Galant VR-4 Forums » Galant VR-4 » Technical Discussions » No start with new motor and dsmlink
smallblock12
Newbie
738/1000
Galant VR-4 org Post #: 1238075 posted 06/17/17 05:53 PM     Remind Me!  Send Private Message   Edit Post
2.4 with a 20g 1150 injectors 3 inch blow thru mas cop setup and dsmlink. Cant get to start. Wired in wideband and primary. Could having the wrong temp sensors effect it or ha I g the wideband as primary?
95 awd 2.4 talon R.i.p
91 gvr-4 sold
92 gvr-4 2.4 20g
Posts: 22 | From: cincinnati, ohio | Member Since: 07/02/12 | IP: (2607:fb90:6110:f) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1238076 posted 06/17/17 05:57 PM     Remind Me!  Send Private Message   Edit Post
There's fuel, compression and spark. What one dont you have..
138/2000
Posts: 3411 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1238081 posted 06/17/17 07:33 PM     Remind Me!  Send Private Message   Edit Post
I had a no start issue the other day with my new build. Ended up being two of my 10 month old FIC 1120 injectors were completely frozen from sitting on a shelf for 6 months with WD40 in them...
Slapped the old 950s in and it started right up.
Start with the basics. Check for spark, make sure the timing is spot on & the the CAS isn't 180 out. If those are fine, check fuel pressure. All of those were fine on my car and you could hear the compression so checking the injectors my last piece of the puzzle.
**This is assuming you have the ecu/tune setup correctly and no crazy wiring changes, etc to add to the confusion **
Good luck!
Ryan C.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2722 | From: Savannah, GA | Member Since: 08/30/05 | IP: (69.245.80.109) | Report this post to a Moderator
smallblock12
Newbie
738/1000
Galant VR-4 org Post #: 1238086 posted 06/18/17 12:21 AM     Remind Me!  Send Private Message   Edit Post
Got the car started. Never gapped the new plugs. They were almost all the way closed. Time to get tuning I suppose.
91 gvr-4 sold
92 gvr-4 2.4 20g
FlyingEagle
Doesn't Match Anything
Galant VR-4 org Post #: 1238088 posted 06/18/17 11:01 AM     Remind Me!  Send Private Message   Edit Post
What are they gapped to? And what plugs are you using?
C53A 1 of the ~1500
Posts: 1523 | From: THE Ottawa | Member Since: 03/05/05 | IP: (198.84.218.34) | Report this post to a Moderator
Generated in 0.217 seconds in which 0.206 seconds were spent on a total of 14 queries. Turbo powered.
