Galant VR-4 Forums » Community » Members' Showcase » Brad Anderson's 1991 Galant VR-4 1459/2000
Turbo99
1459/2000
Galant VR-4 org Post #: 1231697 posted 09/11/16 09:03 PM     Remind Me!  Send Private Message   Edit Post
Owner: Brad Anderson
Message Board Name: Turbo99
Year: 1991
Number: 1459/2000
Best 1/4 mile time: N/A
Dyno: N/A
Motor:
6 bolt stock original VR-4 longblock (down to the head studs and head gasket) with ~84k miles on it
Stock cams
NGK BR8ES Plugs
Fuel:
Walbro 255 fuel pump
Buschur FPR
FIC 1150's
Intake & Intercooler:
FP Intake
Buschur 1g FMIC and piping
Greddy Type-S BOV
HKS throttlebody elbow
Turbo & Exhaust:
Frank 5
Unknown brand 2.5" tubular o2 housing
2G ported exhaust manifold
Tial 40MM wastegate
Buschur 2.5" exhaust with gold HKS Hi-Power muffler
Cooling:
Modified 240sx aluminum radiator pushed into the support
Aftermarket cooling fans of unknown origin
Interior:
1g Eclipse steering wheel
Custom radio bezel gauge pod
Autometer Boost, fuel and oil pressure gauges
Custom numbered floor mats
Tech Edge wideband with display in OEM clock location
2g shifter and leather boot
Canadian seat belts
89 underdash
Exterior:
Resprayed glass out OEM Nile Black with slightly more flake added
Gas door deleted and filler neck relocated to the trunk, but still uses the stock tank
Antenna deleted
JDM headlight housings disassembled, painted black and reassembled
JDM clear corner markers
EMS, Logging & Electronics:
ECMlink V3
Tech Edge wideband
NGK plug wires
2g MAF
Playstation 2 (Yep, that's right, with Midnight Club in it)
Fold out screen in headunit and screen in back of center console with plug extenders so the rear passengers can play
Apex'i turbo timer
Battery relocated to trunk
Drivetrain:
Shep Stage III transmission
Speed Design 4 spider center differential
ACT 2600
ACT flywheel
AWS removed
4 bolt rear end
5 lug conversion
Brakes, Wheels & Suspension:
BC coilovers
Tuner lug nuts
OZ Pegasus wheels - 17x9 ET35 all around, 5mm spacers in the rear
Dunlop Direzza ZII Star Spec - 235/40/17
2g front calipers
AEM 2-piece "Big Brake" 2g front rotor kit with caliper relocation brackets
Stainless brake lines all around
ABS removed
Cusco strut bars front and rear
Whiteline sway bars front and rear
Posts: 60 | From: Rockport, MA | Member Since: 10/09/13 | IP: (172.68.55.57) | Report this post to a Moderator
0 registered and 2 anonymous users are browsing this forum.
Generated in 0.047 seconds in which 0.025 seconds were spent on a total of 14 queries. Turbo powered.
