The Mitsubishi Galant VR-4 Forum
Galant VR-4 Forums » Galant VR-4 » Technical Discussions » solenoid wiring issue
Galant VR-4 org Post #: 1237571 posted 05/29/17 01:38 PM     Remind Me!  Send Private Message   Edit Post
Ok first the Facts:
GVR4 Pins
EGRS: Pin 53 Ground, Pin 102 Power (CA only?)
PCS: Pin 62 Ground, Pin 102 Power
BCS: Pin 105 Ground, Pin 102 Power
FPS: Pin 7 Ground, Pin 102 Power
o2 heater: MFI Relay pin 4 power, Pin 101 ground
My car (Wired like a 1993 model for some reason)
o2 heater: MFI Relay pin 4 power, Pin 105 ground
First of all if its not too much trouble can someone please look at a hard copy of the o2 sensor wire diagram. I only have the pdf version and it looks like it may have been edited.
Is there any reason I can't swap this back to ecu pin 101 so I can use pin 105 for a solenoid again?
Is there any reason to use power from MFI Relay pin 4 over ecu Pin 102?
I'd hate to find out the hard way an melt a perfectly good ecu.
Thank You
Posts: 1383 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: ( | Report this post to a Moderator
Galant Moderator:  curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker
Contact Us | Privacy statement
Generated in 0.21 seconds in which 0.202 seconds were spent on a total of 14 queries. Turbo powered.
