Galant VR-4 Forums » Galant VR-4 » Technical Discussions » EVO 8 Brembo's on a VR4 Question
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019274 posted 09/19/11 09:59 PM     Remind Me!  Send Private Message   Edit Post
Ok so Will JDM EA5A/EA6A Galant Steering Knuckles MR369425 & MR369426 found on restyled (1998+) Galants EA5A (sedan) and EA6A (wagon) Fit on my Galant? the reason im asking is because i wanna run EVO 8 brembos for the front and apparently these are the ones that allow you to do this but this was done for a 2G though. so what im asking is will these JDM Knuckles bolt up to a USDM galant VR4?
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3703 | From: Houston, Texas | Member Since: 04/07/11 | IP: (24.249.34.170) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 1019279 posted 09/19/11 10:05 PM     Remind Me!  Send Private Message   Edit Post
2G front knuckes are totally different. Won't work.
I've been trying to find someone to sell me a frond evo knuckle so i can strip it down and see if i can make it work on a GVR4
use the search, this topic has been gone over quite a few times.
-Joshua Adventure Driven Design
1991 Galant VR-4
1999 Montero "Goldi-Locker"
Posts: 5593 | From: Arizona | Member Since: 05/28/03 | IP: (76.23.73.113) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019282 posted 09/19/11 10:08 PM     Remind Me!  Send Private Message   Edit Post
Dammit! so much for that idea... so what JDM knuckle will work for our cars then?
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 1019284 posted 09/19/11 10:12 PM     Remind Me!  Send Private Message   Edit Post
don't recall, im trying to get an evo 8 knuckle since the front suspension is similar, i think i may be able to use one, wont know til i get one
1991 Galant VR-4
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019288 posted 09/19/11 10:18 PM     Remind Me!  Send Private Message   Edit Post
there's a guy on tuners that makes brackets to bolt up to our knuckles. i might just go that route
QnzMostWanted
Shifter Mercenary
Galant VR-4 org Post #: 1019289 posted 09/19/11 10:19 PM     Remind Me!  Send Private Message   Edit Post
i know for a fact that the evo brembos fit on the 99+ USDM galant/00+ eclipse with minor modifications (with the rear) fronts are bolt on, they share a similar front strut as the GVR4 just a thought maybe those might work...the setups are similar, im sure those would be cheaper and easier to find to test out vs finding evo ones
Denver
1992 Galant GS
EVO 8 ECU Powered N/A
Daily Driven
Edited by QnzMostWanted (09/19/11 10:25 PM)
Posts: 66 | From: Orlando, FL | Member Since: 07/10/11 | IP: (99.101.85.117) | Report this post to a Moderator
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 1019294 posted 09/19/11 10:36 PM     Remind Me!  Send Private Message   Edit Post
Arent garfield in the process of making the brackets for this so you can run it???
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (108.68.109.184) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019296 posted 09/19/11 10:38 PM     Remind Me!  Send Private Message   Edit Post
oh wow I hope so, that would be amazing man. I'd def get a set. would the EVO 8 brembo's bolt up to our rear ones?
Jordangvr4
Member +
Galant VR-4 org Post #: 1019301 posted 09/19/11 10:49 PM     Remind Me!  Send Private Message   Edit Post
Nothing yet has been made up for the rear's to fit I believe and if so you'll loose the e-brake. As for the frt.spindals you don't need no jdm nor other spindals to make them work.
1991 Gvr-4 Amg
1991 Gvr-4 Jdm rhd
Posts: 318 | From: Nassau,NYC. | Member Since: 11/02/08 | IP: (68.195.136.159) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019305 posted 09/19/11 10:56 PM     Remind Me!  Send Private Message   Edit Post
yeah i'll prob just get that bracket to bolt them on from the guy on tuners, but if Garfield has some i'll get his
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019361 posted 09/20/11 12:32 AM     Remind Me!  Send Private Message   Edit Post
i would like to do the front and the rears, i hope my 18's will clear them. they should though
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019372 posted 09/20/11 12:53 AM     Remind Me!  Send Private Message   Edit Post
My rims are 18X7.5 i believe the offset is +40, not sure on the rears of the EVO 8
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 1019383 posted 09/20/11 01:33 AM     Remind Me!  Send Private Message   Edit Post
Whether they clear of not is all down to the shape of the spokes, not the offset.
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (121.73.159.203) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019387 posted 09/20/11 01:48 AM     Remind Me!  Send Private Message   Edit Post
here is a pic of my spokes on the rim. i dont know if this helps
BrandonEchols
Snow White
477/1000
12/1000
Galant VR-4 org Post #: 1019397 posted 09/20/11 02:55 AM     Remind Me!  Send Private Message   Edit Post
To do the rears and keep the e-brake you'll need 3000GT VR4 rear trailing arms, they use a drum-in-disc design like the Evo...
The guy you'll need to get in touch with goes by the name of KMV over on DSM Tuners, brackets ran me $150 shipped, with all the hardware you'll need.
I'm in the process of sorting the particulars out right now - the rear evo rotors being larger and with a higher hat than the stock rotors - so I think a spacer will be needed.
Everyone I talked to said the 3000GT rear arms were bolt on, but that's not what I've found - mine needed some die grinder modifications, and I haven't even got them fitted yet. I'll do a write up when I get everything sorted, but it's a process for sure.
What is hellaflush?
Mitsubishi = Must Involve Turbos, Suck Unless Boost Is Seriously High Inside
Edited by BrandonEchols (09/20/11 06:55 PM)
Posts: 793 | From: Anchorage, AK | Member Since: 01/18/10 | IP: (72.42.140.170) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019405 posted 09/20/11 04:13 AM     Remind Me!  Send Private Message   Edit Post
dam thanks for that great info brandon! I'll def be contacting you about this so i can do the same thing.
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1019408 posted 09/20/11 04:49 AM     Remind Me!  Send Private Message   Edit Post
Quoting BrandonEchols:
I'm in the process of sorting the particulars out right now - the rear evo rotors being larger and with a higher hat than the stock rotors - so I think a spaced will be needed.
please take a lot of pictures when doing the write up. Thanks
-Shane
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.145.216) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 1019483 posted 09/20/11 01:59 PM     Remind Me!  Send Private Message   Edit Post
Mike from looking at your wheels I would say no on clearing the Brembo brakes. For Brembo setup you need a high pad wheel. The spoke design can help to clear the brakes, but it really boils down to the back pad of the wheel.
Great deal on BC coilovers. Hit me up.
www.b2autodesigns.com
Email: [email protected]
Youtube: click
Posts: 753 | From: tampa | Member Since: 08/23/07 | IP:
(84.13.132.250) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019534 posted 09/20/11 04:49 PM     Remind Me!  Send Private Message   Edit Post
lol yeah i know right, but what if i got one of those adapter plates that bolts up to our factory knuckles? wouldnt there not be any clearance issues? because theoretically they should fit since they bolt up in the same location as the stock caliper. even though they are greater in size though.
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1019549 posted 09/20/11 05:16 PM     Remind Me!  Send Private Message   Edit Post
The caliper is much wider than the stock caliper. Only certain wheels will fit and size and offest will only be part of the equation. You have to make sure that what ever wheels you get will have plenty of clearence between the spokes and calipers.
Michael
The rebuild of 1101
Posts: 4085 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (167.80.246.204) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019577 posted 09/20/11 06:31 PM     Remind Me!  Send Private Message   Edit Post
and i suppose putting my wheels on an EVO 8 to see if they clear wouldnt be the right way to determine that would it?
QnzMostWanted
Shifter Mercenary
Galant VR-4 org Post #: 1019596 posted 09/20/11 06:48 PM     Remind Me!  Send Private Message   Edit Post
judging by the look of your wheels, it might be really tight but they MAY fit, test fitting on an evo would work to determine if ur offset is correct
stock offset on evo wheels are +38 so anything that offset or lower would clear
Denver
1992 Galant GS
Daily Driven
Edited by QnzMostWanted (09/20/11 06:50 PM)
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1019637 posted 09/20/11 09:52 PM     Remind Me!  Send Private Message   Edit Post
I wheel could have the offset that is "correct" but the spokes still may not clear.
Yes, putting you wheels on an EVO would tell you if they would clear with EVO calipers. Now be warned it may not be a 100% accurate but it will be damn close.
Michael
The rebuild of 1101
Posts: 4085 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (70.162.87.93) | Report this post to a Moderator
QnzMostWanted
Shifter Mercenary
Galant VR-4 org Post #: 1019642 posted 09/20/11 10:17 PM     Remind Me!  Send Private Message   Edit Post
also, a spacer might help as well, i know alot of people are against using them, but its alot cheaper than having to buy new wheels
Denver
1992 Galant GS
Daily Driven
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1019685 posted 09/21/11 12:44 AM     Remind Me!  Send Private Message   Edit Post
I just gotta get one of my Evo buddies to let me try it.
Posts: 3703 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.39.178) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.306 seconds in which 0.267 seconds were spent on a total of 14 queries. Turbo powered.
