Chris Plesko's 1991 Galant VR-4
Owner: Chris Plesko
Message Board Name: Pivvay
Year: 1991
Number: unknown
Best 1/4 mile time: 12.77 @ 108 mph (2004)
Website: http://www.shiftedthinking.com
Appearance
-Tinted Windows - 35% Front and 3% Rear
-Custom Leather Shift Boot
-Yakima Roofrack
-Silver Rockymounts Trays
-Yakima Fairing with Stickers
-Red Larson Hose Kit
-shiftedthinking.com polished aluminum battery tie-down
-Sparco Mugello Steering Wheel
-TEKNIQ Steering Wheel Quick Release and Hub Adaptor
-shiftedthinking.com Shift Knob (Black and Polished)
Brakes
-Axxis Metal Master Brake Pads
-Stainless Steel Brake Lines
-Slotted Rear Rotors
Drivetrain
-TRE Tranny -1/2 & 3/4 Evo Shift Forks, Double Syncro 2nd
-23 Spline T-case
-Fidanza Flywheel
-Speed Design 4 Spider Center Differential
-Three Speed Transmission Scatter Shield
-ACT 2600 with Street Disk
-1g TEL Shifter
-Symborski Shift Kit
-Stainless Steel Clutch Line
-BG Syncro Shift In the Transmission
-Red Line HW Shock Proof Gear Lube in T-case and Rear Diff
-4 bolt LSD Rear Differential
-4WS removal
Electronics
-Greddy 52mm Black Electronic Boost Gauge
-Greddy 52mm Black Electronic EGT Gauge in #2 Runner
-Greddy 52mm Black Electronic Water Temp Gauge
-Greddy 52mm Black Electronic Fuel Pressure Gauge
-Greddy Profec B
-Gadgetsellers Blue O2 Gauge
-Blitz Full Auto Turbo Timer
-A'PEXi Super AFC
-Panasonic CQ-DFX302U CD/Radio Headunit
-Palm m500 with Pocketlogger
-Underhood Lightweight Sealed Battery
-Cockpit selectable AC and Main Fans
-Stage 3 Keydiver ECU
Intake
-K&N Filter
-DSM Translator
-3" GM MAF (blow through)
-Spearco 2-216 FMIC
-shiftedthinking 2.5" aluminum IC pipes
-DejonTool 3" Intake
-RRE Catch Can
-Magnus Motorsports Intake Manifold
-shiftedthinking.com Water Injection System
Engine
-HKS 272/272 Camshafts
-3rd Generation Lifters
-Magnacore 8.5 mm Wires
-NGK Plugs BPR7ES
-EGR Eliminated
-12" Slimline Fan (puller)
Exhaust
-Ported 2g Exhaust Manifold
-Certified Muffler 3" Turbo back exhaust
-3" Testpipe (Track) and 3" High-flow Cat (Street)
-Ported and Clipped 20g
-Extreme Motorsports 2.5" O2 Eliminator
-Tial 40mm External Wastegate
-DSMParts Stainless Steel Upper Heatshield
Fuel
-Denso 660 Injectors
-Supra TT Fuel Pump
-SteveTek Fuel System (-6an from tank)
-AutoAlchemy Rail Adapters
-Aeromotive Adjustable Fuel Pressure Regulator
-Earls -6 AN Fuel Filter
Safety
-Sparco Evo Driver and Passenger Seats
-Sparco 3" 6 point harnesses
-shiftedthinking.com Aluminum Seat Rails
Suspension
-Kumho ECSTA Supras 205/55/15 (summer)
-Michelin Arctic Alpins 195/65/15 (winter)
-Front and Rear KYB GR-2 Shocks
