Galant VR-4 Forums » Community » Members' Showcase » Luis Rosil - 1991 Galant VR4 #1415/2000
138/2000
Galant VR-4 org Post #: 1139400 posted 09/07/13 08:24 AM     Remind Me!  Send Private Message   Edit Post
Owner: Luis Rosil
Message Board Name:
Year: 1991
Number: 1415/2000
Mileage: 210,xxx
Dyno : 324 HP/360 TQ @ 20 PSI
Best 1/4 mile time: None yet
Build Thread
Dyno
Everything was done on the car at 183,642 miles unless otherwise noted.
Engine:
2g pistons/1g rods
evo 8 valves, springs & retainers
MLS head gasket
arp head studs re-torqued at - 207,321 miles
revised 3mm lifters - 186,231 miles
BSE Kit
Forward facing oil filter housing
Unorthodox Aluminum Crank Pulley - 194,543
Prothane Red Motor Mounts
HKS Clear Timing Cover
Mishimoto catch can - 207,321 miles
Black Top CAS - 202,136 miles
SS oil feed line - 207,321 miles
Larger oil return line - 207,321 miles
Custom water pipe - 207,321 miles
SS valve cover bolts - 207,321 miles
BC 272 Camshafts - 210,000 miles
Fuel & Ignition:
Custom trunk battery tray - 202,231 miles
D-51 series Optima Yellowtop - 201,642 miles
AEM 340 in tank fuel pump - 202,136 miles
Fuel pump re-wire
denso 780cc injectors
Injector seals and cleaning - 207,321 miles
full throttle FPR w/ gauge
-6 AN line from filter to rail - 207,321 miles
Russell Fuel filter - 207,321 miles
NGK Copper BPR8ES - 207,321 miles
SS fuel rail bolts - 207,321 miles
92 octane
Intake & Exhaust:
Ported Evo 3 exhaust manifold - 207,321 miles
Exhaust manifold studs - 207,321 miles
PTE SCM 6152E - 210,000 miles
ARP manifold to turbo bolts - 207,321 miles
3" intake - 207,321 miles
Punishment racing EW with Tial WG - 207,321 miles
Titanium Heat wrapped down pipe - 207,321 miles
3" turbo back exhaust, W/ V-Band clamps, Vibrant muffler - 207,321 miles
JM Fabrications SMIM - 210,000 miles
Thermal throttle body and intake manifold gaskets - 207,321 miles
1G ETS race intercooler - 207,321 miles
Tial 50mm BOV - 207,321 miles
2.5" aluminum intercooler piping made to be as short as possible
GM IAT
OMNI 4 bar MAP sensor
IR boost controller(linked into ECMLink)
S90 3" throttle body - 210,000 miles
FIAV block off - 191,943 miles
New Biss with o-ring
all new gaskets - 207,321 miles
full OEM heat shields - 207,321 miles
Misc. SS bolts - 207,321 miles
Drivetrain:
short throw shifter
Rebuilt shifter assembly - 202,467 miles
Hardened washers for shifter base - 202,467 miles
Fresh Clutch fluid - 207,321 miles
OEM Throw-out bearing - 202,467 miles
Shep Stage 1 transmission - 207,321 miles
FX 2200LB PP - 202,467 miles
FX Multi-friction Race disc - 202,467 miles
resurfaced ACT aluminum flywheel - 202,467 miles
apr flywheel bolts
rebuilt driveshaft w/ carrier bearings 186,973 miles
Redline 75w90 & heavy shockproof - 207,321 miles
Front Axles - 207,321 miles
SS clutch line - 207,321 miles
rebuilt slave and master - 207,321 miles
4 bolt rear end in 4WS housing - 207,321 miles
5 lug conversion - 207,321 miles
Cooling:
Sirocco radiator - 207,321 miles
Mishimoto high flow fan - 207,321 miles
AISIN OEM water pump - 195,785 miles
180 degree thermostat - 207,321 miles
Mishimoto Radiator Hose - 199,532 miles
Greddy radiator cap W/ push release - 205,345 miles
fully flushed and back flushed system - 207,321 miles
Suspension & Handling:
4ws intact
Megan Racing Coilovers - 210,000 miles
whiteline 26mm rear sway bar W bushings- 207,321 miles
Energy bushing kit
Stock rear pads - 191,943 miles
Front and rear rotors - 207,321 miles
Cusco front and rear strut bars - 207,321 miles
All 4 corner Wheel Bearings - 207,321 miles
Moog Steering rack boots - 201,421 miles
Moog sway bar end links - 201,421 miles
Energy Front Sway bar bushings - 201,421 miles
Energy tie rod and lower ball joint caps - 201,421 miles
Non-ABS proportioning valve - 201,421 miles
Rear Adjustable Control Arms - 206,200
Rear Lower Control Arms - 206,200
Rear Moog Sway Bar Endlinks - 206,200
8G Galant Master brake cylinder - 206,200
Rims & Tires:
17" 5 lug enkei race rims with Bridgestone potenza tires - 207,321 miles
17" Evo 8 enkei rims - 210,000 miles
Gauges & Tuning:
Autometer Z-Series Boost Gauge - 206,200
Autometer Z-Series Oil Pressure Gauge - 206,200
Innovate LC2 Wideband - 208,000 miles
Blitz TT in underdash pocket
ECMLink V3 on S/D
Audio:
Pioneer Headunit w/ AUX
JL Audio rear deck and door speakers
Rockford Fosgates in the dashboard
Interior:
custom floormats
EVO 8 front and rear seats
4 point racing harnesses
Nardi steering wheel
freshly dyed carpet
Custom Cluster surround gauge pod
89 underdash with pocket
Refurbished stock 1g shift boot - 201,421 miles
Rear deck dyed black
Rear Speaker covers replaced with Misfits Cloth
89 Manual Seatbelts
threespeed harness bar - 202,467 miles
89 Glove Box - 206,200
replaced headliner - 207,321 miles
Exterior:
JDM Front Bumper - 202,477 miles
JDM Rear Bumper - 201,421 miles
JDM RS Hood
JDM Rear 1/4 Windows
EDM Amber Corners - 204,389 miles
JDM Door Stickers
Removed wing
3rd brake light installed on rear deck
stubby non-power antenna 203,432 miles
93 clear headlights - repainted - 202,477 miles
Badge Number Sticker
4WS Sticker
Rain Guards
MMC badge
Red VR-4 badge
SS fender bolts - 206,271 miles
welded sunroof shut - 205,321 miles
5 different grills
JDM fog deletes, pre-face fogs and projector fogs
Thule Roof Racks
The OEM Window Sticker from 138, not from my vin#
Paints, oils and other misc.
A/C removed
Remounted and repaired wiring.
All emissions are removed.
ABS has been deleted.
Front wheel wells re-rubberized.
Still Want:
Paint Job
138/2000
Edited by transparentdsm (08/02/17 08:36 AM)
Posts: 3527 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (108.162.215.198) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1149312 posted 11/19/13 07:12 PM     Remind Me!  Send Private Message   Edit Post
138/2000
Edited by transparentdsm (05/08/14 08:22 AM)
Posts: 3527 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (199.27.128.230) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1222781 posted 01/11/16 08:34 AM     Remind Me!  Send Private Message   Edit Post
just two quick photos. i need to clean and then take some real pictures of the car.
138/2000
Posts: 3527 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.28.186) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.053 seconds in which 0.021 seconds were spent on a total of 14 queries. Turbo powered.
