Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Speedo reports faster than actual speed
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1234477 posted 12/28/16 03:01 AM     Remind Me!  Send Private Message   Edit Post
My GVR4 reports +10mph higher than actual speed. I found it strange how my car says I'm going like 70mph and cars are passing me so I checked it with a GPS one day and found out it 10mph higher. Does anyone know the cause for this and is there a way I can adjust it like get a different speedo gear drive or something?
"Black Widow" 1991 Galant VR4 #1373/2000
1998 Mitsubishi Eclipse GST
1991 Toyota Previa 5-Speed
1989 Toyota MR2 Supercharged
1976 Datsun 280Z Turbo
Posts: 23 | From: San Jose, California | Member Since: 01/04/16 | IP: (50.148.189.125) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1234484 posted 12/28/16 09:16 AM     Remind Me!  Send Private Message   Edit Post
Whats your wheel/tire combo measurements?
Thom
1992 GVR-4 866/1000. Ready for all of the above.
1992 GVR-4 148/1000. Rescue
Posts: 761 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1234500 posted 12/29/16 08:00 AM     Remind Me!  Send Private Message   Edit Post
Ahh I forgot about the tire size
It has EVO8 wheels with 245/40/17s
I put in the sizes with the stock 195/60/15s in the tire calculator and it says they're the same size though maybe reports 1mph faster.
Maybe if I change to a taller profile tire like a 45 it will read closer to what it should be but it'll probably be off by +5 still.
Galant VR-4 org Post #: 1234505 posted 12/29/16 11:11 AM     Remind Me!  Send Private Message   Edit Post
1g trans and speedo gear maybe? They are different (though I am not at this point thinking about which way).
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1234530 posted 12/30/16 10:20 AM     Remind Me!  Send Private Message   Edit Post
Hmm that maybe the problem are the GVR4 and 1G DSM speedo gears interchangeable?
Galant VR-4 org Post #: 1234549 posted 12/31/16 10:42 AM     Remind Me!  Send Private Message   Edit Post
Yes, IIRC they are one tooth different maybe. I put the 1g in my car because I have 225 45-17 tires on, and they are closer to the rolling diameter of the 1g with 16" wheels than the stock VR4 diameter.
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1234571 posted 01/02/17 06:27 AM     Remind Me!  Send Private Message   Edit Post
Cool I guess the search for a 1G Speedo gear drive begins thanks =)
Eager Beaver
Galant VR-4 org Post #: 1234578 posted 01/02/17 09:34 AM     Remind Me!  Send Private Message   Edit Post
I looked up a 4wd D27A model and the speedo gear (driven) in the trans case top, is MD728826.
JnzTuning.com shows just over $21 US if they can get the part. The part listed N=29 which has to be the tooth count.
The same gear in the Gvr4 is MD728827, and listed as N=30, so 30 tooth count.
As Ice suspected, it is a single tooth count difference. Same price.
C53A 1 of the ~1500
Posts: 1556 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.224.205.238) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1234595 posted 01/02/17 08:05 PM     Remind Me!  Send Private Message   Edit Post
Good info here!
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2754 | From: Savannah, GA | Member Since: 08/30/05 | IP: (73.21.58.201) | Report this post to a Moderator
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1238912 posted 08/06/17 08:07 AM     Remind Me!  Send Private Message   Edit Post
Just a followup to this topic. I finally got around to installing A gvr4 speedo gear that I got. When I took the current one out it had a 29tooth gear and the gvr4 one I had had a 30tooth gear. Swapped them out and now my speedo is off by +12 now so it made it worse. I guess I should have figured since the teeth went +1 it would spin slower.
Anyway I noticed my speedo needle settles on the 15mph mark. Is this normal? Maybe I should open it up and move the needle to the 5mph mark.
Edited by HadesOmega (08/06/17 04:00 PM)
Posts: 23 | From: San Jose, California | Member Since: 01/04/16 | IP: (67.188.137.56) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1238914 posted 08/06/17 08:51 AM     Remind Me!  Send Private Message   Edit Post
Never seen a speedo that doesn't sit at the needle when it should be at rest, unless something is amiss or someone had the gauge face/needle off for some reason and they goofed at reinstalling the needle. The needle should sit lower at rest as it only moves up when the reed switch is activated and the cable in the back of the cluster is actually spinning.
C53A 1 of the ~1500
Edited by FlyingEagle (08/06/17 08:53 AM)
Posts: 1556 | From: THE Ottawa | Member Since: 03/05/05 | IP: (68.171.77.46) | Report this post to a Moderator
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1238920 posted 08/06/17 04:01 PM     Remind Me!  Send Private Message   Edit Post
Yeah the previous owners have been doing some goofy stuff to this car =(
0 registered and 46 anonymous users are browsing this forum.
Generated in 0.249 seconds in which 0.228 seconds were spent on a total of 14 queries. Turbo powered.
