Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » How do you disable the alarm?
BKatter
Galant VR-4 org Post #: 409360 posted 11/20/06 10:18 PM     Remind Me!  Send Private Message   Edit Post
Everytime I lock my doors, the alarm goes off a few minutes later. Is there a way to disable it?
| | | IP: (71.35.244.111) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 409362 posted 11/20/06 10:24 PM     Remind Me!  Send Private Message   Edit Post
unplug the switch under the hood, its usually the culprit
its on the radiator support, a little rubber button thingy that gets pushed down by the hood.
sometimes the rubber is gone and a little white thing is sticking up.
-luke-
86gt pte67gtq
galant vr4 1464 12.83 @ 106
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (69.248.160.150) | Report this post to a Moderator
NYC86ZC
30-Something
541/1000
Galant VR-4 org Post #: 409682 posted 11/21/06 07:46 PM     Remind Me!  Send Private Message   Edit Post
i'm wondering the same thing.
Is there a fuse just for the alarm that I can just take out. My car almost didn't start the other day apparently becuase the alarm was going off all night.
-92 Grey #541
-05 WRX
Posts: 1002 | From: Long Island, NY | Member Since: 12/05/05 | IP: (24.186.23.30) | Report this post to a Moderator
Besso
Galant VR-4 org Post #: 409684 posted 11/21/06 07:48 PM     Remind Me!  Send Private Message   Edit Post
mine was doing it the other day too out of nowhere My carbon fiber hood is probably so puss that it sets the trigger off
| | | IP: (75.67.62.49) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 409697 posted 11/21/06 08:12 PM     Remind Me!  Send Private Message   Edit Post
What Luke said it right. The most common cause I've found that makes it go off is the underhood switch. If you want to disable it you've got to either ground a wire on the trunk latch or maybe short two of them together. The answer has been stated on here a few times.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (70.107.83.56) | Report this post to a Moderator
boostola
Galant VR-4 org Post #: 409700 posted 11/21/06 08:15 PM     Remind Me!  Send Private Message   Edit Post
Ground the factory alarm disarm wire in the kickpanel and the alarm will stay disarmed. The wire will meter as a negative trigger when the key is turned to the unlock position in the driver door. Anyone remember what color it is?
| | | IP: (70.9.198.97) | Report this post to a Moderator
BKatter
Galant VR-4 org Post #: 409732 posted 11/21/06 10:46 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help. I unplugged the switch under the hood and locked the doors and the alarm hasn't gone off yet. It'll be so nice to be able to finally lock the doors.
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 433240 posted 01/22/07 02:27 PM     Remind Me!  Send Private Message   Edit Post
I found this thread a couple weeks ago and it jinxed me. The horn on mine doesn't work, but this afternoon, while buying some smokes, the damn thing started honking all feeble and sickly-like.
I assume the grounding the sensor in the trunk or unplugging the hood sensor are ways to disable the alarm when it's getting false triggers from those points, while grounding the wire in the fuse box is an overall fix, correct?
Thanks. That alarm horn is super gay.
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (72.25.185.195) | Report this post to a Moderator
3Diamond
Hampster Powered and In the "Private" clan !
Galant VR-4 org Post #: 433631 posted 01/23/07 10:11 AM     Remind Me!  Send Private Message   Edit Post
I thought the most effective means of disabling the stocker was just pulling the 2 relays?
Stupidity should be Painful ! http://dsmetc.com/forum/images/smilies/rant.gif
Posts: 1046 | From: Vancouver | Member Since: 10/25/04 | IP: (142.35.4.130) | Report this post to a Moderator
TOF
Galant VR-4 org Post #: 433729 posted 01/23/07 12:45 PM     Remind Me!  Send Private Message   Edit Post
Why...just because it blows?
| | | IP: (139.177.225.66) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 433750 posted 01/23/07 01:17 PM     Remind Me!  Send Private Message   Edit Post
Does the factory alarm do anything other than makes noise (starter disable or similar)? If not, I'd think the easiest way to kill it would be to unplug the alarm horn on the firewall.
I've only managed to set mine off once, but I forget how I did it.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.129) | Report this post to a Moderator
shadowgames81
Galant VR-4 org Post #: 446576 posted 03/02/07 07:12 PM     Remind Me!  Send Private Message   Edit Post
I'm seriously tired of this alarm.....where is this wire in the kickpanel or which whire in the trunk do I need to cut/ground or wutever? Anyone w/ pics or anythin? I've been leaving my battery cable kinda loose so I can jump out and pull it to get it to stop. KInda embarrassin. Any help?
| | | IP: (70.177.219.43) | Report this post to a Moderator
Josh Weaver
Galant VR-4 org Post #: 446611 posted 03/02/07 09:05 PM     Remind Me!  Send Private Message   Edit Post
There is a search button at the top of this page in bold. This topic has been covered many times.
Open your trunk and look up at the lock mechanism on the trunk. There are 2 wires going to the lock. These wires disable the alarm when you open the trunk with a key. You need to cut these two wires. Now, splice the two wires together (not the pieces still attached to the lock). This should permantly disable the alarm assuming your wiring is in good shape. I don't know the kick panel method off the top of my head, it's not as easy to remember.
-Josh
| | | IP: (76.170.178.145) | Report this post to a Moderator
shadowgames81
Galant VR-4 org Post #: 447057 posted 03/04/07 02:47 PM     Remind Me!  Send Private Message   Edit Post
I have unplugged the button under the hood and spliced the wires in the trunk. Everything seemed fine for the past 2 days until a few hours ago when the dumb thing went off again.
Is there any other way to get rid of this thing? Right now I have my battery terminal lose so I can yank it if it goes off but this causes a prob cuz sometimes I have to get out and jiggle it to start the car. I've done searches plenty of times on this subject and seen about a wire in the kickpanel but I need to know which wire or what else I can try cuz this is very annoying.
shadowgames81
Galant VR-4 org Post #: 447101 posted 03/04/07 05:55 PM     Remind Me!  Send Private Message   Edit Post
I saw an old post and it showed a relay under the dash and in the pic he has one listed as alarm. If I pull it will it kill just the alarm or other things also? I'm gonna check into my doors to see about the switches in it hard-wiring them if I can't pull that fuse w/o losing other things.
rgeier11
sled driving mullet brain
Galant VR-4 org Post #: 447321 posted 03/05/07 07:47 AM     Remind Me!  Send Private Message   Edit Post
I have had the same problem for awhile and have been able to find no solution. I have done the trunk wiring mod and the under hood one with no change.
I'd like to find this "main security" relay deal thing as well.
I have taken apart my driver's and passenger's door and unplugged switches and tried some things, but nothing has worked.
1992 GVR-4 #649/1000 SOLD
1998 3000GT VR4 1of19 in New Zealand Green
1992 TSI AWD
Posts: 726 | From: Chicago Suburbs, IL | Member Since: 09/26/04 | IP: (74.134.60.15) | Report this post to a Moderator
shadowgames81
Galant VR-4 org Post #: 447533 posted 03/05/07 04:35 PM     Remind Me!  Send Private Message   Edit Post
I've done the trunk and under hood but not doors yet but it still goes off whenever it wants. Someone hasta have another fix idea or be able to say about the relay or something.
LT4mula
Galant VR-4 org Post #: 448188 posted 03/06/07 08:49 PM     Remind Me!  Send Private Message   Edit Post
I also need to find this wire so I can install my remote start... and this is what I came up with by searching... anyone know?
| | | IP: (148.64.177.155) | Report this post to a Moderator
punisher
Member +
Galant VR-4 org Post #: 448255 posted 03/06/07 10:20 PM     Remind Me!  Send Private Message   Edit Post
Brandon, your car has problems. Maybe they can figure out why your headlights come on when you turn on your left blinker too.
-Matt
1992 Talon Tsi awd - DD
1991 Eclipse GSX - project
Posts: 284 | From: Chandler, AZ | Member Since: 08/13/06 | IP: (70.162.178.95) | Report this post to a Moderator
shadowgames81
Galant VR-4 org Post #: 448407 posted 03/07/07 10:53 AM     Remind Me!  Send Private Message   Edit Post
LT4mula this is what I come up w/ everytime I search also and so far all I seem to get when I ask is the trunk and hood or someone saying to search like that hasn't been tried 1000's of times....I did find one where hertz had posted 3 links to ways to disable it but the links didn't work. So no solution to fix it though and I've done trunk and hood w/ no success
TOF
Galant VR-4 org Post #: 448518 posted 03/07/07 01:57 PM     Remind Me!  Send Private Message   Edit Post
Unplugging hood switch takes care of one alarm. Shorting the trunk wires takes care of another. But neither will resolve an issue with the door alarm system. I don't know how you do that (fortunately my similar alarm issue was related to the trunk).
Hood and trunk fixes will take care of most alarm issues. But some folks do have problems with door switches. So who among the veterins here will step up and help the newbies out on this one?
IslandVr4
Galant VR-4 org Post #: 448557 posted 03/07/07 03:16 PM     Remind Me!  Send Private Message   Edit Post
give me a moment & i'll look through the diagram & see if i can figgure out to dissable the whole system.
| | | IP: (69.29.219.248) | Report this post to a Moderator
IslandVr4
Galant VR-4 org Post #: 448631 posted 03/07/07 06:33 PM     Remind Me!  Send Private Message   Edit Post
OK, it does look like there is a single wire @ the module that can be cut to disable the system without interfering with the modules other functions.
Before I put it out there I want to try it on my own car first. I'll bring her in with me tomorrow & post up the results.
Btw, my alarm works fine, so no saying I don't return the love (nohomo ).
LT4mula
Galant VR-4 org Post #: 448666 posted 03/07/07 07:08 PM     Remind Me!  Send Private Message   Edit Post
mine also works fine, but I just have to find the disable wire for my remote start to work... otherwise I'm going to have to hope I can return it. Is the wire you are talking about the disable wire?
rgeier11
Galant VR-4 org Post #: 448747 posted 03/07/07 09:40 PM     Remind Me!  Send Private Message   Edit Post
I love you. I do.
1992 TSI AWD
Pages: 1 | 2
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.069 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
