kdott96
(Junior Member)
10/21/19 12:08 PM
Random shutdowns
I keep getting random shutdowns with 733. It happens sometimes when in idle, sometimes when driving.. it's very random. When driving, I can feel the car slowing down and no matter how much gas I press, the speed drops on its own until it turns off (or if I put neutral and drop the clutch it goes straight to 0). It starts back up right away, but I want to get to the bottom of this.
This began happening after I switched to an Odyssey battery and was missing my lower intercooler pipe, but ever since then, I replaced that battery with a bigger one I previously had and found the ETS lower intercooler pipe. I would begin to see the battery/brake lights dim on from time to time so I knew my alternator was acting up and got one from Motorcity Reman had it installed Saturday so no more lights on the dash.. but the problem persists. I have also replaced the coolant temp sensor for a new OEM one but still no luck, Is there anything I can check next?
gvr4ever
(Forever Member)
10/21/19 12:13 PM
Re: Random shutdowns
That's a tricky one....
I'd check and make sure the battery ground is clean where it connects. Near the stock air box location. I think the ECU has a ground too. One of the bolts that hold it in.
Check ECU....
It sounds like a connection issue, but with the age of these cars.... They can cause mysteries.
(Turn Right Racing)
10/21/19 05:13 PM
I had a TPS issue that would cause stalls, but never while driving. I would check for boost/air leaks in your intake system. Could be an air metering issue.
MellowVR4
(5" too short)
10/22/19 12:58 PM
Take the ECU out, open it up and take a peek.
10/23/19 07:33 AM
im gonna have to third the idea of pull the ecu, sounds to me like you have a dead ISC motor and it burnt out your 102 or 105 diode, i forget what one it is.
(I ain't no puny human)
10/23/19 08:18 AM
Make that a 4th. My ISC motor leaked into it's plug and took out the diode and the controller on the ECU. ECM Tuning fixed it right up
kdott96
(Junior Member)
10/24/19 06:13 PM
Pulled the ECU and I donít see anything extraordinary, am I overseeing anything?
kdott96
(Junior Member)
10/24/19 06:36 PM
Actually... Looking very closely at IC105 there is a vague orange part on the back Iíll hit up ecmlink tonight
gvr4ever
(Forever Member)
10/28/19 08:55 AM
Here is an example of a failed one.
Your's doesn't look like that. Did you have a idle surge problem at all?
kdott96
(Junior Member)
11/03/19 10:18 PM
No but idle ran high on cold startup no matter what
ECMtuning got back to me, could be just a failing MAP sensor
kdott96
(Junior Member)
11/14/19 09:53 PM
Dave from ECMLink said that my datalog suggested a failing map sensor reading.... and that was literally what it was. Changed the MAP sensor and car is running back again. Thanks for everybody that chipped in.
11/15/19 04:42 AM
What MAP sensor are you using?
kdott96
(Junior Member)
11/15/19 08:44 AM
Omni4bar
11/15/19 09:05 AM
Yea, they are pretty much crap. There is lots of info out there about them being problematic. Ine dies out of the blue, so I went with AEM
kdott96
(Junior Member)
11/15/19 10:48 AM
Yes Iíve heard it too, just gave it another chance bc I feel like it was my fault that it broke (probably when said pipe was not on the car)
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Turbo powered.
