Galant VR-4 Forums » Galant VR-4 » Technical Discussions » non-essential engine bay harness deletes
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 1008995 posted 08/02/11 09:00 PM     Remind Me!  Send Private Message   Edit Post
Figured this could use its own thread. Just read through an EPIC seven page thread from one of the DSG guys (Alex, I think), who came up in a search for keywords similar to these, but otherwise had no luck.
Here's the situation: You've got the engine bay harness - all of it - and you want to remove non-essential leads/connectors. Then you want to upgrade leads/connectors where failures are common. What do you remove? What do you replace? And yes, my dear friend, John, I am thinking GM Weatherpak connectors throughout.
Caveat: The harness is staying in the car for this process. If I had half a dozen blokes on the hook for a new harness (and who had paid in advance), I'd be building a proper harness board right now, but as this is not the case, I'm just looking to do a little electrical pruning in the engine bay.
Ideas appreciated. Thanks.
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (204.17.31.126) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 1009031 posted 08/03/11 12:03 AM     Remind Me!  Send Private Message   Edit Post
With all of the factory parts? I don't think it's a question of what to replace; all the connectors are all 20 years old. It's more of a question of what CAN you replace.
The other question regarding what to remove is fairly simple and just depends what you still want in the car (ABS, A/C, etc.)
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (184.215.121.140) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1009033 posted 08/03/11 12:16 AM     Remind Me!  Send Private Message   Edit Post
If you search really hard (I never have any luck) there was a discussion of a fellah who removed his fuel management harness i.e. ECU harness and either lengthened and or shortened each sensor's wiring and sheathed it in 'Milspec.'
It was a pretty detailed discussion and contained some pretty nifty picks.
182/1000
Posts: 1456 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (146.53.3.5) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1009034 posted 08/03/11 12:29 AM     Remind Me!  Send Private Message   Edit Post
Thanks, gents. Milspec would be nice, but would be overkill when I still need to buy things like tires, brakes, etc..
I guess I'm thinking more along the lines of things like all those goofy little solenoids here and there. The car will be running speed density and have a Cyclone intake manifold on it, so those might be worth mentioning.
My plan right now is to ziptie the harness where bits and sections split off, then strip back the plastic guards and start cleaning things up. This is not a cosmetic mod so much as a reliability mod. Seems to me a lot of DNFs occur due to electrical, hydraulic, or operator error.
Thanks.
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (68.2.216.123) | Report this post to a Moderator
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 1009041 posted 08/03/11 01:05 AM     Remind Me!  Send Private Message   Edit Post
So in for this thread! My harness is in desperate need of trimming and repair...
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3854 | From: Cypress, TX | Member Since: 08/07/02 | IP: (76.30.185.53) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1009097 posted 08/03/11 10:59 AM     Remind Me!  Send Private Message   Edit Post
Well my harness is out and I have not even looked at it. Lets see what is thrown at this thread.
565/2000
699/2000
Random 1gb FWD I bought
Posts: 346 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (204.124.136.17) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1009122 posted 08/03/11 12:47 PM     Remind Me!  Send Private Message   Edit Post
Word. I'm planning on starting at the ends and working my way back to the firewall on both ends. I'll be evaluating the condition of the connectors and whether or not I need to keep things along the way. Guess I'm more looking for thoughts on what to keep an eye out for while I go. Kinda like those vac line delete threads.
Cheers.
123abc
1945/2000
Galant VR-4 org Post #: 1009144 posted 08/03/11 03:39 PM     Remind Me!  Send Private Message   Edit Post
Dunno if this is helpful or not, but when I did the harness in my 1g DSM, this is all I needed for the motor:
Only thing not labeled is the starter wire harness which is the plug not labeled by the firewall plug. I ran my harness next to the shifter cables:
My maf sensor plug was ran inside because I run a translator, and for the wiper motor I ran it through the fender well on the pass. side:
Keep in mind, this is on a 1g dsm, no a/c, no emissions, no cruise, etc.
Edited by 123abc (08/03/11 03:41 PM)
Posts: 144 | From: Winona, MN | Member Since: 03/02/07 | IP: (71.90.121.58) | Report this post to a Moderator
182/1000
Galant VR-4 org Post #: 1009190 posted 08/03/11 08:57 PM     Remind Me!  Send Private Message   Edit Post
Okay, I new it was on here somewhere. Below is a link that may still be overkill for you Brian, but at least its something you can think about maybe doing down the road. This was a project strokin4door came up with a few years ago. Enjoy.
Harness Reworked
Edited by Pot (08/03/11 08:59 PM)
thedsmguy
Galant VR-4 org Post #: 1009199 posted 08/03/11 09:51 PM     Remind Me!  Send Private Message   Edit Post
Linky no worky..
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (24.20.91.222) | Report this post to a Moderator
Romanova
Galant VR-4 org Post #: 1009212 posted 08/03/11 10:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting Pot:
Harness Reworked
Fixed link
tyler
2016 Explorer PI
2006 LS430
2012 GX460
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 1009233 posted 08/04/11 01:41 AM     Remind Me!  Send Private Message   Edit Post
I did this exact thing for the Chevette build but I had the luxury of having the harness out of the car. I didn't keep any solenoids, the ABS, or A/C. Just the bare minimums. The only real issues I saw when I got all the unneeded stuff out of there was the temp sender leads were a little toasty. I'm a big Weatherpak fan myself but there really aren't any places for them in the harness as all of the plugs are Mitsu specific.
I'll try and list the wires I stripped tomm, I dumped them all in a bucket and I hope they're still labeled from when I marked what to delete.
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (75.73.133.56) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1009312 posted 08/04/11 03:52 PM     Remind Me!  Send Private Message   Edit Post
Excellent! I would love to do something like Strokin4dr (nohomo) did. That's excellent. Right now, I've got a couple spools of the cheap-o plastic wrap, but I think the braided might be better in the long run (without spending an arm and a leg to look cool with mil-spec like the Honda guys do).
And props to you, @abc123, for your supremely clever screen name and sharing a picture of the whole shebang out of the car. I haven't quite got that far yet. Toying with the idea of pulling it and working on it indoors, but also like being able to mock-route leads in the bay.
Thanks everyone. Good ideas!
CarRacer
83/2000
Galant VR-4 org Post #: 1009341 posted 08/04/11 05:57 PM     Remind Me!  Send Private Message   Edit Post
If you do buy loom, make sure it's split loom. I got the grand idea of using braided sleeve and was only able to cover two small sections of the harness. There are too many branches and such to cover much with continuous sleeving.
James
83/2000
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (198.228.224.46) | Report this post to a Moderator
CarRacer
83/2000
Galant VR-4 org Post #: 1009717 posted 08/06/11 04:08 PM     Remind Me!  Send Private Message   Edit Post
Here's all the wires I eliminated. Now since I'm not going to put the motor into a VR4 or DSM chassis, I eliminated everything non-essential to the running of the motor. You will probably want to keep some of the stuff I shit canned. Stuff like the wipers, brake fluid idiot light, etc. Here's the drawings showing what wires I eliminated as well, if that helps any.
I mostly used this diagram though to trace what to eliminate. It's painstaking out of the car so I'm sure it's a cluster in the car.
James
83/2000
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (198.228.226.166) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1010193 posted 08/08/11 03:41 PM     Remind Me!  Send Private Message   Edit Post
Thanks, James. Super helpful!
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1010224 posted 08/08/11 06:08 PM     Remind Me!  Send Private Message   Edit Post
This a DSM harness, but should still be very useful for identification purposes.
Don't mind the Xs on things, that pertains to a engine swap into a different chassis where those aren't needed.
Edited by raptorreed (08/08/11 06:11 PM)
Posts: 2714 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (50.54.197.5) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 1010295 posted 08/08/11 11:15 PM     Remind Me!  Send Private Message   Edit Post
Some good info here, gentlemen!
the bitterness of low quality remains long after the temporary joy of a low price has faded
Posts: 3532 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.38.186) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1010414 posted 08/09/11 02:16 PM     Remind Me!  Send Private Message   Edit Post
I'll say. Bookmarking.
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 1010599 posted 08/10/11 05:55 AM     Remind Me!  Send Private Message   Edit Post
I just took the two harnesses (fuel/TPS/ignition/etc and Coolant/O2/etc) and removed all the loom, got em down to bare wire and connectors. Then I plugged everything back in. From there I took friction tape, which is essentially hockey stick grip tape, and at the points where a connector left the mainline of harness, I tied it off it with the tape. Then I removed the harness again, and wrapped the entire thing in the friction tape. Takes a good couple of rolls to do each harness but the friction tape stays on very well, is very flexible and is difficult to see. This also decreased the diameter of the wire bundles so you could hide more of the wires, like the fuel for example, under the injectors instead of on top. While doing all this, I inspected the connectors and removed any connectors which had no function.
I'm going back in soon to do the wires by the battery and along the passenger frame rail.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1011089 posted 08/12/11 03:06 PM     Remind Me!  Send Private Message   Edit Post
I like that idea, Brox, but I don't have an engine in the bay right now, so it's a bit tricky. Thanks for the input, though. Definitely appreciated!
desant78
Member ++
1662/2000
995/1000
Galant VR-4 org Post #: 1011719 posted 08/15/11 05:58 PM     Remind Me!  Send Private Message   Edit Post
saving this thread as a favorite too!
i wanna go fast.
1991 GVR4 1662/2000 (parts car)
1992 GVR4 995/1000 (JSB)
2008 Evo X GSR (DD with bolt ons, 17x,xxx miles)
Posts: 732 | From: Clarksboro, NJ | Member Since: 06/23/10 | IP: (138.162.0.43) | Report this post to a Moderator
CarRacer
83/2000
Galant VR-4 org Post #: 1011731 posted 08/15/11 07:36 PM     Remind Me!  Send Private Message   Edit Post
I suggest a mod change the hosting from my pictures to the GVR4 hosting as they're just on a temporary service now. They will get deleted soon.
James
83/2000
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (198.228.227.53) | Report this post to a Moderator
DR1665
Galant VR-4 org Post #: 1011924 posted 08/16/11 03:48 PM     Remind Me!  Send Private Message   Edit Post
@James, you do know you can upload pictures to the site and get that sweet, sweet, galantvr4.org hosting from the get-go, right?
Done and done.
CarRacer
83/2000
Galant VR-4 org Post #: 1012007 posted 08/16/11 11:08 PM     Remind Me!  Send Private Message   Edit Post
Yes, but I can't do that from my phone and I rarely use my desktop so it was easiest to provide the info that way. I didn't think you would want to bookmark it for later.
James
83/2000
Pages: 1 | 2
Generated in 0.267 seconds in which 0.217 seconds were spent on a total of 14 queries. Turbo powered.
