Galant VR-4 Forums » Galant VR-4 » Technical Discussions » electric rear LSD's?
boboz
Newbie
Galant VR-4 org Post #: 1238399 posted 07/07/17 12:56 AM     Remind Me!  Send Private Message   Edit Post
Hi Guys,
do you see these ever anymore?
I'm looking for an external selectable locking or semi-locking rear diff (not a constantly engaged LSD)
see last diff option (EMCD) on link below:
click,202249,202250/
Posts: 6 | From: bne qld aus | Member Since: 07/07/17 | IP: (113.52.2.140) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1238401 posted 07/07/17 09:09 AM     Remind Me!  Send Private Message   Edit Post
These are for the 7th generation E74A/E84A Galant VR-4 with the 6A12 twin turbo V6. The electronic rear diff was on the 4A/T models with traction control only. I don't think it would be compatible with our 6th generation cars. It definitely wont work with the 4WS pump.
Posts: 2042 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
boboz
Newbie
Galant VR-4 org Post #: 1238459 posted 07/10/17 04:14 PM     Remind Me!  Send Private Message   Edit Post
How do they work?
are they an open diff with an electric-select LSD option?
I've tried to find the relevant workshop manual but there's nothing other than the EA series out there.
Galant VR-4 org Post #: 1238460 posted 07/10/17 04:31 PM     Remind Me!  Send Private Message   Edit Post
Not 100% sure how they work, but it looks like they are usually open and when the ECU detects slip (it is only offered on the Auto models with traction control/trace control) it will send power (perhaps modulated) to the solenoid in the diff which locks the center together.
Being an auto, the ratio will be 3.307 and not the 3.545 or 3.909 the E39A uses.
The chances of finding one is incredibly slim - it also costs about US$3000 to buy new from Mitsubishi. Basically, forget about it.
Edited by fuel (07/10/17 04:32 PM)
boboz
Newbie
Galant VR-4 org Post #: 1238464 posted 07/10/17 08:09 PM     Remind Me!  Send Private Message   Edit Post
yeah - i'm thinking that.
I've been looking for an externally selectable locker i.e. button press activated like an air or electric locker. doesn't have to be solid lock either and this appeared to be the only option out there as everything else is a constant LSD or torsen style locker that is constantly engaged.
Galant VR-4 org Post #: 1238473 posted 07/11/17 08:45 AM     Remind Me!  Send Private Message   Edit Post
What's wrong with the regular plate type LSD?
boboz
Newbie
Galant VR-4 org Post #: 1238489 posted 07/11/17 04:08 PM     Remind Me!  Send Private Message   Edit Post
It's going in the front of a pajero io - we share the same diff centers (your rear is our front)
There are loads of cheap Detroit style lockers available but if you're driving in the rain or on ice in AWD mode the resistance of an lsd or detroit causes the steering to be quite odd and cross loads resulting in bad under-steer.
I'm looking for a center that can be externally activated from an open normal diff to a locked or semi-locked diff that I can tie into my center differential and rear differential locks for low-range heavy duty off road. there are no air-actuated or electric lockers on the market for a center so small.
Galant VR-4 org Post #: 1238497 posted 07/12/17 08:52 AM     Remind Me!  Send Private Message   Edit Post
I see! Had no idea that the iO used the same center as the E39A - technically the Evo1-10 (without AYC) will have the same center.
I don't think you'll have much luck finding an externally activated locker within our community I'm afraid - most of us go for the Evo plate type LSD or the viscous LSD.
What ratio is the front diff on the iO?
boboz
Newbie
Galant VR-4 org Post #: 1238507 posted 07/12/17 04:20 PM     Remind Me!  Send Private Message   Edit Post
Hi, the front ratio is not much good for you, it's 4.875, it's in a semi-beam axle with short driveshafts out the sides, the passengers side has a driveshaft disconnect to allow the passenger CV to disconnect from the diff for 2wd opperation. 5.86 is possible with Hyundai Terecan front centers (225/75-16 tyres needs a low ratio)
So the Evo 1-10 without the active yaw control will be a plate LSD style - but no other mitsi's have that electric solenoid aside from that eterna e84a
Galant VR-4 org Post #: 1238509 posted 07/12/17 07:49 PM     Remind Me!  Send Private Message   Edit Post
^^ correct - only the E84A Galant VR-4/Eterna XX-4 have the electric rear locker. JDM market only, and finding used these days would be a big ask.
Posts: 2042 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (99.230.38.189) | Report this post to a Moderator
Generated in 0.222 seconds in which 0.2 seconds were spent on a total of 14 queries. Turbo powered.
