Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Unmodify the front knuckle.
Gtpdz
594/1000
Galant VR-4 org Post #: 1231578 posted 09/06/16 04:34 PM     Remind Me!  Send Private Message   Edit Post
So I guess I should post a bit as my first contribution to the how-to archive.
If you have modified 1g/VR4 front knuckle's hole to 14mm to accommodate EVO strut, but you want to switch to 12mm hole struts, here is a very easy and simple way to do that without swapping out the knuckles.
Click here
This particular piece it's a small piece of plain sleeve bearing that can slide into the enlarged knuckle hole. If your modified hole is properly sized it will slide in tight and your 12mm bolt will stay there as it should.
Posts: 140 | From: Gig Harbor, WA | Member Since: 03/12/15 | IP: (172.68.59.18) | Report this post to a Moderator
Galant VR-4 org Post #: 1232213 posted 10/02/16 01:13 PM     Remind Me!  Send Private Message   Edit Post
Good find. Motion Industries is a good place to find things like bearings, lubricants, anti seize compounds, etc.
I had one near work a few years back and used them for stuff occasionally.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10601 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
Generated in 0.031 seconds in which 0.024 seconds were spent on a total of 14 queries. Turbo powered.
