Galant VR-4 Forums » Galant VR-4 » Technical Discussions » For stereo: MT reverse light wire?
PlatypusOfFury
849/1000
669/2000
Galant VR-4 org Post #: 1235053 posted 02/01/17 12:24 PM     Remind Me!  Send Private Message   Edit Post
I purchased a fairly dope Android based 2xDIN deck with the works on it including a backup camera.
Looking for the best place I can tap into the Manual's reverse lights wire to activate backup.
Someone must have done this already, just thought I'd hit some pointers up before diving in myself.
Posts: 81 | From: Bellingham, WA | Member Since: 05/22/12 | IP: (2001:4898:80e8:f) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1235055 posted 02/01/17 12:36 PM     Remind Me!  Send Private Message   Edit Post
The only thing the reverse switch does, is to connect the two wires that come into it.
This is basically a ground for the light circuit if memory serves.
If you were to tap/Tee into the reverse light circuit and use that power feed to trigger a backup camera, that will be the closest wire portion to your camera.
Maybe someone else has hooked one up, using the GVR4?
C53A 1 of the ~1500
Edited by FlyingEagle (02/02/17 11:18 AM)
Posts: 1534 | From: THE Ottawa | Member Since: 03/05/05 | IP: (108.63.165.88) | Report this post to a Moderator
PlatypusOfFury
849/1000
669/2000
Galant VR-4 org Post #: 1235056 posted 02/01/17 01:56 PM     Remind Me!  Send Private Message   Edit Post
Why wouldn't it be a tech discussion?
Double DIN stereos w/ backup cameras are getting dang cheap!
The reverse trigger wire to turn the camera on could go many places I'm assuming.
Reverse switch on the manual trans, somewhere in the reverse switch to rear wiring, or even all the way back to a tail lights.
Just seeing if anyone already did this, and where they attached the trigger wire in the VR4.
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1235086 posted 02/02/17 11:20 AM     Remind Me!  Send Private Message   Edit Post
Edited my first post. Sorry, I was coming at it from a mindset of a time long ago ... may have misjudged. Apologies.
C53A 1 of the ~1500
PlatypusOfFury
849/1000
669/2000
Galant VR-4 org Post #: 1235100 posted 02/02/17 07:07 PM     Remind Me!  Send Private Message   Edit Post
No worries.
Backups (for the most part) consist of Ground, 12v Power, and a "Trigger" wire set.
Trigger wire is supposed to link into the reverse power circuit. Stereo display will automatically switch to backup camera when power is sensed through Trigger wire.
I can route all the way back to the trunk reverse lights and be safe. Just thought some may know of a closer place I could tee into with minimal mess.
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1235111 posted 02/03/17 11:44 AM     Remind Me!  Send Private Message   Edit Post
Where ever the relay for the reverse lights will be, is the closest spot to a radio housing you will get, and the wiring can be readily tapped into before going to the rear of the car.
C53A 1 of the ~1500
89Mirageman
Galant VR-4 org Post #: 1235117 posted 02/03/17 02:26 PM     Remind Me!  Send Private Message   Edit Post
I know from making the dsm to csm conversion harnesses that on a 1g the wires for the backup lights come through the firewall. Its behind the passenger's side kick panel where the engine harness plugs into the dash harness. I'd have to think a galant from the same era would be the same way.
94 Eagle Summit DL coupe
98 Mitsubishi Mirage DE sedan
15 Mitsubishi Mirage ES hatch
Posts: 2494 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (76.6.142.114) | Report this post to a Moderator
0 registered and 54 anonymous users are browsing this forum.
Generated in 0.215 seconds in which 0.198 seconds were spent on a total of 14 queries. Turbo powered.
