Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Hard starting issue after reconnecting fuel tank control valve
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1236611 posted 04/15/17 04:23 PM     Remind Me!  Send Private Message   Edit Post
I was getting a decent gas smell from the driver rear for a while, but never saw wetness from gas and figured it was vapor issue since the tank still was pressurized. Finally decided to open up the fuel pump inspection cover to find out that the fuel tank pressure control valve is disconnected between the hard line and the valve. The hose clamp wasn't even in the right place so it must have wiggled free. I tested the valve and it is still working correctly. The arrow is pointed towards the engine and not the tank. Once reconnected, the car had troubles idling for a minute, but now is fine. What I am now having an issue with is that it hard starts (cranks and cranks and then fires) on cold starts. Totally fine on hot starts.
It is a Cali emissions car that has the egr deleted and I redid the vacuum lines years ago and has been running fine since then. I was thinking it might be my vacuum lines, but the seem spot on after Checking the service manual. I really wish I wouldn't have switched them just because that color coding is nice to have.
Any thoughts to the hard cold starts?
Posts: 326 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:6) | Report this post to a Moderator
JNR
5 star (English Professor) member
20/1000
Galant VR-4 org Post #: 1236650 posted 04/17/17 11:27 PM     Remind Me!  Send Private Message   Edit Post
Is it older gas? Corn oil (ethanol) can cause problems in cold weather, but at ~10% (assuming if they use as additive) shouldn't *IF* the gas was stored properly and isn't too old. Otherwise, it likes to attact moisture + can separate over time from the gasoline.
To eliminate as possibility, see if you can take a long trip to burn up what you have in there.
Posts: 9731 | From: ca | Member Since: 04/23/04 | IP: (2606:6000:63a1:1) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1236726 posted 04/22/17 10:06 AM     Remind Me!  Send Private Message   Edit Post
It was fresh gas, just filled it up before connecting the hose.
Posts: 326 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.221 seconds in which 0.208 seconds were spent on a total of 14 queries. Turbo powered.
