Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Stuck on Heater Core Replacement - Need Help [RESOLVED]
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1234276 posted 12/20/16 03:22 AM     Remind Me!  Send Private Message   Edit Post
So, I've got a leak in the heater core and started the process to replace it, but I've hit a roadblock. Hoping some of you who are experienced here can help me with the next steps since a lot of the writeups (and the FSM) don't really describe it well. I searched quite a bit and use a few posts for the process, but none really explain this part.
So far I have pulled the dash, though I just pulled the center console back rather than fully removing it (this may be part of the issue?). I've removed the bolts/nuts for the A/C evap, blower, and the heater unit.The engine bay side hoses are removed from the heater core. I am stuck on how to get the heater unit out, specifically, based on the FSM I am understanding that the evap needs to come out first, then supposedly I can get the heater core out? I'm not seeing how that is possible with the hard A/C lines running to the evap, unless I drain the system and disconnect the lines. I added a link to an image below of the current situation if it helps.
Pic of the situation
My guess is that I need to actually fully remove the center console and the parts between the heater unit and the console, and then I am hoping its all way easier than I think after that. I may be wrong though, which is why I am posting here before I proceed.
Thanks for the help!
Edited by mooserage (02/04/17 12:18 AM)
Posts: 1173 | From: Seattle, WA | Member Since: 05/17/04 | IP: (73.97.159.114) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1234278 posted 12/20/16 06:49 AM     Remind Me!  Send Private Message   Edit Post
The evap is bolted partially over the center unit. You will have to be real careful to remove it without removing the evap. Might be best to have it evacuated and recharge it after. Otherwise you risk cracking your lines or evap core and snapping off the tabs that locate the center unit on the studs.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
Posts: 724 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1234303 posted 12/20/16 07:47 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the reply! Just to clarify, your suggestion would be to remove the A/C hard lines and pull the EVAP out into the cabin. The A/C hasn't worked for 10 years, the compressor bearing toasted and I never cared to fix it,so it wouldn't be a huge loss to empty the lines.
After that, am I just pulling the heater towards the cabin, or does it move toward the EVAPs old location and then out? Just trying to picture this before I do it.
Also, any suggestions for emptying a/c lines? Not sure if anything will be left in there after 10 years without use, but if there is I'm not sure I could capture it properly .
Thanks.
-254/2000 Summit White DD (aka "The Yeti")
The Yeti loves winter and hates me.
-ムースライジュ
Posts: 1173 | From: Seattle, WA | Member Since: 05/17/04 | IP: (107.77.97.112) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1234306 posted 12/20/16 08:08 PM     Remind Me!  Send Private Message   Edit Post
Jesus. If I ever had to do this, I'd probably just sell my Galant. *knocks on wood*
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3338 | From: SoCal | Member Since: 01/02/12 | IP:
(207.255.187.121) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1234312 posted 12/21/16 07:18 AM     Remind Me!  Send Private Message   Edit Post
My son just did this on his Galant. You will pull the EVAP towards the cabin, then the center core pulls toward the cabin also. Took 4 hours, start to finish, to pull the entire dash and everything to replace the core and put it back together. It looks more ominous than it really is. My galant came with the dash removed (along with all the intricate vent work behind it) and I had to put the puzzle back together. That had me wishing I didn't want the car...
Thom
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1234319 posted 12/21/16 10:25 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the detail, just wondering when your son did it, did he pull the whole center console/arm-rest too? I'm wondering if I need more room to get it out and should pull it, it's not too far from being ready to pull anyway.
It has been a rough adventure on this job, but if anything it has given me insight into the dash/interior and the condition of parts. If that's worth anything
1025/2000
Galant VR-4 org Post #: 1234320 posted 12/21/16 10:36 AM     Remind Me!  Send Private Message   Edit Post
Yes, entire armrest and center brackets were pulled
Thom
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1235122 posted 02/03/17 10:42 PM     Remind Me!  Send Private Message   Edit Post
Been meaning to update this with how I got through it and hopefully it helps someone else searching later.
So, this:
was absolutely correct. After pulling the entire dash cover without taking out the center console, I got stuck, because I should have pulled the center console and the center support as well. Here it is before and after pulling those:
Before (No way that the heater unit would rotate or was going to come out):
After (was able to rotate the assembly and get it out):
Also note, you have to remove the lower vent splitter (sorry not sure on the name, but its attached to the the bottom of the heater core) to get the heater unit out, its on the driver floor in the second image.
From there I had to loosen the A/C Evap unit and was able to then pull the heater inward and rotate the top toward me until the heater core was facing upward as seen here:
(Still in the dash area):
From here it is a lot of wiggling to get the heater unit assembly out of the dash, so... I didnt, I removed the core with the heater unit still in the dash area, just rotated.
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1235123 posted 02/03/17 11:07 PM     Remind Me!  Send Private Message   Edit Post
If you are like me, you bought an aftermarket heater core (mine from O'Rielly's) and found yourself in an interesting predicament when you put them side by side:
The stock unit is a perfect fit and if you have the cash and foresight you should get one. It is a perfect fit and comes with the foam already attached. Honestly, if I had realized how much work it'd be to get to this point, I would've gotten one from JNZ because I never want to do this again.
But, if you are cheap, or like me, here is what I did:
First, you will need a foam to seal the unit in it's space, otherwise the air will go around the core and not heat properly. After some searching I found people recommended either camper/canopy seal or pipe insulation, both are adhesive backed. I decided to go with the pipe insulation:
Next, try fitting the new heater core, note where the new core is different than the old one because you can't copy the foam exactly due to varying shapes of aftermarket cores. I found that the end tanks were fatter and almost sealed on their own, and that the sides were quite a bit skinnier than the stock so I added some extra foam. Next, add foam and test the fit and re-do it until you are satisfied.
Here is what I ended up with:
It's not the prettiest, but it did seal well. You can probably see where I added some in an attempt to mirror stock and removed it after I found mirroring the stock foam wouldn't work.
One thing to note, with this new core it did not sit as deep in the heater unit as the stock one, it took me fitting the final plates that hold the core in to realize that it would work. The aftermarket one just stuck out further than the original. So its ok if you feel it is sticking way out of the heater unit, try fitting the plates before you give up.
I also added some foam to the plate that goes through the firewall since mine literally crumbled off from being worn down by a coolant leak. Here is a shot of it being added and the last few steps:
Plates Installed:
From there I flipped the unit back into the original position, which was very difficult and took a lot of patience and started on reassembly.
I took a lot more time than the manual would call for, but thanks to good labelled and pictures during disassembly everything worked after re-install. And the heater is HOT.
-ムースライジュ
Galant VR-4 org Post #: 1235130 posted 02/04/17 10:10 AM     Remind Me!  Send Private Message   Edit Post
Thanks. That is good and useful.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10527 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
1 registered and 22 anonymous users are browsing this forum.
Generated in 0.236 seconds in which 0.191 seconds were spent on a total of 14 queries. Turbo powered.
