Galant VR-4 Forums » Marketplace » Parts For Sale » FEELER: Shifter Bushings
blue642
Galant VR-4 org Post #: 826672 posted 09/04/09 02:30 PM     Remind Me!  Send Private Message   Edit Post
Well I've gotten some interest from another thread over in the technical section about doing a run of shifter bushings. I just made a set up for 642 and they turned out well, so I'm getting a feeler for how much interest there is and whether its going to be worth doing a run of them. They will be made from delrin and the current planned pricing is $35 shipped in the lower 48 states + paypal fee.
Paypal address is [email protected]
Make sure that you note shifter bushings in the title and that your user name for here is included.
First let me specify that these are the bushing in the actual shifter assembly. A full set will be all 6 bushing which are labeled 2, 6, & 11 in the service manual.
EDIT: based on feedback from the test sets, The shoulder of 11 was turned thinner , since there are no sideloads on the bushing and its a pain to test fit due to the C-clip. Also found that out of the several sets that I finally got to measure, the bore variations were just tolerancing range. Final sets will all be shipped with identical 2/6 bushings packaged together and the 11 bushings packaged seperate.
I'll be turning them so that they are slightly thick on the shoulder that way that they can be sanded for a tight yet bind free feel. Based of the rough end of a lot of the factory components in mine I'm not expecting them to fit every car identically so this seems like the best way to do it without introducing slop to cover the factory tolerences. This is how I did mine and after a couple test fits and sanding on the length, it had no slop or bind. Feedback is welcome on this as its no more work for me to build in clearance for those who don't want to do the fitting process and aren't concerned about some potentially minor (~.005") slop.
Since I'm new I figure I should probably give a slight background on myself as well. I'm a technician in the prototype department at a R&D build. I do everything from CNC and manual machining to final inspection there. We primarily make prototype bearings and tooling for pretty much any any market you can think of, so these are well within my comfort level of making.
Edited by blue642 (10/21/09 10:52 AM)
| | | IP: (147.185.160.242) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 826706 posted 09/04/09 04:31 PM     Remind Me!  Send Private Message   Edit Post
I'm in.
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 826723 posted 09/04/09 05:02 PM     Remind Me!  Send Private Message   Edit Post
It's awesome to have people like you around to step up and make things happen that are out of the reach of most avg people, thanks. I dream of having a cnc machine then wonder if I'd ever figure out how to use it.... Count me in for a set, if possible a set that will fit without any sanding I can see me sanding it uneven or something crazy with my luck. Pm me your pay pal info whenever they are ready.
| | | IP: (72.40.28.240) | Report this post to a Moderator
JackbNimble
Member +
Galant VR-4 org Post #: 826738 posted 09/04/09 05:53 PM     Remind Me!  Send Private Message   Edit Post
Hmmm...are these the same that will work for a '90 GGSX?
slugsgomoo: kurt cobain, lead singer of nirvana
slugsgomoo: ate a shotgun
Barnes: omnomnomnom
Posts: 274 | From: Youngwood, PA | Member Since: 02/23/09 | IP: (67.186.21.117) | Report this post to a Moderator
SmoothCustomer
Public school educated knowitall
Galant VR-4 org Post #: 826749 posted 09/04/09 06:35 PM     Remind Me!  Send Private Message   Edit Post
How big of a pain are they to change?
-Eric
2015 FR-S
Posts: 3319 | From: Lexington, KY | Member Since: 07/06/08 | IP: (128.205.224.138) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 826865 posted 09/05/09 10:31 AM     Remind Me!  Send Private Message   Edit Post
As I said in the other thread, I want a set. just let me know price and paypal address.
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (76.6.48.160) | Report this post to a Moderator
Chrisco
Galant VR-4 org Post #: 826867 posted 09/05/09 10:44 AM     Remind Me!  Send Private Message   Edit Post
Count me in. I'll be checking back for paypal information or just PM me what I need to do!
Chris
| | | IP: (24.15.174.117) | Report this post to a Moderator
vegeta1170
Member +
1077/2000
Galant VR-4 org Post #: 827072 posted 09/06/09 09:04 AM     Remind Me!  Send Private Message   Edit Post
That's sweet I'm in also.
#1077/2000 Belize Green,
E3 16G Turbo, Exhaust Manifold, O2 Housing
18" gold Enkei Rims, Synapse BOV, E8 Suspension
Whiteline Sway bars, Dejon intake.
Posts: 338 | From: syracuse, ut | Member Since: 10/26/07 | IP: (76.27.20.93) | Report this post to a Moderator
hosmer
Galant VR-4 org Post #: 827082 posted 09/06/09 09:56 AM     Remind Me!  Send Private Message   Edit Post
I'm in...the side to side on my shifter in brutally tight
Posts: 121 | From: taunton, ma | Member Since: 01/17/09 | IP: (76.28.71.105) | Report this post to a Moderator
weed831
Galant VR-4 org Post #: 827151 posted 09/06/09 03:32 PM     Remind Me!  Send Private Message   Edit Post
I'm in, I desperately need this. I had no bushings there at all when i got the car. There's WAY too much slop.
| | | IP: (70.162.22.49) | Report this post to a Moderator
mooserage
New Title
254/2000
Galant VR-4 org Post #: 827155 posted 09/06/09 03:48 PM     Remind Me!  Send Private Message   Edit Post
whats the word on 90 shifter compatibility? If they fit I am definitely down for a set!
-shamus
-254/2000 Summit White DD (aka "The Yeti")
The Yeti loves winter and hates me.
-ムースライジュ
Posts: 1219 | From: Seattle, WA | Member Since: 05/17/04 | IP: (204.52.246.172) | Report this post to a Moderator
1941Galant
Will fight mice for food
1941/2000
Galant VR-4 org Post #: 827156 posted 09/06/09 03:51 PM     Remind Me!  Send Private Message   Edit Post
I'll take a set.
Posts: 1904 | From: Charles Town, WV | Member Since: 08/21/04 | IP: (70.44.252.218) | Report this post to a Moderator
KenGVR4
Galant VR-4 org Post #: 827170 posted 09/06/09 04:41 PM     Remind Me!  Send Private Message   Edit Post
I would be interested in a set as well
ex-461/1000
ex-1007/2000
Posts: 278 | From: Seattle, WA | Member Since: 05/13/01 | IP: (71.231.123.126) | Report this post to a Moderator
boosted_85
1320/2000
Galant VR-4 org Post #: 827233 posted 09/06/09 10:12 PM     Remind Me!  Send Private Message   Edit Post
I'm interested as well, did you figure how much its going to cost
Posts: 198 | From: milwaukee, wi | Member Since: 04/02/09 | IP: (76.230.230.15) | Report this post to a Moderator
blue642
Galant VR-4 org Post #: 827501 posted 09/08/09 07:01 AM     Remind Me!  Send Private Message   Edit Post
Price is in the top post. $35 shipped.
Not sure on the GGSX compatibility. I think the bushings are the same, just different throw, but not positive. Can anyone chime in on this one?
The actual disassembly of the shifter to change them isn't bad at all. You will need a set of retainer ring pullers to get the c-clip off to get to set 11 though. Also make sure that you get the centering spring reinstalled correctly. The bigger pain is pulling the center councel.
So far I have:
1. Hertz
2. GalantGSX
3. NateCrimsan
4. Chrisco
5. Vegeta1170
6. hosmer
7. weed831
8. 1941galant
possibly...
JackNimble
Smooth Customer
Mooserage
kenGVR4
boosted 85
talon
forbidden fruit creates many jams
136/1000
Galant VR-4 org Post #: 827509 posted 09/08/09 08:03 AM     Remind Me!  Send Private Message   Edit Post
I'm in!
1. Hertz
2. GalantGSX
3. NateCrimsan
4. Chrisco
5. Vegeta1170
6. hosmer
7. weed831
8. 1941galant
9. Talon
Posts: 172 | From: Denham Springs, La | Member Since: 09/03/09 | IP: (65.82.126.103) | Report this post to a Moderator
boosted_85
1320/2000
Galant VR-4 org Post #: 827668 posted 09/08/09 05:01 PM     Remind Me!  Send Private Message   Edit Post
count me in
Posts: 198 | From: milwaukee, wi | Member Since: 04/02/09 | IP: (148.8.18.42) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 827704 posted 09/08/09 07:21 PM     Remind Me!  Send Private Message   Edit Post
I have a GGSX and I imagine they are the same, I'm ordering them anyhow and if they don't work I'll resell them, so I will let you all know.
AutoX_VR4
Galant VR-4 org Post #: 827861 posted 09/09/09 07:13 AM     Remind Me!  Send Private Message   Edit Post
put me down for some.
| | | IP: (165.130.136.206) | Report this post to a Moderator
blue642
Galant VR-4 org Post #: 828653 posted 09/11/09 10:04 AM     Remind Me!  Send Private Message   Edit Post
I'm going to be doing a 2 more sets w/ the material I have left tomorrow. NateCrisman and GalantGSX were the first 2 to call dibs in the original thread, so they'll be getting them to verify fit. GalantGSX will allow us to verify the GSX compatibility too. Once I get closer to a final count and the fits are confirmed i'll order material for the full run which i'll do in a couple weeks.
So here's the updated list:
1. Hertz
2. GalantGSX
3. NateCrimsan
4. Chrisco
5. Vegeta1170
6. hosmer
7. weed831
8. 1941galant
9. talon
10. boosted 85
11. AutoX VR4
possibly...
JackNimble
Smooth Customer
Mooserage
kenGVR4
jared50438
Galant VR-4 org Post #: 828686 posted 09/11/09 12:10 PM     Remind Me!  Send Private Message   Edit Post
i will take some just let me know your paypal! can you pm it to me thanks!
Posts: 106 | From: garner,ia | Member Since: 10/06/08 | IP: (209.218.6.15) | Report this post to a Moderator
mooserage
New Title
254/2000
Galant VR-4 org Post #: 828707 posted 09/11/09 01:21 PM     Remind Me!  Send Private Message   Edit Post
I'll test for the 90 TEL compatibility...
1. Hertz
2. GalantGSX
3. NateCrimsan
4. Chrisco
5. Vegeta1170
6. hosmer
7. weed831
8. 1941galant
9. talon
10. boosted 85
11. AutoX VR4
12. Mooserage
possibly...
JackNimble
Smooth Customer
kenGVR4
-ムースライジュ
Posts: 1219 | From: Seattle, WA | Member Since: 05/17/04 | IP: (75.87.253.127) | Report this post to a Moderator
chvtec33
Galant VR-4 org Post #: 828851 posted 09/11/09 10:36 PM     Remind Me!  Send Private Message   Edit Post
I'm in for a set. PM when ready for money
Posts: 29 | From: Tolland, Ct | Member Since: 05/21/09 | IP: (71.235.146.229) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 828860 posted 09/11/09 11:38 PM     Remind Me!  Send Private Message   Edit Post
ill take a set, pm me payment infomation
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (71.181.182.84) | Report this post to a Moderator
jared50438
Galant VR-4 org Post #: 831686 posted 09/20/09 04:27 PM     Remind Me!  Send Private Message   Edit Post
any updates?
Posts: 106 | From: garner,ia | Member Since: 10/06/08 | IP: (71.39.225.17) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Rating: *
Generated in 0.163 seconds in which 0.13 seconds were spent on a total of 14 queries. Turbo powered.
