Galant VR-4 Forums » Galant VR-4 » Technical Discussions » T3 manifold options?
Yao
Galant VR-4 org Post #: 1209588 posted 06/05/15 09:57 AM     Remind Me!  Send Private Message   Edit Post
Okay, I am getting a little antsy about putting on the T3 that I have for over 5 years lol, what are some good T3 exhaust manifold option that you guys recommend? I kind of like the Treadstone Performance 4G63 Cast Turbo Manifold M121, any experience? ideas? thx
3"K&N, B16g, 2.5pipe, Synapse DV, ETS Frntmnt, FP4r, ZFG Long Block, 2g mani, evo3o2/5th, 3"exst,fic1100cc/walbro,
6an, poly mnts, DEL-abs/ps/4ws/egr/evp, Jack's tran, SB-clutch, evo8 whls-245/45/17/springs, 3kvr4 brakes, Koni, 4bolt rear,
ds-map, ntk.
Posts: 810 | From: Denver, CO | Member Since: 03/06/01 | IP: (73.34.15.168) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1209596 posted 06/05/15 01:59 PM     Remind Me!  Send Private Message   Edit Post
Reliability wise, I have heard good things about the Turbonetics Cast T3 manifold. Not sure about fitment of the wg on a gvr4 though.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1209612 posted 06/05/15 07:22 PM     Remind Me!  Send Private Message   Edit Post
DSM Punishment Racing header fits great but you can't run the stock radiator. I see problems with that turbine housing outlet in case you are running a factory location downpipe and alternator.
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Edited by diambo4life (06/05/15 07:24 PM)
Posts: 241 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (12.130.175.148) | Report this post to a Moderator
89Patches
I <3 AMS
Galant VR-4 org Post #: 1209616 posted 06/05/15 11:14 PM     Remind Me!  Send Private Message   Edit Post
I can't think of any off the shelf T3 manifolds that will fit with the stock radiator. You could ditch the T3 housing and get the FP bolt on housing with O2 housing. Even with the bolt on housing it will be a big improvement over that 16G of yours!
Posts: 723 | From: Ontario Canada | Member Since: 01/30/13 | IP: (174.35.243.172) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 1209617 posted 06/05/15 11:36 PM     Remind Me!  Send Private Message   Edit Post
I ran an ERL on mine with a pte6262 and it JUST cleared the alloy radiator.
There is NO WAY to run a rear mounted fan though so if you still have aircon it's a no go.
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 953 | From: brisbane australia | Member Since: 02/13/04 | IP: (124.186.93.111) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 1209637 posted 06/06/15 11:02 AM     Remind Me!  Send Private Message   Edit Post
I wanted t3, because there would be more turbo selection/vendor selection as well as better pricing then keep going back to FP. Want Cast manifold, because I don't want to deal with cracks and I want durability for DD, looking to do the manifold/down pipe and external gate as versatile as I can. For example, here is my T4 setup for my GSX, but I want it in T3.....
ds-map, ntk.
MDK87
Newbie
Galant VR-4 org Post #: 1209658 posted 06/07/15 02:14 AM     Remind Me!  Send Private Message   Edit Post
I've got two 12" fans behind my 2 core alloy radiator using a Turbonetics manifold.
Mine has also had the T3 and head flanges angle milled to bring the turbo further out. (Compressor cover fouling on block).
You'd have even greater clearance with a non-modified Turbonetics manifold.
Edited by MDK87 (06/07/15 02:15 AM)
Posts: 23 | From: Brisbane, Australia | Member Since: 01/12/10 | IP: (124.170.97.148) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 1210074 posted 06/13/15 10:10 AM     Remind Me!  Send Private Message   Edit Post
Okay, I've ordered the Treadstone Manifold, which is a copy of Turbonetics with higher NI content and lifetime warranty. Next up 34 or 38mm external wastegate, any suggestions? what are some of the most compact ones out there? i
I've scored my self this:
think I'll just cut off the 4 bolt flange and weld on a vband to match up the turbo for easy hookup/release.
ds-map, ntk.
Edited by Yao (06/13/15 10:11 AM)
Yao
Galant VR-4 org Post #: 1210208 posted 06/15/15 08:11 AM     Remind Me!  Send Private Message   Edit Post
okay, looking at all the 38mm including turbosmart, tial, and Synapse 40mm. Any thoughts? I am tempted to try Synapse, but I've read some horror stories on how it's make in china and fails after 1 year. Turbo smart is suppose to be the most compact here, are they made in US?. Tial is proven and made in us.
ds-map, ntk.
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1210214 posted 06/15/15 09:16 AM     Remind Me!  Send Private Message   Edit Post
Don't know about the Synapse. TiAL quality is good. I've had Turbosmart stuff, quality is really good. Australian company, but these day manufacturing could take place anywhere, or the source of the materials anyway. Either way Turbosmart stuff is really nice. I have their CompGate 40. Very compact, as the name would imply.
Posts: 1945 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (2602:306:cd73:c1) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 1210308 posted 06/16/15 02:45 PM     Remind Me!  Send Private Message   Edit Post
Okay, received it today! looks good, however, there is some imperfections from casting, also the first thing I notice is the weight of this thing, roughly 16lbs!! everything looks beefy, the thinnest part of the manifold is where they make the upper indentation for the mounting studs, if it would ever crack, I suspect it would be there. Here is some pics, looks like it's gonna be a tight fit! lol
ds-map, ntk.
Edited by Yao (06/16/15 02:45 PM)
Galant VR-4 org Post #: 1210312 posted 06/16/15 03:17 PM     Remind Me!  Send Private Message   Edit Post
Tight fit? I see your problem, trying to install two manifolds at the same time.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10748 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1210320 posted 06/16/15 04:49 PM     Remind Me!  Send Private Message   Edit Post
We had to machine a 10* angle into the flange of that manifold to clear an hx35 with the stock holset housing. That is what it took to clear the block. Aside from that, that is all we had to do to make it work. We just left the casting imperfections and gasket matched the ports. The outlet was really bad actually. Not in the right spot and funky shaped. An hour or so and it was good enough to run. We have minimal run time as our hx35 was bad but, should have it running again soon with a smaller hy35. So far so good though.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Posts: 1243 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (184.96.219.125) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1210351 posted 06/16/15 10:35 PM     Remind Me!  Send Private Message   Edit Post
Yao, that mani looks like hot garbage. I can't believe your going to mount that nice turbo to that. Also what's with all the hackery going on in your engine bay bro?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
89Patches
I <3 AMS
Galant VR-4 org Post #: 1210379 posted 06/17/15 11:24 AM     Remind Me!  Send Private Message   Edit Post
Fuck me. I actually agree with G...
Generated in 0.169 seconds in which 0.113 seconds were spent on a total of 14 queries. Turbo powered.
