Galant VR-4 Forums » Marketplace » Parts For Sale » FS: '91 Gvr4 Partout (560/2000) NB *Updated February 8, 2020
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1228463 posted 05/23/16 06:09 AM     Remind Me!  Send Private Message   Edit Post
FS is nearly everything from a 1991 Galant vr4 badge number 560/2000.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions.
I accept all payments via PayPal to: [email protected]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Engine
Engine Mount Bolt *Driver Side $3.00
Resistor Pack $35.00
Throttle Cable Guide $3.00
Body
Front Driverside Turn Signal Lamp $15.00
Horn Set $8.00
Front Driver Dogleg $35.00
Rear Door Molding $50.00 each *Passenger side sold
Hood Bumper Set $5.00
Hood Latch $8.00
Hood Release Cable $8.00
Hood Cable Guide $3.00
Hood Alarm $3.00
Wiper Arm Set *Driver Wiper Foil is not included $30.00
Hood Cushions $3.00
Hood Hinge Set $15.00
Air Inlet (Passenger Side ) $8.00
Cowl Trim $8.00
Relay Set *Engine Bay $20.00
Timer Unit Defogger $8.00
Alternator Relay $8.00
Door Lock Relay $8.00
Front Window Regulator $25.00 each
Rear Window Regulator $25.00 each *Rear Driver side sold
Door Ajar Sensor Set $15.00 or $3.00 each
Door Wiring $15.00 each
Door Striker $3.00 each
Outside Door Handle Base $7.00 each
Outside Door Handle Cover $3.00
Front Door Lock Actuator & Latch Assembly $20.00 per door
Rear Door Lock Actuator & Latch Assembly $20.00 per door
Fuel Lid $15.00
Fuel Lid Hook $3.00
Driver Quarter Glass $35.00
Passenger Quarter Glass $35.00
Fuel Pump Wiring Cover Set $8.00
Driver Tail Light $40.00
Trunk Wiring, Part no MB543015 $30.00
Rear Passenger Tow Hook $20.00
Interior
Passenger Dash Speaker Cover * Driver Sold $12.00 each
Chassis Control Module $25.00
Foot Rest $8.00
Gas Pedal $20.00
Brake Pedal $20.00
Clutch Pedal $60.00
Brake Light Switch $8.00
Clevis Pin $1.00
Driver Side Mirror Trim Set $8.00
Front Skuff Plate $5.00 each
Rear Skuff Plate $5.00 each
Visor Set $15.00 each
Door Card Retainer $1.00 each
Interior Door Handle Backing Set $3.00 each
Driver Window Switch $40.00
Interior Door Pull Handle 8.00 each
HVAC Control Trim $25.00
Parking Brake Adjuster $10.00
Radio Antenna Cable $8.00
Buzzer $3.00
Shifter Base & Assembly $40.00
Center Console Side Trim $12.00 each
Doorcard Light Set $3.00 each or $15.00 for all
Center Console Trim $12.00
Glove Box Light $5.00
Control Unit Auto Seat (MB 617345) $20.00
Armrest $40.00
Rearview Mirror $15.00
Window Switch Set $5.00 each
Dome Light (Non-Sunroof) $20.00
Emergency Brake $30.00
Hood Release $3.00
ETACS (MB852353) $40.00
Passenger Door Speaker Cover $12.00
Front Lap Belts $15.00 each
Rear Shoulder Belt $15.00 each
Rear Speaker Cover $12.00
Trunk Trim $8.00
Trunk Dome Light $3.00
Trunk Trim Striker $20.00
HVAC
Cooling Unit $60.00
Blower Motor $50.00
HVAC Control $20.00
Heater Unit *Does not include Heater Core $60.00
Auto Comp Controller (MB276780) $12.00
HVAC Adjuster Tab Set $2.00
Harness, A/C Thermostat part no MB 276781 $15.00
Drivetrain
Clutch Master Cylinder $15.00
Clutch Line Bracket $5.00
Flange Yoke to Differential Hardware Set $2.00 plus shipping
Brakes
Front Driver Brake Line $15.00
Rear Brake Line $8.00 each
Brake Fluid Reservoir $15.00
Low Brake Fluid Sensor $8.00
Non-ABS Brake Lines $40.00 *Missing Passenger Side
ABS G Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Driverside Emergency Brake Cable $20.00
Steering & Suspension
Front 5 Lug Hubs $50.00 each plus shipping
Front Control Arm Clamp $15.00 each
Front Swaybar Mount Set $10.00
Endlink Set $5.00
Rear Crossmember Bracket Set $15.00
5 Lug Wheet Nut Set $25.00
Rear Stock Springs $30.00 each
Rear Strut Mounts $15.00 each
Lower Control Arms $20.00 each
Rear Swaybar Bracket Set $5.00
Rear Upper Control Arms $20.00 each
182/1000
Edited by pot (02/12/20 06:58 AM)
Posts: 1511 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (174.110.206.114) | Report this post to a Moderator
ty_miggy
Newbie
Galant VR-4 org Post #: 1229957 posted 07/02/16 09:40 PM     Remind Me!  Send Private Message   Edit Post
Is the rear windshield trim available? If so, how much and what condition?
Posts: 13 | From: Denver, CO | Member Since: 11/26/13 | IP: (172.68.35.60) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1230059 posted 07/06/16 03:47 PM     Remind Me!  Send Private Message   Edit Post
Interested in 5 lug swap and 4 bolt read end and glove box
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (76.100.71.14) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1230070 posted 07/06/16 10:38 PM     Remind Me!  Send Private Message   Edit Post
I need a very tiny part. It's a floor plug that is on the floor board behind the passenger seat carpet. It's about the size of quarter.
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3711 | From: Houston, Texas | Member Since: 04/07/11 | IP: (172.56.14.216) | Report this post to a Moderator
galant412
Galant VR-4 org Post #: 1231318 posted 08/27/16 10:09 AM     Remind Me!  Send Private Message   Edit Post
Wish I was closer I would come get that hood and the.Top part of the radiator core support.
Proud owner of 411/2000 and 412/2000
Just because your turbo spools quicker dose not mean that you will Win the race.
Posts: 86 | From: Traverse City , MI | Member Since: 06/13/06 | IP: (172.68.58.38) | Report this post to a Moderator
jduke0308
1514/2000
Galant VR-4 org Post #: 1231372 posted 08/29/16 02:59 PM     Remind Me!  Send Private Message   Edit Post
Just sent paypal for the under dash cover and 2 of your door lock tabs.
Posts: 32 | From: Aurora, CO | Member Since: 04/21/11 | IP: (172.68.34.156) | Report this post to a Moderator
jknadia
Newbie
Galant VR-4 org Post #: 1231920 posted 09/20/16 03:50 AM     Remind Me!  Send Private Message   Edit Post
Are you parting out the DOHC badge on the trunk?
Posts: 1 | From: Orcutt ca | Member Since: 09/20/16 | IP: (47.142.246.167) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1231928 posted 09/20/16 09:02 AM     Remind Me!  Send Private Message   Edit Post
Exhaust hangers. I need one but can get them all.
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 241 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (64.135.58.130) | Report this post to a Moderator
bigandbad
Galant VR-4 org Post #: 1232080 posted 09/27/16 10:51 AM     Remind Me!  Send Private Message   Edit Post
Do you have a set of the rear hub splash shields in a good condition?
Posts: 45 | From: Hamburg, Germany | Member Since: 09/06/16 | IP: (84.58.242.245) | Report this post to a Moderator
bigandbad
Galant VR-4 org Post #: 1232082 posted 09/27/16 01:20 PM     Remind Me!  Send Private Message   Edit Post
Thx... I tried at some Mitsu-dealers, here and in the US. Part is discontinued. JNZ even hasn't it in their system...
Galant VR-4 org Post #: 1232092 posted 09/27/16 04:44 PM     Remind Me!  Send Private Message   Edit Post
I may have a pair.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10745 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
turbohf
anyone even read this?
613/2000
Galant VR-4 org Post #: 1232135 posted 09/28/16 10:15 PM     Remind Me!  Send Private Message   Edit Post
vents are mine. thanks!
Dustin
1991 GVR4 #613
1966 Chevrolet Chevy II Nova 400 4dr Sedan V8
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (104.235.188.250) | Report this post to a Moderator
Toago
Newbie
Galant VR-4 org Post #: 1233977 posted 12/04/16 08:17 PM     Remind Me!  Send Private Message   Edit Post
please let me know if you could ship a working rear window defrost switch up to Canada, ideally through Express shipping haha!
Posts: 7 | From: Calgary Canada | Member Since: 11/29/16 | IP: (68.146.80.17) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 1234125 posted 12/11/16 01:41 PM     Remind Me!  Send Private Message   Edit Post
Are you willing to ship a door?
Posts: 199 | From: Lubbock, Tx | Member Since: 01/14/09 | IP: (72.26.142.229) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1234883 posted 01/24/17 03:03 PM     Remind Me!  Send Private Message   Edit Post
I'm looking for a stock rear differential. I don't really even need the internals. Just the case with the hole for the 4ws pump.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.80.190) | Report this post to a Moderator
dave
Newbie
Galant VR-4 org Post #: 1235162 posted 02/06/17 11:52 AM     Remind Me!  Send Private Message   Edit Post
do you still have the MPI relay if so i need one.
Posts: 9 | From: Brooklyn ny | Member Since: 02/05/12 | IP: (67.82.102.68) | Report this post to a Moderator
brodiedehass
Newbie
Galant VR-4 org Post #: 1237318 posted 05/19/17 03:51 PM     Remind Me!  Send Private Message   Edit Post
I am seeking front and rear windshield exterior metal trims and the plastic trim on the bottom side of the sunroof attached to the glass.
Posts: 3 | From: Millersburg, Ohio | Member Since: 05/19/17 | IP: (71.51.116.117) | Report this post to a Moderator
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 1238467 posted 07/11/17 12:01 AM     Remind Me!  Send Private Message   Edit Post
I'm looking for (8) of the white clips that attach the roof trim strips to the body.
#487/2000 Summit White
Posts: 2343 | From: Martinsburg,WV | Member Since: 01/11/02 | IP: (24.126.9.106) | Report this post to a Moderator
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 1238542 posted 07/14/17 11:14 PM     Remind Me!  Send Private Message   Edit Post
Awesome,thanks!
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 1238543 posted 07/14/17 11:24 PM     Remind Me!  Send Private Message   Edit Post
(I'm not sure how I missed your response,but I appreciate it!)
HadesOmega
Newbie
1373/2000
Galant VR-4 org Post #: 1239260 posted 08/29/17 12:05 AM     Remind Me!  Send Private Message   Edit Post
Would you happen to have:
Fuel filler hose (hose that connects from next to tank)
Rear Caliper guide pin boots
sway endlink bushings
"Black Widow" 1991 Galant VR4 #1373/2000
1998 Mitsubishi Eclipse GST
1991 Toyota Previa 5-Speed
1989 Toyota MR2 Supercharged
1976 Datsun 280Z Turbo
Posts: 24 | From: San Jose, California | Member Since: 01/04/16 | IP: (67.188.137.56) | Report this post to a Moderator
Muggus
Galant VR-4 org Post #: 1240544 posted 11/20/17 06:43 PM     Remind Me!  Send Private Message   Edit Post
I sent you a pm about some parts but now i cant seem to find whether or not it actually sent. Let me know, thanks
Posts: 27 | From: nj | Member Since: 01/06/11 | IP: (72.82.148.112) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 1240547 posted 11/21/17 08:46 AM     Remind Me!  Send Private Message   Edit Post
Fog light switch harness pig tail?
Great deal on BC coilovers. Hit me up.
www.b2autodesigns.com
Email: [email protected]
Youtube: click
Posts: 783 | From: tampa | Member Since: 08/23/07 | IP:
(79.71.93.98) | Report this post to a Moderator
182/1000
Galant VR-4 org Post #: 1240739 posted 12/02/17 08:44 AM     Remind Me!  Send Private Message   Edit Post
Quoting Muggus:
Please PM again, I did not receive it.
Posts: 1511 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2600:387:2:808::) | Report this post to a Moderator
182/1000
Galant VR-4 org Post #: 1240740 posted 12/02/17 08:48 AM     Remind Me!  Send Private Message   Edit Post
Quoting bobdole:
I do not have one Charles.
Pages: 1 | 2 | 3
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.119 seconds in which 0.084 seconds were spent on a total of 14 queries. Turbo powered.
