Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 1993 expo trans
1993 expo trans
kerry92gvr4
462/1000
Galant VR-4 org Post #: 1236996 posted 05/08/17 05:38 PM     Remind Me!  Send Private Message   Edit Post
I have a w5m332nnxl trans in my AWD expo. It shifts great. I am getting ready to turbo the van and was wondering if this trans would hold up? It is a w5m33 and everything I see says it's almost the same as a 1g or gvr4 trans. Anyone with any knowledge on this or these transmissions​?
92 Galant VR4 - sold ...3/6/16 its back!!
92 expo awd 5 speed
94 summit awd 5 speed
Posts: 154 | From: Vancouver, Wa | Member Since: 01/25/10 | IP: (73.164.147.44) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1236998 posted 05/08/17 07:26 PM     Remind Me!  Send Private Message   Edit Post
What's the rear axle ratio on the Expo? I figure so long as it's 3.545 and has the same 1G/GVR-4 transfer case ratio (unlike 2G or Evo3) it should work with the 1G DSM/GVR-4 transmission.
Posts: 2079 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (99.230.38.189) | Report this post to a Moderator
kerry92gvr4
462/1000
Galant VR-4 org Post #: 1237012 posted 05/09/17 10:28 AM     Remind Me!  Send Private Message   Edit Post
They are the same ratio.. I'm wondering though if the expo trans is just as strong as the DSM or Galant vr4 trans . The main casting # is the same.
92 expo awd 5 speed
Posts: 154 | From: Vancouver, Wa | Member Since: 01/25/10 | IP: (2600:100f:b114:b) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1237013 posted 05/09/17 10:40 AM     Remind Me!  Send Private Message   Edit Post
Go on 4g61t.org and contact Leon. He autocrossed and raced a 92 with the same tranny. He would have good info.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
Posts: 739 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
Galant VR-4 org Post #: 1237015 posted 05/09/17 10:57 AM     Remind Me!  Send Private Message   Edit Post
None of these transmissions are good for big power. That said - keep the trans clean and replace the worn out gears and bearings when needed. If your going for over 400whp and you drive like me - don't expect any transmission to last unless its a dogbox. Even then you need to maintain and replace parts regularly. If the trans is loose and not shimmed right it will shatter on hard launches and hard shifting. You can always switch to an auto.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-200M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-82M
2017 VW Passat 1.8L Turbo-16M
Posts: 4495 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (162.197.249.69) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1237024 posted 05/09/17 05:48 PM     Remind Me!  Send Private Message   Edit Post
I've had multiple Expo's. The respective trans'(FWD/AWD) are the same.
I love my crazy mother!!!
Posts: 1540 | From: Manchester, NH | Member Since: 07/17/06 | IP: (2601:18d:8a00:d6) | Report this post to a Moderator
kerry92gvr4
462/1000
Galant VR-4 org Post #: 1237067 posted 05/10/17 07:35 PM     Remind Me!  Send Private Message   Edit Post
Thanks everyone
92 expo awd 5 speed
Leon_R
Galant VR-4 org Post #: 1237866 posted 06/09/17 08:25 PM     Remind Me!  Send Private Message   Edit Post
They are close, but not the same as DSM trannies. The viscous coupler is about 2/3rd the thickness of the DSM, which means that center diff and the other cover are also different. But they are strong! Well, just as strong as AWD trannies, if you want to call them strong
Leon
01 VehiCROSS
93 Eagle Summit TSI AWD [email protected] (4G63 transplant)
96 Mitsu Eclipse Spyder GSX
80 Triumph TR7 GST (4G63 transplant)
Posts: 210 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (108.7.233.26) | Report this post to a Moderator
kerry92gvr4
462/1000
Galant VR-4 org Post #: 1237903 posted 06/11/17 02:01 PM     Remind Me!  Send Private Message   Edit Post
thank you leon, I thought that i had heard that same thing somewhere before. just was wondering if when doing a 4g63 swap if it would benefit from putting a dsm trans in vs sticking with the expo trans and it seems as if i will stick with the expo trans since its in great shape .
92 expo awd 5 speed
Leon_R
Galant VR-4 org Post #: 1238657 posted 07/20/17 11:58 PM     Remind Me!  Send Private Message   Edit Post
I used van tranny with upgraded DSM viscous coupler and Shep Racing 4 spyder center diff
Leon
01 VehiCROSS
Posts: 210 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (199.46.249.143) | Report this post to a Moderator
Generated in 0.256 seconds in which 0.235 seconds were spent on a total of 14 queries. Turbo powered.
