Galant VR-4 Forums » Marketplace » Parts For Sale » FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated May 25, 2020
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1223014 posted 01/19/16 05:44 PM     Remind Me!  Send Private Message   Edit Post
FS is everything from an unbadged non-sunroof 1991 Galant vr4. This Galant has 151,910 miles on the odometer and was originally Nile Black.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. First come first served.
I accept all payments via PayPal to: [email protected]
For inquiries please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Engine
Camshafts, Stock $30.00 each
Cam Cap Bolt Set $15.00
Rocker Arm Set $20.00
Crank Pulley Bolt w/ washer $8.00
Front Engine Mount $15.00
Water Pump Pulley Set $15.00
Resistor Pack $40.00
Fuel Rail Bolt Set $2.00 plus shipping
Fuel Feed $5.00 plus shipping
Lower Rear Timing Cover $15.00
Rear Upper Timing Cover $15.00
Banjo (Coolant) $3.00 plus shipping
Starter *Remanufactured $30.00
BOV $25.00
Harmonic Balancer Bolt Set $2.00 plus shipping
EVAP Line *Connects to Charcoal Canister $2.00 plus shipping
Body
Headlights $100.00 for the set or $65.00 each
Cowl Panel $50.00
Front Windshield Side Trim *Passenger $15.00
Hood Latch $8.00
Horn $8.00
Cowl Panel Trim $5.00
Front Driver Dogleg $30.00
Hood Release Cable Guide $8.00
Hood Bumper Set $5.00
Radiator Fan $15.00
Windshield Wiper Set *Driver Air Spoiler missing $35.00
Accelerator Cable Guide $3.00
Fuel Filter Bracket $3.00
Hood Release Cable $12.00
Throttle Cable Guide *On Passenger Strut Mount $3.00
Exhaust Hanger $8.00 each
Window Regulator $30.00
Front Driver Interior Door Wiring $20.00
Door Sensor Set $20.00 or $8.00 each
Door Latch Set $15.00 or $4.00 each
Rear Passengerside Quarter Window Glass $35.00
Rear Driverside Quarter Window Glass $35.00
Fuel Door $15.00
Fuel Door Cable $12.00
Trunklid Ajar Switch $8.00
Rooftrim Clips Set $5.00
Rear Top Window Molding $30.00
Rear Bottom Window Trim $50.00
Trunklid Catch $5.00
Center Tail Light Panel *'89 model year $50.00
Tailight Socket $5.00
Rear Decklid Wiring Harness $30.00
Interior
Dashboard Vent $2.50 each
Dash Speaker Cover *Only Driver side is available $12.00
Hood Release Lever $8.00
Horn Pad $15.00
Glove Box Frame $10.00
Glove Box Striker $5.00
Glove Box Reinforcement Bracket $3.00
ECU Tray $10.00
Lighter $3.00
ETACS $40.00
Chassis Control Module part no MB801352 *Alarm $40.00
Driver Side Visor $15.00
Rear View Mirror $15.00
Mirror Cover $8.00 (Non-Sunroof)
Outlet Bezel $15.00
Shift Cable Clips $1.00
Center Console Side Covers $12.00 each
Center Console Trim $12.00 *Mirror Adjustment Switch sold
Retractor Mounting Bracket $15.00
Retractor Shoulder Belt $30.00
Control Unit Auto Seat (Part No MB617345) $20.00
Seat Headrest $20.00
Seat Height Adjustment $5.00
Seat Hardware Cover (Driverside) $8.00
Amplifier & Radio Antenna Cable $25.00
Gas Pedal $20.00
Clutch Pedal $50.00
Clutch Interface Switch $12.00
Clutch Switch $12.00
Stoplight Switch $12.00
Front Seat Hardware Set $2.00
Front Passenger Door Speaker Cover $15.00
Driver side Speaker Cover $15.00
Door Knob Trim $.50 each
Door Handle Backing $3.00 each
Interior Door Handles $5.00 each
Interior Door Pull Handle $5.00 each
Oh Shit Handles $5.00 each or $15.00 for the set
Driver Window Switch $40.00
Front and Rear Passenger Window Switch $12.00 each
Door Card Clip $1.00 each
Front Passenger Rear View Mirror Trim $3.00
Driver Door Handle Deadpanel $3.00
Rear Door Ashtray $5.00
Doorcard Light $5.00 each
Front Scuff Plate $12.00
Passenger Rear Scuff Plate $12.00
Driver Rear Scuff Plate $12.00
Ash Tray $8.00
HVAC Bezel $30.00
HVAC Knobs $1.00
Buzzer $3.00
Center Console Side Panel Insert $15.00
Trunk Dome Light $3.00
Rear Driverside Seatbelt $20.00
Rear Defroster Heater $3.00
Trunklid Hinge Stay Set $15.00
Steering & Suspension
P/S Reservoir $25.00
P/S Reservoir Bracket $3.00
Lower Plate & Stopper Set *Front Subframe $5.00
P/S Rack Mount Bracket $12.00
Front Passenger Control Arm $25.00
Clamp $15.00 each
Front Swaybar Brackets $10.00
Rear Swaybar Bracket Set $5.00
Swaybar Endlinks $12.00
Rear Steering Rack Mounting Hardware Set $3.00
Rear Crossmember Mount $15.00
Rear Driver Upper Control Arm $20.00
Rear Upper Passenger Control Arm $20.00
Rear Shock Dust Cover $2.00 each
Rear Shock Mount Bolt Set $3.00
Rear CV Axles $40.00 each plus shipping
Rear Lower Control Arms $20.00 each
3 Bolt Cups $20.00 each
BRAKES
Brake Master Cylinder $15.00
Front Driverside Brake Line $15.00
Rear Brake Caliper Brackets $20.00 each
Parking Brake Retainer $3.00
ABS Motor $75.00
ABS Proportioning Valve $15.00
Front ABS Sensor $20.00
ABS G-Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Electronic Control Unit (ABS) $40.00
ABS Connector Bracket $3.00
Brake Fluid Reservoir $12.00
Brake Line Mount $3.00
DRIVETRAIN
Flywheel Bolt Set $5.00
Pressure Plate Bolt Set $2.00
Clutch Line to Slave Cylinder $8.00
Stainless Clutch Line $12.00
22 Spline Transfercase $150.00
Sleeve Yoke $15.00
Center Yoke $15.00
Rear Propeller Shaft Bolt Set $3.00
Rear Differential Bolt Set $10.00
Edited by pot (05/25/20 10:12 AM)
Posts: 1521 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2606:a000:5186:7) | Report this post to a Moderator
rallyvr4
Newbie
740/2000
Galant VR-4 org Post #: 1224229 posted 02/13/16 05:01 PM     Remind Me!  Send Private Message   Edit Post
I'm in need of a front sub frame?
Posts: 20 | From: seattle, wa | Member Since: 04/27/15 | IP: (107.77.97.29) | Report this post to a Moderator
15psi88
Galant VR-4 org Post #: 1224270 posted 02/14/16 08:56 PM     Remind Me!  Send Private Message   Edit Post
Would you be willing to cut the roof skin off?
If so I can have it picked up.
Posts: 101 | From: State College, PA | Member Since: 08/19/09 | IP: (65.79.254.56) | Report this post to a Moderator
Lostkoz
Newbie
Galant VR-4 org Post #: 1225918 posted 03/26/16 03:25 PM     Remind Me!  Send Private Message   Edit Post
Looking for the weather strip that sits in between the front windshield and roof of the car. Also need the driver side rear plastic 1/4 panel piece(not sure of the specified name. I can post a pic if that helps.
Posts: 23 | From: Boise, ID | Member Since: 03/15/16 | IP: (72.24.165.88) | Report this post to a Moderator
johnnyRacer
Member +++
50/2000
Galant VR-4 org Post #: 1226883 posted 04/17/16 10:00 AM     Remind Me!  Send Private Message   Edit Post
Throttle body bolts?
91 GVR4 SW 0050/2000 -sold
-3gMAS/K&N,680cc,BSE,chip,255lph,3"Exh(no cat),H.MBC,evo8/tein-S
87 Conquest TSI
92 Mustang LX Convt-sold
95 BMW E36 Convt-sold
13 F-150 Coyo
Posts: 776 | From: Chicago | Member Since: 01/09/05 | IP: (2602:306:3878:ee) | Report this post to a Moderator
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 1231723 posted 09/12/16 12:56 PM     Remind Me!  Send Private Message   Edit Post
Hey Pot...just PM'ed you a part I need.
Thanks man.
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero "Winter Package"
Posts: 2478 | From: Orlando FL | Member Since: 09/30/04 | IP: (71.43.155.210) | Report this post to a Moderator
Rrohde84
Galant VR-4 org Post #: 1231725 posted 09/12/16 01:30 PM     Remind Me!  Send Private Message   Edit Post
hey do you have a working factory radio?
Posts: 27 | From: Mundelein il | Member Since: 08/13/16 | IP: (204.58.204.13) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 1231748 posted 09/13/16 11:50 AM     Remind Me!  Send Private Message   Edit Post
Breaker and Profec B are SOLD!!!!
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-207M
2008 Toyota Sequoia 5.7L V8-125M
2013 Toyota Tundra 5.7L V8-105M
2017 VW Passat 1.8L Turbo-43M
2019 Cevy Camaro SS 1LE-5M
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (50.193.72.173) | Report this post to a Moderator
youngbuz
Newbie
Galant VR-4 org Post #: 1234309 posted 12/20/16 10:11 PM     Remind Me!  Send Private Message   Edit Post
hello im from sydney australia and need the rear bumper asap how much are you looking for ????
Posts: 1 | From: sydney | Member Since: 12/20/16 | IP: (125.168.197.76) | Report this post to a Moderator
scottinalaska
676/1000
Galant VR-4 org Post #: 1234327 posted 12/21/16 03:08 PM     Remind Me!  Send Private Message   Edit Post
Battery hold down hardware?
Posts: 47 | From: Alaska, USA | Member Since: 11/15/16 | IP: (24.237.106.213) | Report this post to a Moderator
JamesFoster
Infamous BMX Master
674/1000
Galant VR-4 org Post #: 1234337 posted 12/21/16 09:07 PM     Remind Me!  Send Private Message   Edit Post
Passenger door?
674/1000
Posts: 582 | From: CA | Member Since: 10/14/08 | IP: (45.51.41.9) | Report this post to a Moderator
MoeJz
Newbie
Galant VR-4 org Post #: 1234605 posted 01/03/17 05:42 PM     Remind Me!  Send Private Message   Edit Post
Hello,
I am looking for Passenger side door handle ( Outside ) .
Thanks,
Moe
Posts: 2 | From: San Francisco, Ca | Member Since: 01/02/17 | IP: (71.198.86.203) | Report this post to a Moderator
Pushinink
Galant VR-4 org Post #: 1234973 posted 01/28/17 10:40 AM     Remind Me!  Send Private Message   Edit Post
how much for a gauge cluster?
Posts: 70 | From: cincy, oh | Member Since: 11/30/12 | IP: (74.215.23.87) | Report this post to a Moderator
MauricioBolivia
Newbie
Galant VR-4 org Post #: 1235075 posted 02/02/17 09:54 AM     Remind Me!  Send Private Message   Edit Post
hi shipping to south america ? Bolivia ?
regards
Posts: 2 | From: La Paz, Bolivia | Member Since: 11/28/16 | IP: (190.104.30.58) | Report this post to a Moderator
Mattwood
Newbie
1393/2000
Galant VR-4 org Post #: 1238059 posted 06/17/17 08:56 AM     Remind Me!  Send Private Message   Edit Post
I'll take the passenger side speaker cover and AC bracket if still available
Posts: 8 | From: Lyons IL | Member Since: 05/30/17 | IP: (2601:807:4101:1b) | Report this post to a Moderator
Mattwood
Newbie
1393/2000
Galant VR-4 org Post #: 1238113 posted 06/21/17 07:40 PM     Remind Me!  Send Private Message   Edit Post
Is the Alternator bracket still available?
Posts: 8 | From: Lyons IL | Member Since: 05/30/17 | IP: (2600:1:920a:3d2d) | Report this post to a Moderator
chaoticdopey
Newbie
Galant VR-4 org Post #: 1239179 posted 08/22/17 12:46 AM     Remind Me!  Send Private Message   Edit Post
i need the driver seat or just the driver seat rails
Posts: 4 | From: Lancaster, CA | Member Since: 08/10/17 | IP: (2606:6000:5141:6) | Report this post to a Moderator
supersp0rt2
115/2000
Galant VR-4 org Post #: 1242353 posted 04/20/18 12:16 AM     Remind Me!  Send Private Message   Edit Post
Interested in the lower control arm set.
'90 GSX
#115 - RIP
'02 SS Camaro
Posts: 66 | From: Plainfield, IL | Member Since: 01/04/08 | IP: (199.66.69.118) | Report this post to a Moderator
182/1000
Galant VR-4 org Post #: 1242354 posted 04/20/18 03:03 AM     Remind Me!  Send Private Message   Edit Post
I have a set of Rear Control Arms available for $17.00 each shipped to your door. I have one front Passenger Conteol Arm as well. If you want just the rear, I can do $34.00 shipped to your door via PayPal to:
[email protected]
Posts: 1521 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (114.142.197.126) | Report this post to a Moderator
E39_VR4
Newbie
506/2000
Galant VR-4 org Post #: 1242365 posted 04/21/18 11:59 AM     Remind Me!  Send Private Message   Edit Post
Need headliner board and the two small lower trim panels on each side of the console. Would you by chance have the complete seat bases,just the sliders and all the associated mechanisms, with the trim panels? Don't need the seats themselves. Please PM with prices and availability. Thanks!
Democracy is two wolves and a lamb voting on lunch....
'91 GVR4 506/2000
'92 Galant base
'92 Talon TSi AWD
'94 Suzuki Swift GT
'74 Toyota Hi-Lux
'95 Honda CR250R
'75 Suzuki RE5M Rotary
'73 Honda XL175
Posts: 7 | From: Lenoir City, TN | Member Since: 04/05/15 | IP: (75.131.38.20) | Report this post to a Moderator
E39_VR4
Newbie
506/2000
Galant VR-4 org Post #: 1242366 posted 04/21/18 12:04 PM     Remind Me!  Send Private Message   Edit Post
BTW, if need be, I could come and pick up those parts, headliner would be very difficult to ship, I would think.....
'91 GVR4 506/2000
'92 Galant base
'92 Talon TSi AWD
'94 Suzuki Swift GT
'74 Toyota Hi-Lux
'95 Honda CR250R
'73 Honda XL175
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1242370 posted 04/21/18 06:21 PM     Remind Me!  Send Private Message   Edit Post
Rear passenger door handle?
I love my crazy mother!!!
Posts: 1599 | From: Manchester, NH | Member Since: 07/17/06 | IP: (2601:18d:8901:42) | Report this post to a Moderator
cptncreme
Newbie
Galant VR-4 org Post #: 1242396 posted 04/25/18 06:07 AM     Remind Me!  Send Private Message   Edit Post
Pm sent
Posts: 9 | From: Austin | Member Since: 02/28/18 | IP: (74.192.138.38) | Report this post to a Moderator
182/1000
Galant VR-4 org Post #: 1242441 posted 04/28/18 09:32 PM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
PM sent
arapp
Newbie
865/2000
Galant VR-4 org Post #: 1243744 posted 08/16/18 11:10 PM     Remind Me!  Send Private Message   Edit Post
Does your parts car have an automatic retractable radio antenna? I need the male harness and clip that plugs into the antenna motor, mines been damaged.
Posts: 17 | From: So Cal | Member Since: 05/05/13 | IP: (47.150.21.125) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 0 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.215 seconds in which 0.143 seconds were spent on a total of 14 queries. Turbo powered.
