Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Opinion wanted: Do I need a new clutch? (pics)
abikepeddler
1607/2000
Galant VR-4 org Post #: 1238462 posted 07/10/17 07:40 PM     Remind Me!  Send Private Message   Edit Post
I'm such a sic pup... A cracked bell housing has ended up leading me to not only fix that issue but to basically tear the entire car apart and fix EVERYTHING. So basically I have torn #1607 apart. Just pulled out the clutch and wanted an opinion if I should replace it. I'm guessing the answer will be yes but just wanted verification from those of you that are far wiser than I. Clutch does not slip when I drive the car but the disc is looking a bit thin and the flywheel is pretty glazed. Also on a side note does the starter backing plate normally have some bend in it or it supposed to be dead flat? Mine has some subtle undulations that look Factory. Thanks for any input... I want to take care of crap while I have everything apart.
Posts: 34 | From: San Diego, CA | Member Since: 08/11/16 | IP: (76.176.121.25) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1238465 posted 07/10/17 08:26 PM     Remind Me!  Send Private Message   Edit Post
That clutch and flywheel look okay to me, just a bit dirty, but no real bad heat spots or chatter marks and the meat on the disc looks okay.
It's a big job to take the tranny out though so if your thinking about turning up the boost at any point in the future I would replace/upgrade it and get the flywheel machined at the same time.
It's your call though and totally depends on your plans for the car.
IIRC my starter plate was dead flat, no bends or kinks like yours.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) | Report this post to a Moderator
Galant VR-4 org Post #: 1238470 posted 07/11/17 07:21 AM     Remind Me!  Send Private Message   Edit Post
That starter plate has been tweaked by the movement from your broken block. Certainly fixable or usable straightened.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10532 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1238472 posted 07/11/17 08:41 AM     Remind Me!  Send Private Message   Edit Post
First, check the step height on the flywheel and ensure it's in spec.
Regarding the clutch, personally, I'd replace the clutch while the trans is out. But, I hate pulling the transmission. The one pictured looks like a stocker to me, which are fairly cheap. Even if the disc looks good (and it does) I'd still replace it. The problem with those discs is the springs pop out, which will leave you with a clutch that won't disengage. If you look at your disc, it looks like those damper springs have already taken an impact or two. If I were you I'd throw a whole new clutch assembly in, but replace the disc itself at a minimum.
Look familiar? click
Posts: 3344 | From: SoCal | Member Since: 01/02/12 | IP: (214.4.253.121) | Report this post to a Moderator
abikepeddler
1607/2000
Galant VR-4 org Post #: 1238485 posted 07/11/17 03:06 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
Agreed. Not only did the engines cast iron transmission mounting tab break off (where one of the pins passes through the starter backing plate) but the bell housing itself had a 14 inch crack in it. diambo4life saved me by offering up a new bell housing and I was able to weld up the engine block tab cleanly but the starter plate does not line up anymore with where the pins on the block are located. I am certain that the pins are in proper alignment so the backing plate itself is actually spread out from the forces involved (as you stated) with the broken engine block and movement of the cracked bell housing. I ordered up a new starter backing plate for JNZ.
abikepeddler
1607/2000
Galant VR-4 org Post #: 1238488 posted 07/11/17 03:47 PM     Remind Me!  Send Private Message   Edit Post
Thanks everyone for your input. A new clutch it is... So I read and read for hours about all the clutch options. I have only a mildly modded car... prob around 240hp... maybe someday might turn that up to 300 but not likely to bump above that. So from all the reading I did on this forum Centerforce and Southbend seem the have the least bad to say about them for DD use. So that is the direction I am leaning. The option of using a Kevlar disc is tempting.
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1238505 posted 07/12/17 01:28 PM     Remind Me!  Send Private Message   Edit Post
I love my south bend clutch. I contacted tmzperformance with my goals and how it was going to be driven. 400lb/ft was my goal, but I have changed my mind and I still love the clutch I have for stock power. It feels like a stock clutch too. I went with the recommended SS series pressure plate with TZ/B Kevlar/Ceramic dual friction disk.
For a great daily driver/autox setup in a galant vr4, the SS series pressure plate with TZ/B Kevlar/Ceramic dual friction disk will be the best option on a factory flywheel or a chromoly steel flywheel. If you are running a fidanza flywheel, the full ceramic B series disk is the best choice (same price as the TZ/B disk).
I had a SS/TZ/B in my galant around the same power levels and it drove like a stock clutch and was extremely streetable while still handling autox duties. At a 1/4mi track the full ceramic disk was a better option due to the vehicle weight as it would glaze the Kevlar material otherwise.
Edited by idreamidrive (07/12/17 01:30 PM)
Posts: 341 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
abikepeddler
1607/2000
Galant VR-4 org Post #: 1238696 posted 07/23/17 10:46 PM     Remind Me!  Send Private Message   Edit Post
To update this tread: So I ended up buying a brand new starter plate because the one that was tweaked was not really saveable. (The transmission bolt holes in starter plate would not line up with transmission.)
I decided to try the Centerforce Dual Friction clutch in the car but before I do wanted to make absolutely certain I buy the correct part. Is this the correct part number?: Centerforce Dual Friction DF536010
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1238698 posted 07/24/17 06:06 AM     Remind Me!  Send Private Message   Edit Post
Same clutch on Extreme PSI for $30 less. Yes, correct clutch.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
Posts: 739 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
abikepeddler
1607/2000
Galant VR-4 org Post #: 1238710 posted 07/24/17 02:20 PM     Remind Me!  Send Private Message   Edit Post
Cool, thanks thomcasey...
ABP
Banthony
555/1000
Galant VR-4 org Post #: 1238726 posted 07/25/17 08:52 AM     Remind Me!  Send Private Message   Edit Post
If you welded the tab back onto the block, i don't expect it will hang on for very long. I tried this one one myself. The welds on cast iron just generally will not hold, at least not in that area.
What i wound up doing was welding a 1/8# thick chunk of steel to the mount bracket that bolts to the block, then drilled a hole to line up with the transmission bolt hole, used a longer bolt, and filled the gap with a spacer and a washer. Worked fine for years after that.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3511 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.88.86) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1238747 posted 07/27/17 06:18 AM     Remind Me!  Send Private Message   Edit Post
That is exactly what I suggested to him since my old Talon broke off one of those mounting tabs. I bought a mount bracket that had been modified as described and it worked perfectly for years. This was on a mid 10sec car too and the car that had it previously was a low 9sec car. So it is a good piece of backwoods engineering.
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 234 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (108.171.131.164) | Report this post to a Moderator
Galant VR-4 org Post #: 1238751 posted 07/27/17 08:07 AM     Remind Me!  Send Private Message   Edit Post
I wish I had known about/thought of this back when mine re-broke in 2014. Would have saved lots of time/money not having to change the short block!
2 registered and 11 anonymous users are browsing this forum.
Generated in 0.257 seconds in which 0.214 seconds were spent on a total of 14 queries. Turbo powered.
