Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » New version of CAPS ( ASA )
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 874334 posted 02/15/10 03:09 AM     Remind Me!  Send Private Message   Edit Post
Note: I did not write these instructions, I am merely passing on the knowledge to you guys
Enjoy!
Welcome to the new Mitsubishi Aftersales Support Application It's an updated version of CAPS, but more powerful in it's searching capabilities. For example you can see what cars share parts in a single click! No more guess work!
**If you're running VISTA, there's a fix at the bottom for you**
Here is the download link ASA link
The files you want to download are the ones under:
"Mitsubishi ASA Japan (MMC ASA)
MMC ASA catalog of parts for all models of Mitsubishi Japanese market.
Updates via the Internet."
The password for the archives is "dsm-club.org" (without quotations)
Installation:
Once you've downloaded and extracted the two ISO files. Just mount them (with Daemon tools) or burn them with Nero or something similar.
Run disc A and choose "Setup". The program will start to install and you will get this first screen:
Choose "English UK", click OK
Next screen:
Check the "HASP HL" box, make sure nothing else is checked.
Click FINISH
Next screen (after the HASP HL drivers are installed):
Choose "Custom Install"
Next screen:
Choose your hard drive to install to, then check "Single User (Full) - Recommended"
Click NEXT
The program will install.
Once this is installed, DO NOT start the program or it will give you an error message.
You need to crack it.
Browse your ASA Jap Disc A and find the "Crack" folder. Copy the file mmData.dll to this folder:
x:\MMC\ASA\M00\PROG\ (where "x" is the drive you installed to)
Then double click and run the MMC.REG file to update your registry.
The program will now work.
It works practically the same as CAPS and it works with Vista after you apply the fix below.
With x64 Vista you will need to change the registry key that is being entered. Just open it up in notepad (right click, open with, choose notepad)
When inside, one line will say [HKEY_LOCAL_MACHINE\Software\Licenses\], just change that to [HKEY_LOCAL_MACHINE\Software\Wow6432Node\Licenses\] and save it, should work after that.
the program is a 32 bit application, therefore runs in vista 64's 32 bit shell, which is kept separate to all the 64 bit stuff. just like you have a Program Files and a Program Files (x86) folder in x64.
For Vista x32 there would be a similar fix, but I haven't worked it out yet.
** I did not write these instructions, they were posted on www.4gtuner.com by Liberoz **
Short version of the instructions as written by Legume of the same forum...
1) extract file from rar. password: dsm-club.org do both flies A and B
2) mount disc A to magikdisc and run
3) select english
4) select HASP HL
5) select custom install
6) select single user (full) --> next
7) program will install but dont run until crack is installed
when disc 2 is asked for I unmount disc 1, mount disc 2 then click continue.
Browse mounted disc A and find the "Crack" folder.
Copy the file "mmData.dll" and drop it into the "PROG" folder
of NEWLY INSTALLED ASA
8) browse mounted A disc and open CRACK folder
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 949 | From: brisbane australia | Member Since: 02/13/04 | IP: (121.208.179.164) | Report this post to a Moderator
brisvr4
Galant VR-4 org Post #: 1100717 posted 12/31/12 08:55 PM     Remind Me!  Send Private Message   Edit Post
Updated link thanks to citymunky.
mitsubishilinks
Tim
1992 Auspec
Posts: 949 | From: brisbane australia | Member Since: 02/13/04 | IP: (124.189.212.116) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1100938 posted 01/02/13 12:53 PM     Remind Me!  Send Private Message   Edit Post
How do you search for random part numbers? I have some numbers I want to plug in and see what they are.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8884 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.5) | Report this post to a Moderator
citymunky
Fake Title
733/2000
1505/2000
923/2000
832/2000
Galant VR-4 org Post #: 1101195 posted 01/03/13 04:45 PM     Remind Me!  Send Private Message   Edit Post
In the Pink/salmon section there is line for P/N's. type the number and hit enter. BAM!
1990 MMC GVR-4
733/2000 (R.I.P. TurboRen) Sold.
1505/2000 (Loves strippers) Sold.
832/2000 (parts car) R.I.P.
923/2000 (my 1st) R.I.P.
Posts: 1749 | From: Chesapeake, VA | Member Since: 09/22/10 | IP: (108.26.92.36) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1101298 posted 01/04/13 06:56 AM     Remind Me!  Send Private Message   Edit Post
Got it! Thanks.
www.nostalgic.co.jp
Posts: 8884 | From: zompton | Member Since: 02/24/04 | IP: (98.144.74.199) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1101625 posted 01/05/13 06:07 PM     Remind Me!  Send Private Message   Edit Post
I had issues installing the ASA software for this reason.
"Once this is installed, DO NOT start the program or it will give you an error message."
The program automatically starts once you hit the "Finish" button.
Leave the program sitting at the final screen, and perform the remaining steps and the install moves along appropriately.
Reference running Vista 64 bit version of Windows. ASA was downloaded from original links that were listed to the site years ago.
C53A 1 of the ~1500
Edited by FlyingEagle (01/12/13 04:29 PM)
Posts: 1609 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.240.129.198) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1102077 posted 01/08/13 10:23 AM     Remind Me!  Send Private Message   Edit Post
FYI - I downloaded the ASA.exe and walked thru the install. Walked thru install with prompts that popped up. I was able to run CAPS just fine. BUT, I did not have to do the crack as indicated above. Mine was straight install and run. I did test it, apparently our gas tanks cost about $9xx.00. Yikes...
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15470 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (65.127.129.246) | Report this post to a Moderator
Drew84
801/2000
Galant VR-4 org Post #: 1102594 posted 01/11/13 11:05 AM     Remind Me!  Send Private Message   Edit Post
Any questions just ask, I use this program at work every day.
1999 Montero Winter Package
1990 Talon TSi AWD
1991 Galant VR4 801/2000
#RacedInAnger
@autoofftopic
Posts: 226 | From: Peabody, Ma | Member Since: 11/16/10 | IP: (173.162.169.117) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1102833 posted 01/13/13 09:17 PM     Remind Me!  Send Private Message   Edit Post
For anyone looking up vehicles using chassis codes versus direct input of the VIN, here is a handy visual guide.
This appears only to have models from a particular region, possibly just North America, as I do not see C58 Mirages from Germany, C70 Mirage/Colts from AUS/NZ, etc, etc. I'm sure people from Europe and the JDM belt will notice this too.
Regardless of this fact, I have never seen this compiled so nicely before.
Drew84
801/2000
Galant VR-4 org Post #: 1102915 posted 01/14/13 12:11 PM     Remind Me!  Send Private Message   Edit Post
Yes that is a North American only Market Model Code conversion chart.
1990 Talon TSi AWD
#RacedInAnger
@autoofftopic
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1103740 posted 01/18/13 09:16 PM     Remind Me!  Send Private Message   Edit Post
I had the same results as blacksheep, no file swapping or crack-installing. Works fine on my x64 Vista laptop so far. Results may vary though.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.135.121) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1109829 posted 02/20/13 09:47 PM     Remind Me!  Send Private Message   Edit Post
Found a complete DSM parts catalogue in .PDF format. If a part was in a DSM, and it has an MD Mitsu number associated to it, then it should be listed here.
Complete internal listing of parts for transmission, engines, oil coolers, nuts bolts ... the list goes on.
If you want to know where a click will take you, here is the link minus the http
://www.gmb.be/CJD_parts/CD2/Catalogs/82-96PassCar/89d.pdf
JDM Unit
486/1000
Galant VR-4 org Post #: 1109859 posted 02/21/13 12:26 AM     Remind Me!  Send Private Message   Edit Post
I want to know the difference between all these?
CASE, Thermostat
1990-92
MD130433 1 w/o Turbo, Federal
MD130435 1 w/o Turbo, Calif.
MD130434 1 w/Turbo, 1990, Federal
MD130436 1 w/Turbo, 1990, Calif.
MD168848 1 w/Turbo, 1991-92, Federal
MD168847 1 w/Turbo, 1991-92, Calif.
1993
MD190337 1 w/o Turbo, Federal
MD190340 1 w/o Turbo, Calif.
MD190339 1 w/Turbo, Federal
MD190342 1 w/Turbo, Calif.
MD190338 1 LASER w/Turbo, w/Auto. Trans., AWD, Federal
MD190341 1 LASER w/Turbo, w/Auto. Trans., AWD, Calif.
1994
MD190339 1 w/Turbo
www.nostalgic.co.jp
swe_gvr4_1991
Galant VR-4 org Post #: 1147891 posted 11/09/13 04:01 AM     Remind Me!  Send Private Message   Edit Post
Jap ASA: 505mb
General export: 460mb
Europe: 360mb
USDM: 249mb
These links will never be broken since i own that server.
.. KiM H ..
Galant VR-4 1991. Gulf spec.
Author of Swede Density software - REAL speed density for 1G's and GVR4's - Videos
Posts: 177 | From: Sweden, Alingsås | Member Since: 07/27/06 | IP: (141.101.81.52) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1149314 posted 11/19/13 07:38 PM     Remind Me!  Send Private Message   Edit Post
won't work with Win8
Posts: 249 | From: NV | Member Since: 08/05/08 | IP: (108.162.222.183) | Report this post to a Moderator
r4pt0x
Galant VR-4 org Post #: 1151394 posted 12/09/13 03:45 AM     Remind Me!  Send Private Message   Edit Post
Try this:
Fully functional web-based ASA for Europe, Asia, America and Japan markets
Posts: 123 | From: Bavaria / Germany | Member Since: 11/20/13 | IP: (173.245.53.223) | Report this post to a Moderator
BENE38A
Slanging Kiwi parts
Galant VR-4 org Post #: 1179306 posted 07/07/14 05:33 AM     Remind Me!  Send Private Message   Edit Post
I recently downloaded mitsubishi ASA, here is a link that I found through random old posts from mitsubishi forums.
I didn't need any cracks, there was even a popup walkthrough of what to do. File needed to be unzipped but works straight away on windows 7 xp.
Works great, its an American version so has all the late evo and eclipse models, I found a USDM vr4 vin and it works.
I am a caveman on computers compared to other people and I managed to do this just fine. I recommend anyone to get this, being able to search for any part number makes those big orders alot simpler and makes it easy to cross reference different models and parts.
1991 Mitsubishi Galant vr4 RS
Posts: 261 | From: New Zealand | Member Since: 09/02/13 | IP: (116.251.175.208) | Report this post to a Moderator
SleepinGVR4
What are we going to do today Ferb?
629/2000
Galant VR-4 org Post #: 1225382 posted 03/09/16 05:30 PM     Remind Me!  Send Private Message   Edit Post
If you get this message when you try to run MMC, "The key is out of date and needs to be updated," you need to edit the MMC.REG file with notepad.
This will happen if you are running a 64 bit OS. You will need to modify the registry key that is in the crack folder.
To do this, open the registry file in Notepad by right clicking and selecting 'open with' and browse for Notepad.
When opened, one line will say [HKEY_LOCAL_MACHINE\Software\Licenses\].
Change that to [HKEY_LOCAL_MACHINE\Software\Wow6432Node\Licenses\] and save it to your desktop.
Then you can double click on the registry key.
Copying the mmData.dll file and modifiying the MMC.REG key should all be done before clicking finish at the end of installing MMC from disk.
Posts: 2483 | From: Danville, Pennsylvania | Member Since: 02/12/03 | IP: (216.49.8.34) | Report this post to a Moderator
Galant VR-4 org Post #: 1239298 posted 08/30/17 09:36 PM     Remind Me!  Send Private Message   Edit Post
So I finally downloaded this from the link in the 12/31/2012 post, and I notice the date in the upper right corner is 2007-12-28. Is there any known way to get a newer version? Looks like it stops with '08 MY vehicles.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10651 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
Scientist
Secretary of the Interior
Galant VR-4 org Post #: 1239339 posted 09/01/17 11:21 AM     Remind Me!  Send Private Message   Edit Post
Try www.Partsouq.com
1988 VR4....Needs a lot of TLC
Posts: 530 | From: Roseau/Dominica | Member Since: 01/18/07 | IP: (199.189.115.30) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1239363 posted 09/03/17 06:56 PM     Remind Me!  Send Private Message   Edit Post
I have used/bought from Partsouq.com based out of the AE and another great cross reference for parts availability is www.amayama.com (parts sourced and shipped from JDM and UAE). This also allows you to compare prices and shipping from two different regions if parts are plentiful, or there is crossover into the Hyundai world.
C53A 1 of the ~1500
Posts: 1609 | From: THE Ottawa | Member Since: 03/05/05 | IP: (108.162.128.102) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1239367 posted 09/04/17 01:10 AM     Remind Me!  Send Private Message   Edit Post
previous links can be donwloaded.
but use of ASA requires registration.
the cracks do not seem to be valid anymore?
Posts: 249 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1241460 posted 01/28/18 06:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting FlyingEagle:
Is there a way to check USA stock of part numbers without calling the dealer or am I just missing that function with my older version of caps?
Posts: 380 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1243664 posted 08/07/18 10:40 PM     Remind Me!  Send Private Message   Edit Post
Anyone get it to work with windows 10?
www.nostalgic.co.jp
Posts: 8884 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1245826 posted 04/14/19 09:54 AM     Remind Me!  Send Private Message   Edit Post
I have not used the program in Windows 10 as of yet. That being said, I still keep ASA running on my older PC using 64 bit versions of windows software.
The crack software listed in the original Russian downloaded versions of ASA, was the key to getting the program to work. As long as the program wasn't auto-updating (which I think was taken out of the program likely to keep it working as long as mine has), the crack update feature that you re-direct the Registry Key with, is yeah, the key to making it stick. It has been years since I installed the programs on my older pc and I would have to try and make this work on my newer PC with Windows 10.
New links have come to light that are Russian based, but provide updated versions of the ASA softare.
Located here: http://mmc-manuals.ru/Downloads
Here is a quote of the page you will get directed to by clicking the link:
Mitsubishi ASA v.1.8.0.0
Mitsubishi ASA
Mitsubishi ASA - Aftersales Support Application
Installation manual (on russian)
[M00] Mitsubishi ASA Japan, update 596 (2017-04-28), 417 MB
[M50] Mitsubishi ASA North America, update 492 (2017-04-28), 211 MB
[M60] Mitsubishi ASA Europe, update 565 (2018-06-01), 331 MB
[M80] Mitsubishi ASA General Export, update 476 (2017-04-28), 443 MB
Flat Rate Manual
This Flat Rate Manual has been prepared so that the personnel of service shops authorized by Mitsubishi Motors Corporation can utilize it as a handbook for estimating repair costs and for handling warranty claims.
All flat rate times listed herein are subjected to change at any time by Mitsubishi Motors Corporation based on time studies related to design change on vehicles, or improved repair methods, techniques or equipment, or other advance in the industry.
Flat Rate Manual (2007), eng., ISO image into RAR archive, 91,6 MB
Flat Rate Manual, version 4 (July, 2011), eng., fra., ger., ndr., spa., sva., ISO image into RAR archive, 41,0 MB
Flat Rate Manual, version 6 (July, 2013), eng., ISO image into RAR archive, 31,5 MB
Flat Rate Manual, version 10 (November, 2017), eng., ISO image into RAR archive, 32,2 MB
Flat Rate Manual, version 11 (December, 2018), 2019 MY, eng., ISO image into RAR archive, 33,4 MB
You can also get Mitsubishi Flat Rate Manual to use to your advantage when estimating time to do a simple repair or for major work on the exterior. I have just installed the Flat Rate Labor Time Guide using Windows 10, and it is up and running as intended. Very rudimentary and will take some time to familiarize with, but should do the trick. I always give up a day when I want to do something basic on my car, as so many little steps on taken along the way to care for fit and finish and or anticipating extra parts required to complete the task without having to step away from the job, mid task. If looking to quote a labor time for major vehicle repair in the future - like a wrinkled rear end due to being hit from behind - you now have the tools to use to prove what labor time is a bare minimum, assuming OEM parts are used to do the repair - if this writes off a car or provides for a higher labor payout with no repair performed (IE a cheque from your insurances company in lieu of repair this is the information you need as provided by the manufacturer!). I installed the 2007 version as I was hoping earlier models were not dropped, as in later 80's/early 90's platforms.
C53A 1 of the ~1500
Posts: 1609 | From: THE Ottawa | Member Since: 03/05/05 | IP: (198.84.216.54) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.109 seconds in which 0.029 seconds were spent on a total of 14 queries. Turbo powered.
