Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Opinions on Suspension Tech rear sway bar kit?
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137786 posted 08/25/13 08:27 PM     Remind Me!  Send Private Message   Edit Post
I plan on upgrading my rear sway bar, not only for corners but to help with 60ft times. While checking pricing on the 26mm Whiteline bar, I came across the ST kit on JNZ's site. The pros are its $50 cheaper, comes with adj endlinks, and it also comes with a subframe brace. So consider the price difference and extra goodies, I'm surprised its not more popular. Thoughts?
JNZ link
-Craig
1501 Build Thread
Posts: 1755 | From: O-H-I-O | Member Since: 11/24/11 | IP: (75.89.183.89) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1137788 posted 08/25/13 09:07 PM     Remind Me!  Send Private Message   Edit Post
if i didnt have the 4ws id buy that. thats awesome.
138/2000
Posts: 3412 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (24.176.247.34) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1137789 posted 08/25/13 09:47 PM     Remind Me!  Send Private Message   Edit Post
Try Ultra Racing bars, they have full sway bars and fender brace and such for our car
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (166.137.191.16) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137810 posted 08/26/13 01:51 AM     Remind Me!  Send Private Message   Edit Post
I swapped to a full DSM rear subframe, when I did my. 4 bolt swap, so I don't need anything VR4 specific. Those UR bars are expensive as well
-Craig
1501 Build Thread
Street Surgeon
Professor Street Surgeon
501/1000
Galant VR-4 org Post #: 1137820 posted 08/26/13 08:22 AM     Remind Me!  Send Private Message   Edit Post
I bought a ST front and rear swaybar kit, the front is garbage and has to be used with the stock bar!
Cory O.
'92 Mitsubishi Galant VR-4 501/1000
Heavily modified, barely driven, some assembly required.
Edited by Street Surgeon (08/26/13 03:10 PM)
Posts: 941 | From: Omaha, Nebraska | Member Since: 03/03/04 | IP: (132.3.49.81) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1137821 posted 08/26/13 08:30 AM     Remind Me!  Send Private Message   Edit Post
My ST rear 25mm bar fit perfect. Handles great, it's non adjustable which is the only negative.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137836 posted 08/26/13 12:15 PM     Remind Me!  Send Private Message   Edit Post
Street Surgeon, was it because of 4WS it won't fit right?
Prove it, I believe the link said it comes with adjustable end links now
-Craig
1501 Build Thread
Street Surgeon
501/1000
Galant VR-4 org Post #: 1137854 posted 08/26/13 03:10 PM     Remind Me!  Send Private Message   Edit Post
Actually I made a mistake (which I will try to edit in a minute here...), it was actually the front bar that is a complete PITA, their front bar (I bought the front and rear set) actually works WITH your stocker so you end up with two front bars and you have to use a set of special brackets and modify things etc. etc. The back I didn't put in yet as I am removing the AWS rear and installing a 4-bolt.
Here's something fun, try looking up instructions on their site on how to install these *hint* they don't exist..... ANYWHERE..... Not even in the box. Not that you should need a set of instructions to install a swaybar right? Wrong, ya do if it's the front one! Want to buy my set? I never even put them on the car I just took them out of the box and after I saw the mess decided to go whiteline.
Cory O.
Posts: 941 | From: Omaha, Nebraska | Member Since: 03/03/04 | IP: (132.3.49.78) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1137873 posted 08/26/13 04:30 PM     Remind Me!  Send Private Message   Edit Post
I meant that the bar is not adjustable.
12yr+ Vr4 owner.
Family Guy
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1137888 posted 08/26/13 07:43 PM     Remind Me!  Send Private Message   Edit Post
I've had the ST bar in my car for probably 6 years. Works and fits well. It does help dial some understeer out, but it's still not neutral or tail happy. Mine didn't come with the brace though, must be a new addition, and not quite sure where it would go? That looks like a generic picture.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
01 GMC Sierra C3 AWD
05 CTS-V Stealth Grey
Posts: 1619 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.135.121) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137898 posted 08/26/13 08:13 PM     Remind Me!  Send Private Message   Edit Post
Street Surgeon, I would consider buying the rear bar. For my car, I don't need the front. The rear is $200 shipped from JNZ, and comes with endlinks and the extra brace
Prove, wouldn't adjustable endlinks accomplish the same thing as an adjustable bar?
EMX, good to know that you have one and like it. I actually checked some members gallery threads on cars I felt were well built, to see if anyone was running one. Your thread was one of the ones I looked at, it's not listed though. As for the extra brace, I will just ask JNZ. Regardless, for the $50 difference and including the end links, it's looking like a winner to me
-Craig
1501 Build Thread
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1137963 posted 08/27/13 10:24 AM     Remind Me!  Send Private Message   Edit Post
Added, thanks! The biggest PITA with it, is getting the bolts started for the hold-down clamps. I'm sure the Whiteline/others is the same deal. It's a lot of bar/poly bushing to shove between the factory bolt holes.
91 #108/2000- link
715/1000
1284/2000
Galant VR-4 org Post #: 1137975 posted 08/27/13 11:54 AM     Remind Me!  Send Private Message   Edit Post
Quoting LIV4PSI:
No, an adjustable bar actually changes the spring rate of the bar by using different attachment points, adjustable links only adjust the bar angle on install.
12yr+ Vr4 owner.
Family Guy
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1137983 posted 08/27/13 12:54 PM     Remind Me!  Send Private Message   Edit Post
I have the 4ws intact with my Whiteline 26mm bar
92 GVR4 #802 link
06 EvoIX SSL-417HP/418TQ-OEM Turbo E85 / Ohlins DFV
94 MX5 M-Edition - On Xidas
SOLD: 92 GVR4 #611
Posts: 789 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Galant VR-4 org Post #: 1238313 posted 07/02/17 01:06 PM     Remind Me!  Send Private Message   Edit Post
So I was looking for instruction like mentioned above and did find some, but they are so old that the image liknks we're all dead. Can anyone post a picture of the st bars installed to give me an idea of what I'm doing?
Posts: 1373 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.63.63) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1238315 posted 07/02/17 03:54 PM     Remind Me!  Send Private Message   Edit Post
I just installed my whiteline 26mm bar last week and had all the known issues and perhaps one more.
I ground the slots on the bar mounting brackets and changed hardware to hex cap screws with D shaped washers in order to fit the brackets to the factory mounting position.
The clearance between the end of the bar and the rear trailing arm/hub was insufficient so I had to grind the top corners down to stop it contacting there. I dont think this is a big issue but reflect sloppy/cheap manufacturing.
I don't want to us the word bent, but my bar was crooked. When I sat it on a flat surface the right side of the bar sat flat against the surface and the left side of the bar was 20mm above the flat surface. (workbench and concrete garage floor)
When I installed the new mevotech endlinks I cut one of the bushings in half and spaced them differently in order to compensate for the 20mm difference and remove any preload on the bar. You can see it in the first picture above.
So not all that good from whiteline, but what I will say is that a 26mm bar in the middle stiffness setting did help the under steer a bit but as mentioned above it certainly did not make the car neutral or tail happy. So i wonder if the 25mm bar would be worth it. I am thinking I will change my endlink location to the stiffest setting soon.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 117 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) | Report this post to a Moderator
pagosadsm
Galant VR-4 org Post #: 1238317 posted 07/02/17 04:38 PM     Remind Me!  Send Private Message   Edit Post
I have a SP 1" bar on my 92 Talon. I made it adjustable and also mounted it to my trailing arms. I have tubular rear control top and bottom. All suspension is steel bushings or heim joints
Rick
Posts: 53 | From: pagosa springs colorado | Member Since: 11/26/10 | IP: (174.28.136.226) | Report this post to a Moderator
Galant VR-4 org Post #: 1238318 posted 07/02/17 06:19 PM     Remind Me!  Send Private Message   Edit Post
25mm is still bigger than 19mm I'm not sure how the adjustability is gauged, but maybe it's more aggressively spaced than the middle hole on the white line. I can only hope right. Did you have to drop the subframe?
I still would like a picture of the front one installed. There's some weird hardware in the box and its got me scratching my head.
Posts: 1373 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2604:2000:1480:8) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1238348 posted 07/03/17 04:25 PM     Remind Me!  Send Private Message   Edit Post
I had the front bar installed in my DSM. I took it out because they understeer enough from the factory. I have only been using an aftermarket rear bar since then. I'll see if I can find a picture. As mentioned though, it does go underneath the front subframe, and parallels the stock bar.
Also, in regards to the Whiteline adjustable rear bar. I've seen many instances where using the stiffest and softest setting breaks endlinks because of their extreme angle. The middle one seems to be the only real option.
Another side note I learned while searching suspension parts for my Caddy. ST is owned by KW. So I wouldn't be concerned with quality.
91 #108/2000- link
Edited by EMX5636 (07/03/17 04:34 PM)
Posts: 1619 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:100:25a1) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1238349 posted 07/03/17 06:52 PM     Remind Me!  Send Private Message   Edit Post
While I haven't tried the other two adjustment holes it certainly looks like the end links will be at a pretty steep angle with the whiteline bar. That was the reason I chose the middle setting initially.
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.258 seconds in which 0.207 seconds were spent on a total of 14 queries. Turbo powered.
