Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Since the car has been sitting my brakes are rocks.
VR6Eater
ShiftBoots?
Galant VR-4 org Post #: 1235652 posted 03/02/17 11:00 PM     Remind Me!  Send Private Message   Edit Post
I haven't had time to try and bleed the system. I don't see any leaks. It will still stop but I'm thinking master cylinder?
Any opinions.
24/2000-Wrecked, parted, and scrapped. RIP
425/1000-Currently not JSB
1702/2000-SOLD
99 SRADFixxerUpper 750cc
73 F-100 390cu all original family heirloom
Posts: 85 | From: Bristol, WI | Member Since: 01/22/13 | IP: (50.224.142.8) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1235654 posted 03/03/17 06:28 AM     Remind Me!  Send Private Message   Edit Post
check valve for brake booster clogged??
138/2000
Posts: 3428 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1235655 posted 03/03/17 06:37 AM     Remind Me!  Send Private Message   Edit Post
Frozen calipers?
1992 Nile black w/sunroof
14xK miles. 2nd owner since 1998
Posts: 5745 | From: Lafayette, IN | Member Since: 08/06/02 | IP: (128.210.106.177) | Report this post to a Moderator
highrpm666
677/1000
Galant VR-4 org Post #: 1235666 posted 03/03/17 02:54 PM     Remind Me!  Send Private Message   Edit Post
Failed booster.
VR4 677/1000-rebadged. AKA Charlie the turbo slut DD
Posts: 118 | From: Morrison, Co | Member Since: 02/19/14 | IP: (2607:fb90:6e48:8) | Report this post to a Moderator
VR6Eater
ShiftBoots?
Galant VR-4 org Post #: 1235668 posted 03/03/17 06:59 PM     Remind Me!  Send Private Message   Edit Post
I didn't think about the booster. Thanks guys.
1702/2000-SOLD
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1235676 posted 03/04/17 12:40 PM     Remind Me!  Send Private Message   Edit Post
Pull the booster hose directly at the booster - do you hear air sucking in almost instantly as the hose comes loose?
If not ... hose leak, check valve suspect, or internal booster leak to atmosphere. Use a vacuum hand pump and vacuum gauge to confirm hose and valve hold vacuum.
Basic booster test:
Foot on brake pedal. Start engine. Pedal should sink a little bit. This is good, no sinking, not so good.
Now release pedal.
Stop engine.
Pump pedal a few times until the booster effect is bled off. Should take a few pumps.
If not ... more possible booster issues.
C53A 1 of the ~1500
Posts: 1528 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.224.194.147) | Report this post to a Moderator
1 registered and 8 anonymous users are browsing this forum.
Generated in 0.214 seconds in which 0.204 seconds were spent on a total of 14 queries. Turbo powered.
