Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » CAPS Requests
CAPS Requests
Pivvay
Galant VR-4 org Post #: 204849 posted 04/12/05 11:40 AM     Remind Me!  Send Private Message   Edit Post
Mods feel free to move this if you need to a different forum.
Okay I've got CAPS up on my work computer (finally) so I can run searches for people. I'm going to try to get common VINs posted here as it makes it easier to search but if the part is not off a DSM then please be as specific as possible. I make no guarantees the part number is correct but I'll try my best. Let me know as well if the PN was wrong so it doesn't get archived as this thread progresses.
| | | IP: (162.18.17.229) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 215190 posted 05/06/05 08:36 AM     Remind Me!  Send Private Message   Edit Post
This is certainly a good idea, but not a lot of contributions so far.
Ryan Hertz
Posts: 13499 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.70) | Report this post to a Moderator
Assmilk Pearl
Galant VR-4 org Post #: 215193 posted 05/06/05 08:39 AM     Remind Me!  Send Private Message   Edit Post
I never noticed this. I have CAPS set up at work too, so I'll do what I can to help out.
-mitsuturbo
Posts: 18893 | From: Flemington, NJ | Member Since: 09/11/03 | IP: (208.215.178.150) | Report this post to a Moderator
SteveHebert
Galant VR-4 org Post #: 216163 posted 05/09/05 06:22 PM     Remind Me!  Send Private Message   Edit Post
Looking for part number for rear wheel bearing(s) VIN JA3CX56U5NZ007219
Also is it two separate bearings for each wheel - or one complete unit with bearings enclosed?
much appreciated
| | | IP: (64.136.26.228) | Report this post to a Moderator
steelythefez
Galant VR-4 org Post #: 216195 posted 05/09/05 07:19 PM     Remind Me!  Send Private Message   Edit Post
Steve I believe that I have a spare set of rear wheel bearings. I'll look up the part numbers tomorrow.
-Paul
| | | IP: (207.180.132.96) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 216577 posted 05/10/05 06:03 PM     Remind Me!  Send Private Message   Edit Post
They are two seperate bearings:
MB290175
MB569972
There are also a seal, a cover, and a "rotor".
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.222.254) | Report this post to a Moderator
SteveHebert
Galant VR-4 org Post #: 216606 posted 05/10/05 07:44 PM     Remind Me!  Send Private Message   Edit Post
is the rotor a unit that contains the two bearings? Part # ?
Seals & cover too (might as well)
twkd
Galant VR-4 org Post #: 216738 posted 05/11/05 06:40 AM     Remind Me!  Send Private Message   Edit Post
Here you go:
34068 MB393807 DUST SEAL,RR AXLE SHAFT,INR
33103 MB290175 BEARING,RR AXLE SHAFT,BALL,16X58 REPL PART MT191613
33138 MB534782 ROTOR,RR AXLE SHAFT
33105 MB569972 BEARING,RR AXLE SHAFT,OTR,BALL,72X17-35
33108 MB290428 COVER,RR AXLE SHAFT,INR
33109 MB393803 COVER,RR AXLE SHAFT,OTR
33136A MB569254 SHAFT ASSY,RR AXLE
Pick and choose away.
twkd
Edited by twkd (05/12/05 11:02 AM)
| | | IP: (69.148.235.172) | Report this post to a Moderator
Paul Mc369
Galant VR-4 org Post #: 217167 posted 05/12/05 11:12 AM     Remind Me!  Send Private Message   Edit Post
Could someone with good CAPS skills and a jdm copy find every vehicle this part number was used on?
MB860149
gear kit, rear diff final 3.909
It may help some people stuck with the RS/EVO gear box.
| | | IP: (24.159.97.72) | Report this post to a Moderator
3Diamond
Hampster Powered and In the "Private" clan !
Galant VR-4 org Post #: 218545 posted 05/16/05 11:59 PM     Remind Me!  Send Private Message   Edit Post
OK this is a wierd one but i will be soo grateful if someone could help me out!!
Car is a Galant 1991 FWD I need illustration and part numbers for REAR bearings and fronts (if not too troubling). It came with same rotors/ebrake combo on the rear as did VR4 so-its not the DRUM version as apparently the bearings are different.
THANKS!
Stupidity should be Painful ! http://dsmetc.com/forum/images/smilies/rant.gif
Posts: 1046 | From: Vancouver | Member Since: 10/25/04 | IP: (216.187.78.204) | Report this post to a Moderator
3Diamond
Galant VR-4 org Post #: 228829 posted 06/20/05 01:33 PM     Remind Me!  Send Private Message   Edit Post
anyone? All i need are the inner, outer bearing #'s. Thats a USDM, galant SOHC 1992, WITH disc, not drum rear brakes (look like our vr4).
Posts: 1046 | From: Vancouver | Member Since: 10/25/04 | IP: (142.35.4.130) | Report this post to a Moderator
SPAM
Galant VR-4 org Post #: 229920 posted 06/23/05 06:41 PM     Remind Me!  Send Private Message   Edit Post
Can someone give me the part number to a passenger side manual steering rack bracket? Just the bracket...thanks a ton
| | | IP: (67.77.254.36) | Report this post to a Moderator
RussianE39
Galant VR-4 org Post #: 230062 posted 06/24/05 06:01 AM     Remind Me!  Send Private Message   Edit Post
About 3.9 rear diff gear set:
P/N MB860149 was used on:
CD9A, CE9A (Evo2 & Evo3 Lancers)
E38A, E39A, E74A, E84A (JDM Galants VR-4 different generations)
N23WG (Mitsubishi RVR - some kind of RHD Expo LRV but with turbo and GVR4 RS tranny :-) )
| | | IP: (83.217.42.122) | Report this post to a Moderator
WanganSedan
Galant VR-4 org Post #: 237218 posted 07/18/05 08:22 AM     Remind Me!  Send Private Message   Edit Post
Sorry I haven't checked this thread in awhile. I'll try to see if I can find the info that some people were looking for on CAPS.
| | | IP: (64.94.49.253) | Report this post to a Moderator
cycloned
Galant VR-4 org Post #: 248065 posted 08/17/05 09:35 PM     Remind Me!  Send Private Message   Edit Post
anyone knows where i can get a CAPS program?
| | | IP: (206.73.209.94) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 248075 posted 08/17/05 10:06 PM     Remind Me!  Send Private Message   Edit Post
It's in the How-To section of the board.
John'
Bimmubishi
giant log
Galant VR-4 org Post #: 249557 posted 08/22/05 07:48 PM     Remind Me!  Send Private Message   Edit Post
Rear O2 sensor for Evolution II CE9A (2 wire)
Thanks homeys.
Posts: 5698 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (24.63.8.121) | Report this post to a Moderator
ryz91
Galant VR-4 org Post #: 255976 posted 09/10/05 05:30 PM     Remind Me!  Send Private Message   Edit Post
part # for CAS plug harness, please. 91 GVR4
Thanks.
-Ryan
| | | IP: (68.122.43.97) | Report this post to a Moderator
Bimmubishi
giant log
Galant VR-4 org Post #: 297823 posted 01/24/06 08:57 AM     Remind Me!  Send Private Message   Edit Post
Looking for someone with a relatively new CAPS to look up the following:
Evo 7 (Ct9A) front lip (3 pcs I think)
Evo 7 Wheels (BBS)
Evo 7 Rear bumper
Thanks guys, I need the part numbers too. My caps is not at the shop so I can't look it up for someone.
AL
Posts: 5698 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (65.166.217.86) | Report this post to a Moderator
speedyvr4
Still looking for the forest!
536/1000
Galant VR-4 org Post #: 298645 posted 01/25/06 07:49 PM     Remind Me!  Send Private Message   Edit Post
my caps wont recognize ct9a,infact there is no evo to choose from,i guess i have usdm caps.I just got it so bear with me,if you can tell me what to put in the cells or give me a VIn i can give it another shot.
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (67.164.217.247) | Report this post to a Moderator
Bimmubishi
giant log
Galant VR-4 org Post #: 298660 posted 01/25/06 08:17 PM     Remind Me!  Send Private Message   Edit Post
Same with my caps, that's why I had to post.
Thanks for the try though.
A
Posts: 5698 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (24.91.194.250) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 298661 posted 01/25/06 08:19 PM     Remind Me!  Send Private Message   Edit Post
You're probably going to need the JDM CAPS since the 7 was never a USDM car. I don't have that on my PC. Hell, my CAPS CD doesn't even have the Evo8 on it .
John
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 298704 posted 01/25/06 09:42 PM     Remind Me!  Send Private Message   Edit Post
Alex, I checked my USDM CAPS and no Ct9A, but I thought you had a working JDM CAPS program?
Scott
525
Posts: 2054 | From: Norwell, MA | Member Since: 07/24/04 | IP: (24.218.187.156) | Report this post to a Moderator
JB
Other
Galant VR-4 org Post #: 298840 posted 01/26/06 08:28 AM     Remind Me!  Send Private Message   Edit Post
Mine has ct9a, but it only lists the 03-05's fed cars(rs, mr, and gsr)
JBiz
Half Man, Half Amazing
Posts: 5836 | From: MA | Member Since: 08/15/04 | IP: (68.162.196.178) | Report this post to a Moderator
Petey G
Galant VR-4 org Post #: 298850 posted 01/26/06 08:56 AM     Remind Me!  Send Private Message   Edit Post
good luck finding JDM caps, i know you can get books from mitsu that have all the JDM Evo part #'s.........the 3 book set is like $900.....if you need part #'s from something newer i work at a dealer so i always have newest version of caps
Edited by Petey G (01/26/06 09:12 AM)
| | | IP: (63.149.92.66) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 2 anonymous users are browsing this forum.
Generated in 0.054 seconds in which 0.021 seconds were spent on a total of 14 queries. Turbo powered.
