Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 1g intercooler
1g intercooler
Yao
Galant VR-4 org Post #: 1085587 posted 09/15/12 08:16 PM     Remind Me!  Send Private Message   Edit Post
Okay, it's time to do intercooler upgrade. I am looking at 1g VRSF Kit. Just one question, anybody knows if a 1g front bumper mount is similar to vr4? They don't have Gvr4 kit, but I think it might work, no?
3"K&N, B16g, 2.5pipe, Synapse DV, ETS Frntmnt, FP4r, ZFG Long Block, 2g mani, evo3o2/5th, 3"exst,fic1100cc/walbro,
6an, poly mnts, DEL-abs/ps/4ws/egr/evp, Jack's tran, SB-clutch, evo8 whls-245/45/17/springs, 3kvr4 brakes, Koni, 4bolt rear,
ds-map, ntk.
Posts: 810 | From: Denver, CO | Member Since: 03/06/01 | IP: (67.176.15.69) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1085646 posted 09/16/12 06:48 AM     Remind Me!  Send Private Message   Edit Post
short answer yes, any intercooler with "work". long answer not really, there will be lots of cutting and the bumper supports are absolutely nothing alike. you will be cutting up a good amount of the bumper support and possibly parts of the frame. i just did an evo8 install and i had to cut parts around my pass headlight to get the piping to route properly, i also had to do a mini wire tuck to keep from having intercooler pipe hitting it and the radiator. if anything i would look into the dimension of the 2G one because the drivers side piping is up top, just the way the aftermarket GVR4 specific ones are.. i'd do lots of measuring and probably have the bumper off the car checking every measurement so i know what im getting into.
138/2000
152/1000
Edited by transparentdsm (09/16/12 06:51 AM)
Posts: 3620 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.237.230) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 1085696 posted 09/16/12 04:10 PM     Remind Me!  Send Private Message   Edit Post
K, looking closer, I think I'll just stick with ETS. My partial front mount is not doing good at all, 85 degrees out side and my intake temp at manifold is 130!! with 8psi??!! How am I suppose to let the 16g lose when it could barely do 8psi... yeah, and a GTR3 and a vette flew by me today, didn't give chase when I realize 8psi with 130 temp and 7 count of knock is not going to take on the big boys
ds-map, ntk.
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1085725 posted 09/16/12 07:27 PM     Remind Me!  Send Private Message   Edit Post
A 16g isn't going to do much for the chase either even if you had the ETS front mount kit.
I found the anti-lag.
Posts: 584 | From: Fresno, Califonia | Member Since: 06/11/08 | IP: (142.129.197.179) | Report this post to a Moderator
bmxr152
975/1000
Galant VR-4 org Post #: 1124099 posted 05/18/13 08:13 PM     Remind Me!  Send Private Message   Edit Post
Well i have not found any pictures or info on here about a 1g dsm VR Speed intercooler installed on a gvr4. Anyways i did one this weekend. It was not hard at all. The only modifications i had to do was trim the sides by the radiator where the wire harness tucks by. Even the mounting tabs that came with the intercooler matched up the the frame. Not the center one but im not to worried about that. I had to but another 90 degree 2.5 bend and 2.5 pipe since i cannot fit the holset with this stupid civic core. I will be going with a scirocco setup soon. anyways heres some pictures for you guys.
Anyways ill have a little stuff left to do and i snap a picture of it with the bumper on.
92 GVR4 #975-1000
90 Rs-t Gt32 powered, fully built
Edited by bmxr152 (05/18/13 08:18 PM)
Posts: 231 | From: Lake tahoe, NV | Member Since: 07/31/10 | IP: (71.80.219.32) | Report this post to a Moderator
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1124109 posted 05/18/13 10:27 PM     Remind Me!  Send Private Message   Edit Post
Search "johhny #5". I did the VRSF kit on mine and i didnt have to do much modifications at all.
-Jake
1993 Talon TSI, FPgreen DD
1957 VW Beetle Sedan Deluxe
1997 Civic EX, B18c/5lug swapped
2002 Yamaha Fz-1
Looking for another GVR4, or 5/2000...PM!
Posts: 664 | From: colorado springs, colorado | Member Since: 03/28/12 | IP: (166.137.209.18) | Report this post to a Moderator
Galant VR-4 org Post #: 1124115 posted 05/18/13 11:06 PM     Remind Me!  Send Private Message   Edit Post
Where was this when I was looking for pics like this?
Nice set good install. I would like to see a picture from the top showing how far forward under the bumper it comes.
7 1G DSM's now a GGSX build.
Posts: 1481 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
bmxr152
975/1000
Galant VR-4 org Post #: 1124152 posted 05/19/13 11:37 AM     Remind Me!  Send Private Message   Edit Post
Okay i eill post some more pictures tonight
92 GVR4 #975-1000
Posts: 231 | From: Lake tahoe, NV | Member Since: 07/31/10 | IP: (66.87.68.135) | Report this post to a Moderator
bmxr152
975/1000
Galant VR-4 org Post #: 1124190 posted 05/19/13 03:44 PM     Remind Me!  Send Private Message   Edit Post
okay heres some completed picture and the requested bumper picture. I noticed 200 rpm faster spool and 30F drop in temps at the manifold.
92 GVR4 #975-1000
Edited by bmxr152 (05/19/13 03:45 PM)
Mister1161
Newbie
1161/2000
Galant VR-4 org Post #: 1130880 posted 07/02/13 05:56 PM     Remind Me!  Send Private Message   Edit Post
that setup actually looks great.
#1161/2000 belize green
Posts: 24 | From: Wis. | Member Since: 07/01/12 | IP: (207.250.87.252) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1130883 posted 07/02/13 06:27 PM     Remind Me!  Send Private Message   Edit Post
master p piping
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1638 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.82) | Report this post to a Moderator
Galant VR-4 org Post #: 1130885 posted 07/02/13 06:59 PM     Remind Me!  Send Private Message   Edit Post
Thanx for xtra pic
bmxr152
975/1000
Galant VR-4 org Post #: 1131351 posted 07/06/13 11:25 AM     Remind Me!  Send Private Message   Edit Post
Thanks. I just installed a scirocco radiator and now have the turbo down firing. Clean up the engine bay a little. Overall though i love the vrspeed fmic and even at 104f outside its only showing 110f intake manifold temps
92 GVR4 #975-1000
Posts: 231 | From: Lake tahoe, NV | Member Since: 07/31/10 | IP: (75.141.228.230) | Report this post to a Moderator
Chi271
271/1000
Galant VR-4 org Post #: 1131690 posted 07/09/13 01:50 AM     Remind Me!  Send Private Message   Edit Post
I will be having the same setup on 271...(1g vrsf/civic half rad.). Both parts sitting on shelf currently How were your coolant temps with that half size radiator, before and after fmic? Any over heating? Thanks
271/1000 (-Kensington grey w/sunroof)
99 GSX(northstar white)
98 TSI AWD(pewter blue)
89 Colt GT -(sold)
119/2000 NB (sold)
Posts: 76 | From: Chicago,IL | Member Since: 03/24/13 | IP: (68.24.131.189) | Report this post to a Moderator
bmxr152
975/1000
Galant VR-4 org Post #: 1131905 posted 07/10/13 10:35 PM     Remind Me!  Send Private Message   Edit Post
Well i was having overheating issues with the civic radiator so i switched to a scirocco. This way at 110f trmps though. It did fine at 95 but as soon as it hit in the 100s i couldnt get the temps lower than 210.
92 GVR4 #975-1000
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1132269 posted 07/13/13 05:38 PM     Remind Me!  Send Private Message   Edit Post
What this always boils down to is one simple question: What's your time worth?
You can make anything fit within reason. I purchased the ETS kit and had it installed because it was worth more to me to have time available to work then it was to have time devoted to tearing down my car and installing the kit. And that's with a setup designed specifically for the VR4. If you have the tools, awesome and you can make quick work of a kit. If you don't have the tools, you'll either have to improvise, or buy tools (so now it's a bit more). If you are making a non-kit work, be prepared for custom pipes, weird angles, tap and die sets, etc....
anything can be done, but I've seen far too many people think they are going the easy/less-expensive route only to be shaking their heads months later saying "yeah, I got it in, but if I could do it over again...."
That being said, if you don't need it as a daily and you have the space to work on it, you'll never learn more about your car then by breaking it and putting it back together!
Quoting Yao:
RIP 543
Ded click
2006 Suzuki SV-650 (for sale)
2011 BMW 335d (~510'lb/tq and 36mpg. hwy. How can you go wrong?)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (41.162.24.37) | Report this post to a Moderator
bmxr152
975/1000
Galant VR-4 org Post #: 1133335 posted 07/20/13 09:24 PM     Remind Me!  Send Private Message   Edit Post
It really was not that much extra work to get it to fit. I like that the piping was a good 2 feet shorter with less bends on the 1g intercooler. So far I still like it. Ive had an ets kit on another car and i still had to do some modifying of the radiator support.
92 GVR4 #975-1000
Edited by bmxr152 (07/22/13 10:54 PM)
car_guy
Galant VR-4 org Post #: 1218194 posted 10/08/15 10:42 PM     Remind Me!  Send Private Message   Edit Post
I know this is an older thread but now that ETS is no longer an option, I'm seriously considering this. My question is what intake and MAF setup are you guys who have done this using?
Edited by car_guy (10/09/15 05:57 AM)
Posts: 60 | From: Farmington, NM | Member Since: 07/13/15 | IP: (75.173.117.120) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1218242 posted 10/09/15 03:46 PM     Remind Me!  Send Private Message   Edit Post
You might try calling English Racing. They are right around the corner from ETS and might have some stock on the shelves.
I mean if you're lucky....
EDIT:
Wait, why is it not an option? I didn't even bother checking before writing my reply, but it's certainly still on their website.
Oh, and you are my hero. Thanks for searching old threads before posting a new one!
RIP 543
Ded click
Edited by EfiniX (10/09/15 03:50 PM)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (209.152.44.116) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1218470 posted 10/13/15 02:05 PM     Remind Me!  Send Private Message   Edit Post
ETS sadly discontinued the GVR4 kit. They will no longer carry or make the pipes, just the Intercooler.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Generated in 0.184 seconds in which 0.119 seconds were spent on a total of 14 queries. Turbo powered.
