Me!  Send Private Message   Edit Post
If those are underhood, that does not mean the grounds under the dash or in the doors are good...
0 registered and 52 anonymous users are browsing this forum.
Generated in 0.194 seconds in which 0.183 seconds were spent on a total of 14 queries. Turbo powered.
