Galant VR-4 Forums » Galant VR-4 » Technical Discussions » ABS rotor stuck on drive shaft
bigandbad
Galant VR-4 org Post #: 1237094 posted 05/11/17 02:26 PM     Remind Me!  Send Private Message   Edit Post
My outer wheel bearings are crap - bought all the stuff to overhaul the rear driveshaft and have to face a new problem...
The brass ABS rotor is stucked at the shaft, it doesn't move anyway.
Can't use my hydraulic press because the wheel hub is too big....
Any suggestions?
Posts: 45 | From: Hamburg, Germany | Member Since: 09/06/16 | IP: (82.83.76.17) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1237099 posted 05/11/17 07:51 PM     Remind Me!  Send Private Message   Edit Post
Maybe saw a slit in each side and smack it good assuming you'd like to get rid of the ABS. For me, I just took the spindles to a shop and they put the new bearing and seal on. Sorry I don't have more for you this time. Maybe an impact could give the extra jolt it needs
1099/2000 Summit white
"Do it once, Do it right."
gaylantvr4
Joe
Galant VR-4 org Post #: 1237104 posted 05/11/17 09:07 PM     Remind Me!  Send Private Message   Edit Post
use a torch to put some heat on the gear to expand it
998/1000
Posts: 850 | From: Omaha ,NE | Member Since: 10/03/04 | IP: (68.13.39.198) | Report this post to a Moderator
bigandbad
Galant VR-4 org Post #: 1237110 posted 05/12/17 03:19 AM     Remind Me!  Send Private Message   Edit Post
@Nebraska: deleting the ABS is not an option. To keep it strrelwgal, the ABS must be functional. I would kill the gear if a new was available - but these are discontinued...
bigandbad
Galant VR-4 org Post #: 1237111 posted 05/12/17 03:20 AM     Remind Me!  Send Private Message   Edit Post
@gaylantvr4: we tried to heat it, bit it's out of brass and not out of steel. We fear that it will start to melt...
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1237115 posted 05/12/17 06:43 AM     Remind Me!  Send Private Message   Edit Post
Clamp the ABS ring in a soft jaw vise and smack the back side of the hub face with a hammer. It should pop off fairly easily.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3327 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:1003:b124:4) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1237116 posted 05/12/17 06:44 AM     Remind Me!  Send Private Message   Edit Post
And if you fuck up the ABS ring trying to remove it, I may have one laying around you can have.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
828/1000
Galant VR-4 org Post #: 1237125 posted 05/12/17 09:54 AM     Remind Me!  Send Private Message   Edit Post
I have some too.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10498 | From: Michigan | Member Since: 03/05/01 | IP: (2602:306:c544:4f) | Report this post to a Moderator
bigandbad
Galant VR-4 org Post #: 1237721 posted 06/03/17 04:03 PM     Remind Me!  Send Private Message   Edit Post
Update:
After heating it with an electric heatgun, the puller at its maximum, at medium temperature for half an hour it suddenly decided to move with a big bang...
Thx to all for your advices!
1 registered and 16 anonymous users are browsing this forum.
Generated in 0.22 seconds in which 0.201 seconds were spent on a total of 14 queries. Turbo powered.
